NetGear WirelessN 300 USB Adapter WNA3100 Logo
Anonymous Posted on Aug 18, 2013
Windows 7 get error unable to load suptools.dll
Error 0xc000007b
fix 0xc00007b error "the application was unable to start correctly"
there may be multiple reasons as to why you might receive 0xc00007b error when trying to run an application on a windows machine. 0xc000007b error usually comes from mixing up 32bit environment with 64bit one. For example 32bit application loads a 64bit dll causing 0xc000007b error.
Solution 1
In most cases it's .NET framework causing issues. This can easily fixed by re-installing latest .NET framework from [link]
Solution 2
Re-install the application that you are trying to run. It sounds simple but the application data files could be corrupt or missing. This could be caused by a installation that did not complete successfully or by a virus.
Solution 3
Running the application as an administrator could fix this error. Right click on the program shortcut or program .exe file, then click on Properties, and on the Compatibility tab. Check the Run this program as an administrator box, and click on OK
Solution 4
Restart your computer as some applications require restart after installation to function properly.
Solution 5
Run Windows update as it can provide application fixes and updates. Furthermore it installs missing drivers and updates the outdated ones like graphic card drivers. Windows 7 / 8 / 8.1 users need to search for "windows update". select all important and optional updates and click on the "install updates" button. If you use Windows XP navigate navigate to Windows Update by choosing Start > All Programs > Windows Update. When the scan is complete,Click the Review and Install Updates link. Finally press the "install now" button.
Windows 7 / 8 / 8.1
Windows XP
Solution 6
manually update the application if possible.
Solution 7
re-install Microsoft Visual C++ from [x32 link] or [x64 link]
Solution 8
re-install DirectX [link]
Solution 9
Many times hard disk problems can be repaired using the chkdsk command. If you are using windows 7 press the start button in bottom left corner of your screen. If you are using windows 8 / 8.1 press the windows key .Search for "cmd" and Right click it and select "Run as administrator". Windows XP users Click on start > run. In the Run box, type in "cmd" in the box.
Windows 7:
Windows 8 / 8.1
Windows XP
A CMD window should appear. In that window you can just type it as you see "chkdsk c: /f /r". If you have more then one drive or partition, you will need to tell it the disk (chkdsk d: /f /r).
If it is the primary windows disk c: it will ask you to schedule it for next boot. When you restart, it will do a chkdsk for you before even getting to the login screen.
Solution 10
This solution only works for a 64-bit system. It requires replacing files is system32 directory so be careful. Only attempt this solution if you are confident and if other solutions have failed. When Microsoft Visual C++ Redistributable Package is not properly configured it may cause 0xc00007b error. Firstly download the zip file [link] and decompress it. Reboot in safe mode and go to C:\Windows\System32. copy all files included in the zip package (mfc100.dll, mfc100u.dll, msvcr100.dll, msvcp100.dll and msvcr100_clr0400.dll) to C:\Windows\System32 replacing the current ones. After that reboot in normal mode.
If all the solutions above haven't worked i would consider backing up data and performing a clean install of windows.
Error Failed to load DLL: GameuxInstallHelper when uninstall darsk sector
http://answers.microsoft.com/en-us/windows/forum/windows_7-gaming/error-number-0x80040702-failed-to-load-dll/6c625ae8-4230-4bba-9616-cffc02b611d1
On my windows 7 gateway laptop I am receiving the message "the ordinal 572 could not be located in the dynamic link library iertutil.dll. I ran a cmd scan and did not find anything. Any suggestions?
How To Fix Iertutil.dll Errors
Important: Do not download iertutil.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of iertutil.dll, it's best to obtain it from its original, legitimate source. Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the iertutil.dll error.
  1. Restore iertutil.dll from the Recycle Bin. The easiest possible cause of a "missing" iertutil.dll file is that you've mistakenly deleted it. If you suspect that you've accidentally deleted iertutil.dll but you've already emptied the Recycle Bin, you may be able to recover iertutil.dll with a free file recovery program.
    Important: Recovering a deleted copy of iertutil.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
1670: unable to load module d:\iss setup.dll,error code:193
get current PS update when you turn on system - if the update doesn't automatically load - go to system - system updates - follow instructions on machine.
Msvcrt.dll error message(Msvcrt.dll error message("the procedure entry except handler4 common could not be located dinamic link library msvcrt.dll")
Two possible solutions.
Roll back system with System Restore. Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
3helpful
3answers
How to get wpcap.dll in windows 7 64 bit
To get the dll file go to the link below:
http://www.dll-files.com/wpcap.zip?0VLhSIXEdO
But if you are having wpcap.dll errors and you want just to fix them, Below is the link on how to fix them:
http://www.dll-error-fixes.com/steps-fix-wpcapdll-errors/
2answers
Hello i have a ati radeon 9250 and windows 7 it havent driver for windows 7 therefor i installed driver for windows xp in windows 7 all work good but in shutdown or restart i have blue screen...
The way to fix ATI2DVAG.dll errors is to first restart your PC into "Safe Mode With Networking". This will basically allow your PC to boot up without all the drivers and software which can cause it to crash. To do this, you should first restart your PC and then press F8 continually before Windows loads. After that, you should then select "Safe Mode With Networking" to boot your PC into that mode. When in safe mode, you should download a new version of the ATI Graphics Driver from the Internet, which should fix most of the problems you've been having with it. This can be done by downloading the driver from the ATI website and then re-installing it in Windows.
After updating the driver, try your PC in "normal mode" again to test to see if the problem has been fixed. If you find it hasn't fixed the issue, you should then go back into safe mode an manually replace the ATI2Dvag.dll error on your PC with a fresh copy of the file from the Internet. On top of that, you should also clear out the "registry database" of your PC with a registry cleaner. The registry database is a central storage facility for Windows, which basically keeps all the settings and options that Windows needs to use to run inside. This part of your system is very important and used to load up many different DLL files. To ensure no registry errors are causing problems on your system, you should download a registry cleaner program from the Internet, install it and then let it fix the errors your PC has.
You can fix ATI2Dvag.dll errors on your PC by using the tutorial and tools on our website. You can Click Here to fix ATI2Dvag.dll errors on your PC.
OR
Do not download ati2dvag.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of ati2dvag.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the ati2dvag.dll error.
Restore ati2dvag.dll from the Recycle Bin. The easiest possible cause of a "missing" ati2dvag.dll file is that you've mistakenly deleted it.
If you suspect that you've accidentally deleted ati2dvag.dll but you've already emptied the Recycle Bin, you may be able to recover ati2dvag.dll with a free file recovery program.
Important: Recovering a deleted copy of ati2dvag.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
Run a virus/malware scan of your entire system. Some ati2dvag.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the ati2dvag.dll error you're seeing is related to a hostile program that's masquerading as the file.
Use System Restore to undo recent system changes. If you suspect that the ati2dvag.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
Reinstall the program that uses the ati2dvag.dll file. If the ati2dvag.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
Important: Try your best to complete this step. Reinstalling the program that provides the ati2dvag.dll file, if possible, is a likely solution to this DLL error.
Update the drivers for hardware devices that might be related to ati2dvag.dll. If, for example, you're receiving a "The file ati2dvag.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
Note: The ati2dvag.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
Roll back a driver to a previously installed version if ati2dvag.dll errors began after updating a particular hardware device's driver.
Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the ati2dvag.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The ati2dvag.dll file could be included in one of those updates.
Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause ati2dvag.dll errors as they fail.
If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
Repair your installation of Windows. If the individual ati2dvag.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
Use a free registry cleaner to repair ati2dvag.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid ati2dvag.dll registry entries that might be causing the DLL error.
Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the ati2dvag.dll error, this should be your next course of action.
Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the ati2dvag.dll error using a troubleshooting step prior to this one.
Troubleshoot for a hardware problem if any ati2dvag.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Good luck
If this helps you resolve your problem, please
consider giving me a good rating and a quick
"thanks" or "good job".It will help me as well.
Thank you.
1helpful
3answers
Having upgraded Itunes to Verision 9 I get the following message when I try to sync my iphone. "iTunes was unable to load provider data from Sync Services" I am using Windows 7, any ideas how to fix?
The only way to correct this problem is to uninstall and reinstall Itunes from your system, you will also need to remove some other program, check this link for the steps.
http://support.apple.com/kb/HT1923
2answers
Cant install a printer
HP PSC 1410 All-In-One InkJet Printer installation
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
