Question about Panasonic Lumix DMC-LZ5 Digital Camera
Faulty focus My Lumix with 6x focus will not focus when I use the zoom.
  • Anonymous May 14, 2008
    same issue as above ..
    Problem Solver:
  • 18 Answers
Have you tried changing the focusing mode to one of the other settings? I usually find central point setting best for zoom. Alternatively, you could try using Macro (the flower) setting - I leave mine on this all the time it's really the best general purpose mode.
Posted on Jul 13, 2009
Any one there able to help? URGENTLY NEEDED SERVICE (REPAIR) MANUAL FOR PANASONIC LUMIX LF-1
It won't be easy to get a repair manual. But I advice to visit ifixit, to see if they have a manual or video for your camera. They also can help with spare parts. Camera Repair
Nov 15, 2014 | Cameras
Picture not focused at 12x zoom
It's probably something to do with a lag or jam on your shutterspeed. so when you hit the button, and move you get a little blur. If its not this you might need to have your lens cleaned inside and out due to the camera zooms and catches the blurs on the lens after zooming so far in. I would recommend taking it to your local camera shop for adjustments and cleaning.
Sep 19, 2007 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic H-FS014042 not working with GF1
If you placed the lens correct, till it clicked while turning, it should work correct. Did you check if there was anything on the contacts, before placing the lens?
Can you focus manually? and is your camera in the auto focus mode?
I can't make more at this moment. Success.
Jan 02, 2014 | Panasonic Camera Lenses, Flashes and...
Lumix Panasonic DMC FZ28 18x optical zoom, 27mm wide pix always out of focus... what could be the problem? thanks!
Does it make 2 beeps and have a green spot in the center of viewfinder/lcd? if so it is thinking it is focused, test this to see. If it is 2 beeps but definitely out of focus, it will need to go in for a back-focus alignment. Simple operation for the repair team.
Sep 21, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
HELPPP!! My camera will not focus when zooming at all.
is it possible that the focus switch on the left side of the lenses is set to macro, or manual focus? That could make your camera "go blind".
Vladimir Z
May 20, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
Panasonic lumix dmc-fx01 won't focus
See the post for the same camera: "Buttons stopped working": there is a small 2 position switch connected to the zoom button. In my camera the zoom switch was stuck in one of the extreme positions. You have to put it back in the middle an re-assemble.
Mar 29, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Camera doesn't focus
There are many reasons why images can appear out of focus. strangely if you think about it it is not focusing per se like photographic cameras the focus is at infinity by default- from about 50cm - out So if the images appear out of focus these are some of the reasons shots taken in low light with a low ASA setting resulting in long exposure -thus camera shake. Focus hunting- there are various methods used but if the mechanism cannot 'lock' onto something the focus motor will 'hunt' Faulty zoom Optic Zoom mechanism. Inadvertently set to 'Macro' mode Grease on the lens Careful checking of the camera- its settings- with the manual is essential before declaring the camera faulty Don't forget the paper manual is a nodensed version of the full manual on the software disk.
Sep 02, 2007 | Cameras
Canon powershot sd 1000
Canon Customer support re this I suspect the Zoom mechanism is damaged A rapair may be costly
Jul 31, 2007 | Canon PowerShot SD1000 Digital Camera
Pictures have come out blurry and out of focus
The most common problems that most new users encounter are: 1. Trying to focus closer than @7 ft. when zooming at greater than 6x. The camera won't do it, and that zoom is tempting. 2. Not waiting for the lens to focus before completing the shutter press. Try holding the shutter at half-press until you see the steady green indicator, then gently press fully to take the shot while holding as steady as you can. 3. Expecting too much from OIS. If you're seeing the "jitter" icon a lot, that means that you're into the range of slower shutter speeds that OIS might not be able to compensate for.You might try switching to a higher ISO speed (or turning on more lights)-- yes there will be more noise, but it'll quicken the shutter speed, and a non-blurry pic that's noiser is better than a clean blurry one. . . and you'll learn a little about what you're camera will do under different conditions. Also, you have to really make the effort to hold the cam steady, even with OIS, especially when using slow shutter speeds.
Sep 07, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic Lumix DMC-LZ5 Digital Camera Logo
224 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
