After about an hour the freezer is 26 and the fridge is 64. The Evap Fan isn't running. I cliped the wires, after I unplugged it of course, and wire nutted them together and ran the unit. I measured 12 volts dc between the white and red wire. So I figured it was a bad fan motor. I purchased a new fan and installed it. Unit still not cooling after an hour. I contacted the appliance repair place and he said that it takes a while even though I explained I had the 12 volts dc going to the motor. Now here's my question, there is a yellow and a blue wire also on that motor harness. Could there be something else that the board is looking for to pass another leg of power to that motor?
Because the new one isn't working either. I tested the old one with a nine volt battery. When I hooked the red and the white to the battery I got nothing. But when I twisted the red, blue, yellow together it spun, seemingly slow, but it spun. So that's what brought my question about the other leg from the board. Also I noticed only the bottom 3rd of the evap froze when the compressor ran, so it could be a refrigeration problem too. But it still doesn't explain the problem with the fan.
When the freezer section gets cold and reaches
its required cooling temperature, after that the frost on freezer section
starts defrosting and the cooling fan in the freezer section blows this cool
air from freezer to fridge. But if the defrost cycle does not start then over
ice will get collected on freezer ventilations and that will block the
air passing section from freezer to fridge, so the freezer gets cool but fridge
section does not cool.Its defrost problem. Try
manual defrost by unplugging the refrigerator from main power outlet
for 24 hours then reconnect it and check, if the same problem is noticed again,.
If yes then its defrost board problem. The defrost board located in the back of
fridge section. You can get required parts from www.repairclinic.com or from
online sears part site. ------------- Thank you.
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
