Question about Vizio GV42L 42 in. LCD Television
Wall mount hardware
Am looking for the bolt size that goes into the back of the 42"LCD screen (4 ea) used with the wall mounting kit.
  • 3 more comments
  • ziggyzh Nov 21, 2007
    like to know the diameter of bolts (4) used to mount the 50 in. panasonic plasma TV.
  • Anonymous Mar 20, 2014
    screw size in back of
    olevia 27" lcd wallmount
  • Anonymous Mar 23, 2014
    need bolt size
  • Anonymous Mar 26, 2014
    need bolt size or thread size that goes in back of tv to mount on wall
  • Anonymous Mar 27, 2014
    There are pre drilled holes to attach the wall mount to the television on a 60" LG television. What size are the bolts used to do this?
The bolt size you need is: M8-1.25 X 20.  20 is the length that I used and it works well.  You could also use 25 (which is a little longer) if you would like.
It took about 5 trips to Home Depot and Lowe's and a few hours searching the web before we got it right.
Posted on Oct 11, 2007
What is the remote learning code for my 32" TV
Mounting an LCD (Liquid Crystal Display) TV on the wall may seem a bit overwhelming at first; but it's not that difficult. With a few simple tools, a proper mounting kit and a helper, the job will be a breeze. With a little bit of patience and an hour or two, your LCD TV will look great. Follow these steps to learn how to mount an LCD TV on the wall.
Things You'll Need:
LCD TV
Mounting kit
Tools
Step 1
Find the best spot on the wall to mount the LCD screen. Think about how much room you may want on that wall, especially if you plan on mounting speakers, too. You could hang a poster or picture relative to the size of the television on the wall to see if you like the placement.
Step 2
Pick a mounting kit. You can purchase mounting kits online (see Resources below) along with many other sites. Look to make sure the kit and TV are VESA compatible so that you have standard measurements and quick, easy attachment during the mounting process.
Step 3
You may already have tools needed to mount the TV. You'll need a set of screwdrivers, a socket set, a saw capable of cutting into drywall, a drill and a measuring tape. Having a stud finder with a built-in level is also great to pinpoint the exact location of the stud. The stud finder will be useful if you'll be running wires through the wall.
Step 4
Get the location for the TV picked out. Check near the bottom of the wall to see if the area you plan on using to run the wires is free of obstructions. Using the stud finder for this will make it easy.
Step 5
Find the studs. You should use at least one stud when mounting the LCD screen to make sure that the mounting bolts are driven into something solid that will support the weight of the TV and the mounting bracket. Using two studs is ideal for mounting larger TV's, those with screens larger than 37 inches. Use a pencil to mark the drill holes for the anchors and stud location.
Step 6
Secure the mounting rails to the back of the LCD screen. Double check them for proper fit. Make sure that they're hidden behind the body of the television for a finished look.
Step 7
Cut the hole for the wires to come through by using a drywall saw. The easiest way is to pull them out at the electrical box. This avoids having to go into the basement, closet or otherwise. You can purchase a wall box at your local home improvement store to place in the exit hole of the wires.
Step 8
Drill the holes for the bolt anchors in the locations that you measured and marked previously. Place the bolt anchors into the holes and tap them in with a hammer.
Step 9
Secure the wall mount to the wall. You'll need a socket wrench to ensure that the mounting bolts get snugged down tightly to the anchors. Use a level to make sure you've done an even job.
Step 10
Grab a friend or family member to help you lift the LCD screen onto the mount. Make sure it's locked down tightly and the screen is set to go.
Hope this helps and Good luck
Sep 25, 2011 | Televison & Video
What size bolt screws into the back of the TV to mount a wall mount
42" will more likely to use Metric M6 screws (canbe M5 but not likely), the length of the screws will depend on the thickness of the mounting plates. When you buy wall mounting kit, it will come with mounting screws. You can get Metric screw from HD or Lowe's for about 50 cents each.
I get my wall mounts from Costco and they come with a bag of Metric screws fro mounting.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Aug 06, 2011 | Philips 42PFL3603D/27 42 in. LCD TV
Trying to figure out how to convert the base to a wall mount since it appears that it is set up to do this.
first get a wall mount kit. ikea sells them cheaply.
there should be 4 screw holes on the back of the screen. screws goes in there.
first drill 2 holes on the wall
mount the ikea kit using expanding bolt
then screw in the ikea kit on the monitor
just hang the monitor on the wall side.
but..... 15 inch is a bit smallish for wall mount... dont ya think?
Jul 01, 2011 | AOMNI Corporation Magnavox 15MF605T/17 15...
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
I have an ULPT-X Omni Mount that I will be using with a Samsung 65" LED. How do I mount the ULPT-X to make sure that the exact center of the TV will be in the center of the wall space it will be hung on. ...
What do you mean by centered on the top and bottom? It doesn't need to be centered in the exact part of the wall for the tv. it all depends on what your viewing height is for where you want the tv vertically. Once you figure that out you mount it where you want it for your personal viewing preference.
Thank you,
Lee
Oct 26, 2010 | Televison & Video
I have a wall mount installed already but dont know how to attach the TV - model LA32R71B to it, should I have some bolts or nuts as there are 4 bolt holes in the back of the TV but I dont know the thread...
The wall mounting kit should come with all kind of screws to attach the mounting barckets to the back of the TV. Most TV uses metric M5 or M6 screws for the mounting holes on the back of TV, you should be able to get them at HD or LOWE for about 35 cents each.
My kits come with a bunch of Metric screws. Do you have the instruction sheet of the mounting kit?
http://s807.photobucket.com/home/budm/allalbums
Aug 08, 2010 | Samsung Televison & Video
How do I mount my Soyo MT-SYTPT3227ABMS on the wall
Things You'll Need:
LCD TV
Mounting kit
Tools
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Step 9
Step 10
Aug 03, 2010 | Microsoft MT-SYTPT3227AB 32 in. LCD TV
Purchased universal wall mount kit for Samsung LN46B530
I have found that Home Depot and Lowe's (the bigger hardware stores) do not carry something like this. I alway got to my Local ACE Hardware where they have a whole isle with nothing but screws, nuts, bolts and fasteners. I always find what I am looking for there. So if you have a little hardware store in your area then I suggest trying them. It is alittle more expensive than the bigger guys but always worth it cause you can buy one, Two or 100.
Apr 18, 2009 | Samsung LN46B530 LCD TV
No screws for wall mounting 42 inch tv
any hardware store will have them bring your tv manual with you it will tell you the spec on the screw to connect to the 4 pre existing nuts on the back of the tv as far as from the mount to wall it will be a standard lag bolt small enough to fit threw the hole and long enough to go threw the drywall and about an inch and a half of the studd 2" to 2 1/2" inch lag bolt will work
Apr 14, 2009 | Televison & Video
Vizio GV42L 42 in. LCD Television Logo
1,131 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
