Wont reset some programs will work but some wont when i press 2nd mem the memory doesnt show up so i cant reset it an when i graphed something i need to change the zoom to zoom fit and since this everytime i try to use the graph it says err. wondow frame but it has no goto it just says quit
Instructions 1 Enter the memory options by selecting "Mem." Press the "2nd" key followed by the "+" key. Select "Reset" from the memory choices. Use the arrow key to select and delete all memory.
2 After choosing to delete all memory, select "Reset." After this reset, your screen should show "Mem Cleared." Once you have reached this screen, press "Enter." If you installed programs or applications, you may need to remove them manually. Once again, enter the "Mem" command. 3 Press "2" to select Memory Management. If you are deleting programs, input that option from the subsequent menu choices. If you need to remove applications, input that choice and press "Enter. Select the application or program from the list displayed. Press "Del" to request the deletion. Choose "Yes" to confirm your choice.
4 Repeat this process to delete remaining programs manually. After completing this, exit the memory menu and press the "Apps" button. Make sure no applications remain. Additionally, press the "Prgm" button, and check that all programs have been removed
Hello, Reset the memory of the calculator and draw your graphs again. To reset memory Press [2nd][MEM][3:Reset][2:Reset][ENTER]. Since this procedure resets the screen contrast to default settings, you may have to adjust it. To adjust contrast Press [2nd] key and release it. Press and hold [UpArrow] to darken or [DownArrow] to lighten contrast.
Hello, Press [2nd][MEM][7:Reset][1:All RAM][2:Reset][ENTER]. Resetting RAM will clear old data stored in list, matrices, graphs, stat graphs. If you have precious data, you may choose to press [2nd][MEM][1:ALL] then you scroll down the list and erase individual items. When the Fat Right Arrow points to an item, you press [DEL] to delete it. Be careful not to delete the APPS (have asterisks to show they are archived). Hope it helps.
How do I correct ERR: MEMORY on a TI-83 family or TI-84 Plus family graphing calculator?
An ERR: MEMORY
is given when there is not enough memory to perform the instruction or
function. To increase available memory by deleting the contents of any
variable (real or complex number, list, matrix, Y= variable, program,
Apps, AppVars, picture, graph database, or string), follow these steps.
• Press [2nd] [MEM] to display the MEMORY menu. • Press 2: Mem Mgmt/Del. • Select a variable or data that needs to be deleted and press [ENTER]. •
Use the arrow keys to move the cursor next to the item, and then press
[DEL]. The variable or data should now be deleted from the memory. When
deleting programs or Apps, a message asking for confirmation will
appear. Select 2:Yes to continue. To leave any variable screen without
deleting anything, press [2nd] [MODE]. Notes: With the exemption of programs and Apps, no warning will be given to verify the deletion.Some system variables, such as the last-answer variable Ans and the statistical variable RegEQ, cannot be deleted.
Clear the old contents of variables .
Press [2nd][MEM][2:Mem Mngt/Del][6:Y-Vars][ENTER]. The graph functions that have been defined are listed on screen. Scroll to select the one you want to use and press [DEL].
There is amore radical way to clear the memory:
Press [2nd][MEM][7:Reset] [1:All RAM][2:Reset][ENTER].
Hope it helps.
Hello, Reset the memory to defaults and you will not get the error. [2nd][MEM][7:Reset][Defaults] [2:Reset] [ENTER]. Press [CLEAR] and them [Y=] to enter the function. No need to set Zoom. Defaults work fine for y1= 4X+3. Press [GRAPH]. Hope it helps
[2:Reset] [ENTER]. Press [CLEAR] and them [Y=] to enter the function. Press [GRAPH] when finished entering function. Hope it helps
if i hit 2nd MEM absolutely nothing happens
