Question about Konica Minolta DiMAGE G530 Digital Camera
Sd card i have emptied my memory card and transfered the photos into my iphoto. i have pictures stored on my sd card. i would like to transfer those to my iphoto as well but my iphoto is saying the camera is empty. how do i get the photos stored on the sd card into my iphoto or to have prints made?
    President:
  • 2,961 Answers
When you camera is connected, go to my computer and you should find it listed under other devices, you should then be able to explore the camera folders in which sould be your sd card folder, copy and paste them.
Posted on Sep 06, 2007
SOURCE:
How do I transfer pictures from the internal storage to a sd card?
hi rednpat986.
this is all i could find,if this does not work go to the link at the bottom.
How to transfer photos from camera internal memory to SD card? Follow these steps:
  1. Insert a memory card into your camera.
  2. Turn on your camera.
  3. On the camera, press the Review button then the Menu button.
  4. On the Setup tab in the menu (your menu tabs might be named differently), select Image Storage.
  5. Select Internal Memory.
More items...
Transfer pictures from internal memory to a card - Kodak Support
camera How do transfer pictures from the internal storage to sd card...
Nov 05, 2017 | Cameras
Trying to transfer photos to computor, hit transfer and it comes up Failed to initialize pluto. Don't know what to do.
You didn't say what software you are using, but there are better ways to download your photos. The best way is to connect your SD flash memory card to the computer. If your computer has a SD card slot you are in luck. If not, you can buy a USB SD reader for under $20 on line or in any computer store.
To use it, remove the SD card from your camera and insert it in the reader. Your computer will automatically recognize the SD card as an external memory device; exactly as it does with an external hard drive. You can then open the SD card and access the folder with your pictures. All you need to do is copy and paste your photos from the SD card to a new folder on your computer. It's that simple. Almost all professional photographers use this method and do not transfer pictures from the camera with the SD card in the camera.
Aug 17, 2015 | Nikon D5100 Digital Camera
How to put photos on my sd card
This more than likely means your internal storage is low and not the SD card and may not have anything to do with your pictures but more so with your apps. Go into settings and see if your tablet has the feature to set where your downloads and other media is stored, by default that will be your internal memory. change it to SD card or USB storage. In Settings you can also click on your apps individually and transfer them manually one by one to the SD card or USB storage or download a file manager and do so all at once. Some apps and files may not have the feature to transfer these apps the tablet came with or apps you downloaded that uses the internal memory. By default if a memory card is in you tablet pictures are automatically store there, if this is not the case the easiest way to transfer is connecting the tablet to a computer/laptop and transfer to the card or again use a file manager.
Aug 15, 2014 | Acer Iconia Tablet with 8GB Memory - Steel...
Memory card locked
SD and Micro SD memory cards SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts. ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Oct 19, 2012 | Nikon D3000 Digital Camera
Kodak Z740 all of a sudden wont import jpeg images to iphoto. Camera communicates with iphoto and will show photo info, but then an error code says it cant read the format and lists jpeg. I know its a...
An external reader is the best solution. It will transfer the images way faster than using a cable connected to the camera. See if there is a setup option in your camera that chooses the SD card only for storing photos. If there is, then select it.
Apr 15, 2017 | Kodak EasyShare Z740 Digital Camera
I am using Nikon Transfer on my Macbook Air with my Nikon D3100. The software on teh PC says, 151 photos selected and transfer successful however i cannot see any of the photos in the provided default...
Pictures are normally stored in:
~\Pictures
Option 1:
Nikon Transfer stores the pictures in a user selected folder. To fine it, look: http://support.nikonusa.com/app/answers/detail/a_id/266/kw/Nikon%20Transfer
Option 2:
1. Remove Nikon Transfer 2. Have iPhoto import the images into the iPhoto library (~\Pictures)
Jun 27, 2011 | Nikon D3100 Digital Camera
I use a mac. Have all pictures stored on iphone and would love to know how to get the photos to my photo frame. Not sure how to get pictures from iphoto to a memory card or whatever it is I need to do.
Use iPhoto to get the images off your iPhone and onto your Mac, then export you selected images to a media format the photo frame support.
Now without knowing the requirements of the photo frame but going to guess it accepts and USB thumb drive. Once you have imported your images into iPhoto from your iPhone, plug in the USB thumb drive to your Mac. In iPhoto, select the images you wish to move to your photo frame ( either select an album or individual images). Then go to the File Menu and pull down to Export and save the images to your Thumb drive. For best results for image quality on the photo frame you will want to match the export size with the native resolution of the photo frame.
Apr 24, 2011 | Office Equipment & Supplies
How do I transfer photos from my computer specifically iphoto to my phone sd card of my T715A, please.
Hi,its not posssible for you to transfer files from your iphoto directly to your phone sd card,iphoto files are only compatible with the iphone,however,you can try moving the pictures from your iphoto into another folder on your computer before sending to your phone sd card.
Take care
Mar 04, 2010 | Sony Cell Phones
Transfer pictures from camera memory to photo card
There ain't no internal memory in that piece of Junk S3500, just put one in the bin, that crap did want to power up.
Jan 29, 2008 | Fuji FinePix S3500 Digital Camera
Konica Minolta DiMAGE G530 Digital Camera Logo
122 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Ekse
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
