I want to install an aftermarket stereo in my 1996 Kia Sportage. The wires are differently colored than the cars factory wire color! I need to know which wire goes to what!
Dont know if you tried this already but go to a car audio store and ask for an adapter the plugs into your stereo and then it plugs into the factory wiring harness. its easier and cleaner and less stressfull. if you done so write back and Ill see if I can send you a pick or something.
read (you meant main harness to radio sub harness.)
and car may have 5 or more harness for 5 or more very complex radio head end options new,so only the real service manual covers all that for sure,or if lucky 2nd fiddle here.
Car Radio Battery Constant 12v+ Wire: Green
Car Radio Accessory Switched 12v+ Wire: Green/Orange
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Under the Driver Seat.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Tweeter Speaker Positive Wire (+): Blue
Left Front Tweeter Speaker Negative Wire (-): Brown/Red
Left Front Mid Speaker Positive Wire (+): Black
Left Front Mid Speaker Negative Wire (-): White
Left Front Low Speaker Positive Wire (+): Yellow
Left Front Low Speaker Negative Wire (-): Blue
Right Front Tweeter Speaker Positive Wire (+): Blue/Orange
Right Front Tweeter Speaker Negative Wire (-): Green/Orange
Right Front Mid Speaker Positive Wire (+): Black
Right Front Mid Speaker Negative Wire (-): Brown/Red
Right Front Low Speaker Positive Wire (+): Black
Right Front Low Speaker Negative Wire (-): White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Blue
Left Rear Speaker Negative Wire (-): Green
Right Rear Speaker Positive Wire (+): Yellow
Right Rear Speaker Negative Wire (-): Blue
Go by a stereo shop and get an adapter for your car. It connects all of the correct wires to the aftermarket radio without damaging or removing wires from old connector.
does this model have the built in amp? brownred may be the clock. do you know what each of the wires on the stereo controls? if you know this i can help you.
either way give me a list of the colors you dont know
every vehicle is different. If you get a radio harness (just plugs into the factory plug) from an automotive store the colours will correspond to the aftermarket stereo unit
1996 Eagle Vision Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Black/Yellow Car Radio Accessory Switched 12v+ Wire: Red/White Car Radio Ground Wire: Black/Light Blue Car Radio Illumination Wire: Orange Car Stereo Dimmer Wire: Pink Car Stereo Antenna Trigger Wire: Orange/Red Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 3 1/2′ Car Audio Front Speakers Location: Dash Left Front Speaker Positive Wire (+): Dark Green Left Front Speaker Negative Wire (-): Brown/Red Right Front Speaker Positive Wire (+): Purple Right Front Speaker Negative Wire (-): Dark Blue/Red Car Audio Rear Speakers Size: 6′ x 9′ Car Audio Rear Speakers Location: Rear Deck Left Rear Speaker Positive Wire (+): Brown/Yellow Left Rear Speaker Negative Wire (-): Brown/Light Blue Right Rear Speaker Positive Wire (+): Dark Blue/White Right Rear Speaker Negative Wire (-): Dark Blue/Orange
