Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
I need a system to see the network
I have just finished reinstalling Windows XP on a system which was formerly on network. Afterwards,the system didnt see network,I couldnt find the CD that came with the system on which all the drivers are contained. What option do i have to get the necessary drivers for the system hoping its a driver problem.I have the network cable connected already but the light signal doesnt come up.
  • 2,961 Answers
Re: I need a system to see the network
You may need to check all the pc are on the same network eg mshome or workgroup, and then you need to find the network card make to download the driver, as windows wont have it on, then use the network wizard to set up networking.
Posted on Sep 06, 2007
0 characters
3 Points
I got problem with formating pc xp ..after a push F8 to agree licens ..format stop runin and show me that " searchin for previous microsoft windows " i need to solve this problem what i need...
Your HDD is maybe damaged and you won't be abble to install a new os on it .
Otherwise , if you really can't format it , try extracting it from your desktop and connecting it to a healthy computer .
Reinstall it back in your desktop afterwards and launch the W XP install disc .
Regards .
Jan 24, 2011 | Microsoft Windows XP Home Edition English...
I want window vista BUT I DONT KNOW HOW CAN I DO THIS
Hi there !
So tell me, what do you want to do with your computer? Do your computer crash and need to reinstall your Windows Vista operating system? Or you want to upgrade your operating system from Windows XP to Windows Vista.
For reinstalling Windows Vista, is it the same procedure when reinstalling Windows XP and Windows 7. Here is the link on how to reinstall operating system For Windows Vista, here is the procedure on how to reinstall Windows Vista.
1. Just put the installer CD into the CDROM Drive and open your computer
2. If message appear to press any key to boot from CD. Press any key to go to Windows Set up.
3. From there, just follow the installation procedure and put CD key if prompted and it will install itself the whole process. It will reboot for 3 times and don't press anykey when this happen. it will be finished within 20 mins.
For upgrading from Windows XP to Windows Vista, remember that all your files and softwares will be remove except for the hardware drivers. But not all the hardware drivers will be 100% working because upgrading the operating system will make your drivers outdated or not compatible with Windows Vista. If some drivers not working, just install the hardware drivers compatible with Windows Vista.
Here is the procedure.
1. Do not put the Windows Vista installer CD yet into the CDROM drive.
2. Open your computer and let it run to Windows XP program until is is finished to load your Windows settings.
3. Now insert your Windows Vista installer CD to the CDROM drive, it will pop up the upgrade installation wizard and just choose the upgrade installation. It will run the upgrading installation and just follow the instruction and it will be finish with 20 mins.
I hope this will help you and thank you for using FixYa !
Jan 07, 2011 | Operating Systems
How to download a free microsoft windows xp professional in the online? and i am having original cd of microsoft windows xp professional while installing operating system it showing their is an error in...
We wish you a Happy New Year.
If you have the original CD use it,it's genuine windows. But what you get online is pirated.
Reinstall Windows XPTo reinstall Windows XP, try either of the following methods. If the first method does not work, try the second.
Note You may want to disconnect from the Internet during the installation. This helps protect you from malicious users. Method 1: Start the reinstallation from Windows XPTo reinstall Windows XP by using Windows XP CD, follow these steps:
  1. Start your computer.
  2. Insert the Windows XP CD in your computer's CD drive or DVD drive.
  3. On the Welcome to Windows XP page, click Install Windows XP.
  4. On the Welcome to Windows Setup page, click Upgrade (Recommended) in theInstallation Type box (if it is not already selected), and then click Next.
  5. On the License Agreement page, click I accept this agreement, and then click Next.
  6. On the Your Product Key page, type the 25-character product key in the Product keyboxes, and then click Next.
  7. On the Get Updated Setup Files page, select the option that you want, and then click Next.
  8. Follow the instructions that appear on the screen to reinstall Windows XP.
If you successfully completed the reinstallation, congratulations. You are almost done. Please continue to the "After you reinstall Windows XP" section to finish.
If you received an error or if the reinstallation did not finish, try method 2. Method 2: Repair install of Windows XP by starting your computer from the Windows XP CDNote If Windows XP was preinstalled on your computer, you may need the installation CD to reinstall. Contact your computer manufacturer to make sure that you have the installation CD for a repair installation.
To reinstall Windows XP by starting your computer from the Windows XP CD, follow these steps:
  1. Insert the Windows XP CD into your computer's CD drive or DVD drive, and then restart your computer.
  2. When you receive the "Press any key to boot from CD" message on the screen, press a key to start your computer from the Windows XP CD.
  3. The following message on the Welcome to Setup screen will appear: This portion of the Setup program prepares Microsoft Windows XP to run on your computer: To setup Windows XP now, press ENTER. To repair a Windows XP installation by using Recovery Console, press R. To quit Setup without installing Windows XP, press F3.
  4. Press ENTER to set up Windows XP.
  5. On the Windows XP Licensing Agreement screen, press F8 to agree to the license agreement.
  6. Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
  7. Follow the instructions that appear on the screen to reinstall Windows XP. After you repair Windows XP, you may have to reactivate your copy of Windows XP. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 310064 How to troubleshoot Windows XP Setup problems when you upgrade from Windows 98 or Windows Millennium Edition
Hope this helps. Post back if you are facing any other problems pertaining to this. Cheers!!
Jan 02, 2011 | Microsoft Windows XP Professional
How to reformat a computer?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing F1 button.. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Hope this helps
Jul 19, 2010 | Microsoft Windows XP Professional
Standby Inactive
This is usually because your OS didn't recognized your monitor drivers.
Jun 15, 2009 | Microsoft Windows XP Professional
Media player ,system restore, help and support not working
( first remove it and then reinstall it again )
kindly follow the below procedure
click > Start > settings > control panel > Add Remove Programs > Add/ Remove Windows Components > Windows Media Player .
" kindly (Untick) and Click > (Next) > ( Finish)
so that Windows Media Player is removed . "
Now to load back fresh Windows Media Player.
kindly do same procedure to reach there as mentioned below.
kindly (tick) mark the Windows media player and click > ( Next ) > ( Finish)
Jan 11, 2009 | Operating Systems
Help & support feature
Some viruses stop this function. Try running your antivirus then reinstall if necessary afterwards.It will give you the option  of fixing the existing windows which will save your files and settings.
Dec 10, 2008 | Microsoft Windows XP Professional
XP Pro can't logon
try going to safe mode first,restart pc,press f8,go to safe mode..choose administrator..if that didnt work,install your windows xp,post a reply if that didnt work so i can tech you how to install your xp
Jun 27, 2008 | Microsoft Windows XP Professional With...
Networking window xp to win98
Just run the Network Setup Wizard and set it as you want when it finish run this wizard using your Windows XP CD on Win98 make the setup same. But remember please provide detailed information for a Right solution.
May 12, 2008 | Microsoft Windows XP Professional
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
48 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Scott Fryer
Alex Krenvalk
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
