I shorted out the battery when i was hoking it back up and now i dont have any power what so ever, when i turn the key or try to turn the radio on or lights, nothing works, im looking for a master fuse or something that would of burnt out or something in that nature that would be cousing loss of power.
You do have about half dozon fusable links that may have fried or battery maybe bad. check first master fuse is usually under the hood (if you havent looked already) on the passanger fender next to headlamp or firewall for the main fuses. take a test lamp if you have one and turn key on and see if there power on both posts if power is available one side only then pull that fuse and check to see if it blown
you do have about half dozon fusable links that may have fried or battery maybe bad. check first master fuse is usually under the hood (if you havent looked already) on the passanger fender next to headlamp or firewall for the main fuses. take a test lamp if you have one and turn key on and see if there power on both posts if power is available one side only then pull that fuse and check to see if it blown
