Question about Toshiba Satellite 1805-S274 Notebook
CD Rom drive
Attempts to start when CD inserted but then gives up and stops
  • 2,961 Answers
It may be a problem with your autorun, click the link below and install and run the wizard. If still no luck i'm afraid your drive is failing to read the discs and is faulty, assuming you are having the same trouble with other discs.
Posted on Sep 06, 2007
A while ago, my laptop's DVD drive stopped reading CDs. A after a few attempts , it displays the CD/DVD as an empty one. The CDs are not empty or too scratched because I tried them on a different computer...
Hello there!
Please note that a CD-ROM drive can read and in some cases write to a CD inserted into it. This is done by means of a fragile laser mechanism that scans the surface of the disc as it spins at high speed inside the drive. Drive failure can occure from a scratched laser eye, mechanical failure, overheating, or simply years of use. You will want to ensure the drive is actually broken before buying a new one as replacement or send it for a repair.
Please follow these easy steps:
1. Open the CD drive tray and insert a CD. If you have a tray that opens by pushing a button, push the button. For slot drives, try to slide the CD in. On slot drives, if the CD will not go in fully, the drive is not getting power.
2. Wait and listen for a "whirring" sound from the drive after the CD is in and the drive tray is pushed in. This may take a few seconds.
3. Look at the status light on the front of the drive if one is present. It should be blinking to indicate that the device is reading the CD.
4. Replace the first CD with another one in case the first CD is damaged or unreadable. Repeat steps 1 through 3 with the second CD.
5. Wait to see if anything comes up on the pc screen indicating the CD is being read or run. A notification may appear asking if you want to play the CD or run the software. This indicates a functioning drive.
6. Click on "Start" followed by "My Computer" and locate the CD-ROM drive usually labeled as "D:/" or "E:/". Double click on it. If the CD drive makes no noise or an error message appears on screen indicating the disc can not be read, the drive may be broken.
If an error message appears indicating that the CD-Rom drivers are missing this may indicate a software issue and not a broken drive.
Mar 15, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
Cd-rom in my daughter's laptop has stopped working. i have an identical laptop and swapped out the cd-rom drives but still does not work. I'm trying to download the drivers for the cd-rom drive but can't...
I believe we need drivers for CD ROM if both laptop are of same models. Can you plese insert the faulty CD ROM to your laptop and verify whether it is working or not. If yes, then you'll have take your daughter's laptop to service center. Could be a problem with mother board.
Please come back and give ratings to my solution if this turns to be helpful for you or also if you need more clarification.
Mar 31, 2010 | Computers & Internet
Click on the start menu in the lower left corner of your display.
Click on "My Computer".
A window similar to this one will open and you will see your CD/DVD drive.
If double clicking the drive does not open the CD, right-click the symbol with your mouse and choose "Play" or "Open".
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Sep 16, 2009 | Computers & Internet
My cd rom won't detect blank cds
try re-installing your burning software ( nero-Roxio et,c )
Does it play a standard Music/Audio CD.
if not un-install and re-install the drive.
Are the cables to the drive connected correctly ?
Does the drive support CD+ And CD- media ?
Are the cds definately Blank, any small amount of data written to them, after failed burn attempts will not show the disk as being empty.
Mike @ Compurepair.
Jun 13, 2009 | Dell Computers & Internet
Stiffy drive don't respond and DVD ROM spin but don't read CD
The laser carriage was stucked in one posistion, it works fine after I've manually release it.
Jan 20, 2009 | Fujitsu AMILO M-6500 Notebook
Stiffy drive don't respond and DVD Rom spin but don't read CD.
Try different discs to determine whether it's the disc or the drive. If it's the drive the the lens on drive might be dirty, try cleaning it with proper "Cleaning CD" if that doesn't help the drive it self might be going out (as in the mechanical parts on the drive). In the later case the only solution is buy a new drive.
Dell XPS 1300 Cd rom problem
This is a CD drive mechanical problem. All CD/DVD drives have built in error checking for mechanical failures. When you insert the CD/DVD, it tries to grab and seat the disc, then attempts to spin it up and then read it. If the grab and seat function fails for any reason, the drive will eject the tray so you can try again. You should contact Dell support and get the drive replaced. Has the drive ever worked? or did it just stop working one day?
Nov 02, 2008 | Dell Inspiron 9100 XPS Latitude D400...
Error Message on CD Rom - will not operate
Your CD ROM needs to be cleaned from inside may be it can't read CD because of dust on lens
Nov 06, 2007 | Computers & Internet
Toshiba Satellite 1805-S274 Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
