FixYa.com
Tags:
GPS Devices
Generic problem for all GPS Devices
Nokia 95 (by 9 users)
posted by kevkev on Sep 06, 2007
HOW DO YOU SWITCH IT ON!
Feel stupid but doesn't seem to be working
Many thanks
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
8 Other Users Have The Same Problem
Comment by sjnj, posted on Jun 15, 2008
I just put batties in and it will not turn on
Comment by Guest, posted on Apr 25, 2008
I opened the new GPS turned it on set up satilite entered my address. I was called to eat. when I came back and tryed to turn it on it would not turn on. Itis in my car charging right now.
Comment by Guest, posted on Apr 22, 2008
my system is from japan how do i use it i have inserted road explorer 2.5 thanks
Comment by Guest, posted on Jan 01, 2008
no power
Comment by yachtperth, posted on Dec 29, 2007
Owned for two years display comes on, yet does not respond when pushing any buttons. cannot turn off. must charge up to get going then same problem reoccurs
Best Solution
posted on Sep 06, 2007
Helpful (85)
TomShpak
Rank:Guru Guru
Rating: 86%, 105 votes
I hope this will help you out and I hope you mean Nokia N95
http://www.nokiausa.com/A4410970
Enjoy
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 18, 2008
Helpful (85)
rb57
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
There is a very small power switch on the bottom right of the NV-U70 Sony GPS. I couldn't find it at first either, and I felt the same way. The documentation doesn't do a good job of pointing a user to this, and it's not at all obvious. Hope this helps!
This Problem Also Relates To: Cobra (GPSM2500) GPS Receiver Furuno NavNet vx2 1920C GPS Receiver Furuno GP1650DF GPS Receiver Furuno 1715 LCD Radar System w/ 2.2kW Dome Antenna by GPS Receiver Garmin GPSMAP 60 GPS Receiver Garmin GPSMAP 76CS GPS Receiver Garmin GPSMAP 492 GPS Receiver
Can you Help with these GPS Devices problems?
GPS Devices
I just bought an older
I just bought an older garmin... Answer This...
GPS Devices
Although the Navman is plugged
Although the Navman is plugged... Answer This...
GPS Devices
Messages says GPS is off.
Messages says GPS is off. It... Answer This...
GPS Devices
Garmin 360 will no longer
Garmin 360 will no longer show... Answer This...
GPS Devices
My GPS will no longer
My GPS will no longer take me... Answer This...
8 Other Users Have The Same Problem - Continued
Comment by jonluc518, posted on Dec 24, 2007
Where is the reset button on this device?
Comment by mrbbag, posted on Nov 23, 2007
hard to turn on
the switch on the side is very hard to press
my 2nd fault is i have to press the reset button for it to locate the gps signal if i want to use it again for a 2nd time
can you also tell me if i can fit a speaker to replace the bluetooth head set
Comment by Guest, posted on Nov 03, 2007
screen shows laptop icon navman with x on screen
Repair Service
Find GPS Device Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
