Question about Symbol P 304PRO Handheld
Scanning problem Hello, I have trouble with a Symbol P304PRO-I100 scanner. It is connected via a SYMBOL USB connection cable. When i try to scan a barcode everything goed ok (i think). The scanners beeps and has a green light, but when i look at the screen, i dont get to see any output from the scanner. I tried it on various PC's etc, but it is not working any more Can you help ? regards, Guppie
Hej Bluegreenash, thanks for your help. Point 1 is ok alle drivers etc are ok as fasr as i can see. The device is also installed correctly. Point 2. I think you are right with this one. I dont have a code book and i think i never got it too...I will try to see if i get it. Regards Guppie73
Posted on Sep 07, 2007
  • 661 Answers
With this problem there are 2 things that I think you need to do. 1. USB devices usually require drivers, it is unlikely that these came with windows, you need to check that your device is correctly installed and any software required to run it is installed. 2. check the configuration of the scanner, (as it will appear to work even if it is configured incorrectly. you should have a code book which you can program all of the options, as the scanner may not even know that it is connected via usb. (all the scanner knows is that it has power)
  • Gareth Cockram
    Gareth Cockram Sep 27, 2007
    manual is here, there is a reset included but no code book, (print page as you cannot barcode scan from screen)
    http://support.symbol.com/support/search...
    AHA!!! found it
Hello I have trouble with laser ls2208 it is PS2 connection but i have only USB on PC so i buy converter ps2 to usb but after connected scanner read product but not send text to pc .
You can try scanning the Keyboard Wedge host type barcode IBM AT Notebook then rebooting your PC. If this does not work you should order a CBA-U01-S07ZAR. This is the USB cable for use with the LS2208. Zebra Technologies support solution ADC-00217 addresses this type of issue. The article was written for connecting to a laptop, but your connection is similar if you do not have a keyboard attached to the cable. This link will take you to the solution which includes the IBM AT Notebook barcode. portal motorolasolutions com Print the article and scan the barcode then reboot your PC.
Dec 11, 2014 | Symbol LS2208 Handheld
I Have a new symbol scanner LS1902T-1000, whose software/Driver got missing, when i tried to read the bar codes, the unit beeps and a green light come on but I do not see any thing in the screen Please...
Hello Sabrina,
it depends much on the connection between the scanner and computer. The good sign is that the scanner is set correctly to scan the barcode. You need also scan the correct barcode for the connection art. Please scan from the Product Reference Guide the Barcode for USB, RS232 or Keyboard Wedge.
The Product Reference Guide is located at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5880807apdf
Oct 22, 2010 | Symbol Cobra LS1902 Handheld
I cant use symbol ls2208ap . how i use it
hello, once you have it connected to your computer via usb, serial or keyboard wedge, you scan the barcodes that come in the user guide to set it up, its pretty much a plug and play. you can find the quick start guide at
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=7188201cpdf&sliceId=&dialogID=165478796&stateId=1%200%20165462678
Let me know if i can be of additional assistance,
Kim Ganoe
800.933.2839 x251
Feb 01, 2010 | Symbol LS2208-7AZK0100S Handheld
Symbol LS 4000-I100 to a PC Help connecting
That depends on your exact model, it could be USB, Keyboard Wedge, or RS-232. In any case, you just plug it in and turn it on.
Oct 15, 2009 | Symbol PN: LS4000-I100 Laser Scanner...
Symbol Scanner LS4071-I1us
transltor and data comparison failed?
Jul 27, 2009 | Symbol LS 4071 Handheld
Symbol HotShot LS2106 sounds like it's scanning, but no display
If you are using a USB to PS/2 converter on the end of the USB cable then it won't work. You will need to get a PS/2 cable made for this scanner. I can supply you with one if you need it.
Jul 03, 2009 | Symbol Hotshot LS2106 Handheld
Symbol HotShot LS2106 sounds like it's scanning, however, no data/information is displayed once scanned. Connecting to Windows XP with a USB converted to PS2 cable. Are there reset bar codes available that...
The LS2106 did not support laptop mode so the PS/2 wedge needs to have a PS/2 keyboard attached to the cable. If that does not work I would suggest trying to find a 25-31617-01 Synapse adapter cable and STI85-0200 USB Synapse cable. This would allow you to connect the scanner right to the USB port and it should work without any extra programming. I believe the cost of the two cables (if you have to purchase them new) is almost as much as a new LS1203 scanner with USB cable. At least with the new scanner you would get a three year warranty.
Need instructions
it depends on the configuration of your host and scanner. Usually there it works like this:
Connect the scanner to USB or per Keyboard Wedge Select the correct language set for your Scanner Try to scan your barcode if this will not work - enable the barcode you need to scan with the programming barcode from Manual
The Barcodes needed to set up the device are listed in the Reference Guide at http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=5093002apdf
Jan 14, 2008 | Symbol LS1902T Handheld
Symbol P 304PRO Handheld Logo
220 people viewed this question
Top Symbol Computers & Internet Experts
George Etukudo
George Etukudo
Norman Al-Anbar
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
