Question about Quinn-Curtis Real-Time Graphics VB w/Source (WINVB202)
Problem with meter
I use the real-time graphics Active X Control WIN-AXC-200 Version 1.0 with Visual Basic 5 and Windows NT 4.0. In my software, there is a screen with several meters and several frames. One frame is hidden at the load of the screen. When the user strikes spacebar key, this frame appears or disappears. But if we strike several times on spacebar, the software doesn't react anymore : it seems that the software doesn't receive anymore events about the keyboard. We have to click on a meter and then software works well. This software is installed on several computers but the problem occurs only on few computers. So it seems that there is a problem with the meters and the configuration of the computer. What can I do to solve this problem? Thanks.
  • 3 Answers
Keyboard event are delivered to the component that has "keyboard focus". Looks like somebody is stealing focus from your active x control. It would be the best to find whom and disable it but if not the quickest hack is: 1. set timer in you application say for 100 milliseconds. 2. check if your your active x control has focus (there should be analog of GetFocus in VB). 3. if not - call something similar to Win32.SetFocus with the handle of your control. Let me know if you still have problems.
Posted on Sep 09, 2007
I have a full copy of visual cadd v4, but it wont install on my pc. im running windows vista 32-bit Home Premium
This is due to software compatibilty issues with Vista(x32bit).
Here some options you can try:-
1. You can try installing the software in "safemode" using the "Vista compatibility mode", but no assurance it will work. (FYI - V3.0/4.0 are not longer supported by the developer)
2. Upgrade to a newer version - Visual CADD 5, when patched to the latest 5.0.6 should work just fine with Vista.
Hope it helps.
May 31, 2011 | IMSI Visual CADD 4.0 Full Version for PC
Does CAD KEY 19 work in windows 7 ?
If you run it in Windows 7 in Windows 95/98/00 or NT 4.x compatibility mode then there is no reason why it wouldn't work. To do this;
1. Right-click on the executable (.exe) file and click on 'Properties'
2. Click on the 'Compatibility' tab
3. Check the box next to 'Run this program in compatibility mode for:'
4. Select 'Windows 98/Windows Me', 'Windows 2000' or 'Windows NT 4.0 (Service Pack 5)'
5. Click 'Apply' then 'OK'
6. Double-click the executable (.exe) file to open.
Hope this helps!
Regards,
Matt
Mar 03, 2011 | Cadkey Corp Cadkey 19 Full Version for PC
Cannot import songs from a CD
iTunes.exe has been set to run in compatibility mode for an older version of Windows. For best result, turn off compatibility mode of iTunes before you open it.
> 1. Make sure iTunes isn't running. 2. Click Start, type regedit, then press Enter. 3. Navigate to this Registry location:HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers 4; Its better you clean/repair Windows registry with RegInOut. 4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry. 5. Start iTunes. The offending message should be gone!
Nov 25, 2010 | Apple iTunes
The file "iTunes Library" cannot
Nov 09, 2010 | Apple iTunes
Can't open itunes, says library made with newer version i downloaded songs on iphone. have 10 on itunes
4; Its better you clean/repair Windows registry with Reg In Out.
Oct 18, 2010 | Apple iTunes
I have a PC running Win XP Pro. I have just purchased an iPone4 and am trying to add all my music from my old MP3 player. Itunes imports 200 odd songs justt fine (converting them from ogg to AAC along the...
> 1. Make sure iTunes isn't running. 2. Click Start, type regedit, then press Enter. 3. Navigate to this Registry location:HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers 4; Its better you clean/repair Windows registry with Reg In Out. 4. Look in the main pane for a key that refers to iTunes. If you find one, delete it, then exit the Registry. 5. Start iTunes. The offending message should be gone!
Sep 27, 2010 | Apple iTunes
I can't install a visual basic 6.0. because I've been accidentally deleted the some components of system32. most especially the config.nt
If my memory serves, VB 6 was the last dos/windows version and windows;nt was simply a text file that held some config parameters when it ran in nt mode. I woud suggest you update your software, but if you are unable to do that, you might try reloading nt from diskette or CD. I think NT also supported the undelete command. If it hasn't been very long since you erased it, you may be able to restore it with an undelete. I think that was the command name.
Dec 11, 2009 | Microsoft Windows XP Home Edition
Installing jetflash 2 windowsme
Download and install the following files and try again. The should also work with Windows ME as it is just a dressed up version of Windows 98.
For Windows 95, 98 and NT VBRun60.exe - VBRun60.exe installs Visual Basic 6.0 run-time files.
VBRun60sp5.exe - VBRun60sp5.exe installs Visual Basic 6.0 sp5 run-time files
For Windows 98 only DCOM98.exe - Extends the support for Distributed Component Object Model (DCOM) for Microsoft Windows 98.
Apr 10, 2008 | Computers & Internet
DRIVERS
Try this LINK
The site gives you three choices. I'm pretty sure the latest version (1st choice)will work with XP:
Software Download - PhotoShot for Panasonic Palmcorder Camcorders
Operating System: Windows 98SE/Me, Windows 2000
Date of Release: 02/01/2002 5:00 AM
Software Download - PhotoShot Driver
Operating System: Windows 95/98
Date of Release: 01/01/2000 5:00 AM
Operating System: Windows NT 4.0 and Windows 200
Date of Release: 05/01/2000 4:00 AM
Good luck
Dec 26, 2007 | Panasonic PV-L750 Camcorder
Computers & Internet Logo
77 people viewed this question
Top Quinn-Curtis Computers & Internet Experts
David Payne
David Payne
Are you a Quinn-Curtis Computer and Internet Expert? Answer questions, earn points and help others
