Question about Mitsubishi WS-55513 55" Rear Projection HDTV
PROBLEM WITH MITSUBISHI WS 55411
My Mitsubishi rear projection 55 inch picture blinks on and off for fractions of a second every few seconds. Also my factory remote does not work. I have a univeral remote with my bose system and the tv will respond to those commands. Any ideas as to the problem (faulty lamp? bad circuit?) and cost to repair?
  • Anonymous Dec 11, 2008
    I was getting worried that I was about to spend money I don't have. I ran my fingers across the buttons(funny as it sounds) and it worked awesome. I have a little one that I am sure had something to do with my problem. Thanks for the tips.
    Relieved
I had the same problem with my model as well. Luckily, I had the extended warranty and a technician came out and said that many people with TVs of this model have the same problem. He replaced the main system board and the problem was fixed. It has been about 4 months now and the problem just came back again. My TV is out of warranty now, but I hope I can get a warranty on that newly replaced party which appears to have gone bad again.
Posted on May 06, 2008
Update on my previous post. As stated before, after the repair technician replaced the main system board, the problem came back. I read some other sites that recommended running your fingers over the buttons on the front of the TV. Apparently, these TVs have a problem where the buttons will get stuck (even if they don't look or feel like they are stuck). As strange as it sounded, I gave it a try and it worked!
Posted on Jun 25, 2008
    Genius:
  • 1,153 Answers
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 PART # 283P044020 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT
Posted on Sep 06, 2007
SOURCE:
Mitsubishi ws55411 wont power up
Is the led just blinking non stop green? If so you need the DM repair kit for that model which is available from www.tvrepairworld.com the kit contains the upgraded caps and the CD with repair instructions.
Apr 30, 2011 | Mitsubishi WS-55411 55" Rear Projection...
I CAN GET PROPER COLOR ON MY WS-55411 MODEL
Try to describe better, is picture 3d looking or what is your problem?
Make a comment here OR IF YOU RE-POST THE QUESTION MARK IT "attention SD TECH" AND I will assist you.
I know the model indicated very well.
SD TECH
Sep 06, 2010 | Mitsubishi WS-55411 55" Rear Projection...
TV wont turn on, the power light turns green for a second then blinks three times and turns off?
That blinking light represents an error code,give Mitsubishi a call they will help you troubleshoot and diagnose your problem and if needed help you set up service. 1-800-332-2119 Good luck !
Nov 29, 2009 | Mitsubishi WS-55411 55" Rear Projection...
Do have power and sound, do not have picture
this unit has a self test check you can do
when the set shuts down or when the set is turend off.
press and hold , onthe front of the set the input or device button, and hold the menue button for bbout 5 seconds.
the set will flash a 2 digit blink code at you.
12 blik = no problem
21 blink = xray protect
22 blink = short protect
23 blink = loss of deflection.
regards,
daniel.
Jan 15, 2009 | Mitsubishi WS-55411 55" Rear Projection...
TV not turning on after left on
ok 6 hours is not long but i would deffintly say u have a power issue now with the box inside over heated and burnt out will have to be prfessionaly replaced
Jul 18, 2008 | Mitsubishi WS-55411 55" Rear Projection...
4 pin or 6 pin
It has neither. It is not firewire capable.
Jul 17, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi 55 inch Rear Projection w/ Green tint
C.V.G ADJ AND SERVICE MODE ? GREEN C.V.G BAR ADJ POPARLY?
YES , SO POPARLY NOT SAVE 50HZ & 60HZ
NO, SO CVG I.C DEF, ITHER PRT LANCE LOOSE
Jun 13, 2008 | Mitsubishi WS-55805 55" Rear Projection...
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi WS-55857 won't turn on
Thank you for posting your concern details however i would be needing few more details from your side if necessary and allow me few mins to come up with the resolution.
May 19, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
444 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
