Question about Dell 1600n All-In-One Laser Printer
Copying When copying one sheet, the printer always feeds a second blank sheet through. This slows the process down when copying multiple sheets. If I ask for 50 copies, 100 sheets will go through my printer
  • 161 Answers
It seems to me that the tray sizes are not programmed correctly. A4 size is european and and slightly longer than letter size. If programmed to A4, the unit will behave as you described.
Posted on Sep 25, 2007
SOURCE:
HP 2300 jams when duplexing multiple pages.
try to replace the pickup roller and sepration pad (if ther are old)
Mar 12, 2010 | HP Office Equipment & Supplies
Sheet feed won't work
When you reinstall the blue plastic piece underneath, the white plastic sheet that closes over the glass must hang over the blue plastic piece, not tuck under it.
Mar 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
How do i make double sided copies for my HP 2840
When you call up your printer (usually [Ctl][P]) tell it to print even numbered pages only, but in reverse order, This means the last page to be printed will be page 2, and it will be face down on the top of the pile (blank side showing) Take the printed sheets and rotate them so the top (head) of the sheet is feeding back into the machine, with the blank sides up. Now call your print up again and tell it to print the odd pages only. The first sheet to be printed will be page 1 which will print on the blank side of page 2, and all the rest will follow in sequence, with the correct sides up. Works every time. The print control is part of the Windows system, so your application should provide the full functionality.
Dec 18, 2008 | HP LaserJet 2840 All-In-One Printer
Always feeds a second sheet
You may need to repalce your pick-up roller and your stop roller
Mar 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
Dell 1600n All-In-One Laser Printer Logo
62 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
