Question about Kenmore 62622 Electric Dryer
Problem with my Kenmore 62622 Electric Dryer
My dryer vent is not clogged, i've cleaned it over and over. Although the dryer does not seem to be catching the lint it used to. I normally set it on the star for everything (ultra dry).Now it seems to not heat up, but if i run it on the shortest timed setting, everything gets very warm and dry, like it used to do on the star setting.
  • Anonymous Jan 08, 2008
    dryer heats up good but does not catch any lint
    Genius:
  • 1,153 Answers
It could be the elements inside dryer, one or more could be bad, the different settings causes the dryer to do different things, so whatever your setting on ultra dry may not be operating at full force. Hope this helps.
Posted on Sep 06, 2007
6ya staff
SOURCE:
Have a Kenmore elite electric dryer model 11062952100 that heats but stops midcycle on both timed and auto. It does start right back up. Does seem to take a little longer to dry clothes. Have checked the...
Check behind the dryer to make sure the tube running to the exit vent isn't clogged or blocked. Then go out side where the vent runs to and make sure it isn't clogged.
Aug 29, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
Ultra fabric care electric dryer model 96588210 stopped heating all of a sudden. I cleaned vent tube out. Flipped circuit breakers. still not heating. Thank you
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 06, 2011 | Kenmore 62622 Electric Dryer
Dryer shuts off rapidly, moved it from the wall a little seems to be working, last week the outdoor vent was opened and it did the same thing till i closed the vent door. is there a censor on the machine...
the dryer has safety features in it, if it gets to hot it will shut off or blow the thermal fuse. I would clean my vent out as well as the inside of the dryer. Hope this helped Tim
Feb 09, 2011 | Kenmore Elite HE4 Electric Dryer
I have a kenmore mp4405044 gas dryer it is leaking water, I completely cleaned the dryer 1 month ago. What is the problem
It seems like clogged vent problem .You should thoroughly clean vent and total inspection of vent
Dec 16, 2010 | Kenmore 400 6943 Dryer
Kenmore 64672 dryer gets hot but clothes still wet
you have a clogged wall vent or clogged dryer vent or a clogged lint trap,you are trapping all the hot wet air in the dryer and that's why it's taking so lont to dry-mike
Apr 22, 2009 | Kenmore 64672 Electric Dryer
Dryer runs has little heat takes longer timer to dry
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Mar 14, 2009 | Kenmore 62622 Microwave Oven
Kenmore 400 Series electric takes ver long time to dry.
Very common problem. You need to call a
duct cleaning company and tell them to clean
your dryer vent. Rule-of-thumb: dryer vents
should be cleaned every couple of years to
prevent them from being clogged with lint and
causing lint fires. This is definitely your problem. Good luck :)
p.s. one way to verify a clogged vent is
to go outside where the vent exits the house
and feel the air-flow. should have adequate air-flow.
Mar 09, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer model 41780042990
sounde like you have a clogged vent line be shure the vent hose is not cinked in any waty that would restrict the air flow. Next turn the dryer on and make sure you and a good flow of air out side the house if the air is not blowing out the vent out side you will need to clean this out or have it cleaned.
Jan 20, 2009 | Frigidaire FEQ332E Electric Dryer
Dryer not heating
THE PROBLEM IS YOUR WALL VENT CLOGGED OR THE BACK OF THE DRYER VENT HOLE IS CLOGGED,IT KEEPS THE MOIST HOT AIR IN THE DRYER SO YOUR CLOTHS TAKE FOREVER TO DRY,THEY MUST BE CLEARED FOR THE DRYER TO WORK AGAIN-MIKE
Jan 05, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore 62622 Electric Dryer Logo
75 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
