Question about Ovens
SMEG SA708X Oven Heater problem
When the oven door is opened the heater indicator light and rear element come on if the rear element is selected irrepective of thermostat setting. When the door is closed everything works normally. The pilot light and thermostat control also works normally for all other elements with the door open. Any ideas?
  • Anonymous Mar 23, 2014
    I've run the pyrolitic cycle on my SMEG oven. Several hours after it has finished the interlock device will not disengage. The oven door will not open and no function can be selected
  • 625 Answers
Thermostat must be getting a blast of cold air from the door being opened.
Posted on Sep 06, 2007
I have a Smeg Wall Oven Model No SA710X-5. When I turn the cooking selection switch to the desired cooking setting the green light comes on. But when I turn the thermostat switch to the desired temperature...
It sounds like the element is missing one side of the 240v power. One side may always be hot while other side is controlled. A qualified repairman can Start at the element and work backwards. Trace wiring back looking for burned wire, bad connections and connectors, all the way back to thermostat. Check thermostat for continuity (with power off), replace thermostat if necessary.
Oct 29, 2013 | Smeg Ovens
Model SA392EB
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Feb 15, 2013 | Smeg Ovens
Fixed fan element, but can't remember how to put it back together again
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jun 22, 2012 | Smeg Ovens
Fitting heat element sa410x
Feb 11, 2012 | Smeg Ovens
Opening oven door trips rcd when up to temp. doesnt do it when cold
Nov 22, 2011 | Smeg SE290X Stainless Steel Electric...
SMEG SA708X oven's symbols have rubbed off, wioul appreciate a photo of the left hand (have only managed to find the dial template for teh right side dial)
Here's a picture of the panel... BTW does anyone know the wiring / have a wiring diagram for the door switch as mine was swapped around by an oven guy just to get it running but now I have a new switch and can't remember how it all goes!!
Feb 26, 2010 | Smeg S1100MFX5 Electric Single Oven
SMEG SA410X-S heat not coming on for fan forced cooking. The fan and light work, and the heat works fine for grilling.
The fan element (round) is more than likely blown. Open the oven door, take the rear cover off inside the oven (covers the element) and have a look at the element with a torch. If it is buckled, warped or has a blow hole in it, then it's faulty.
Mar 18, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven ss336-5 not heating
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Jan 21, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Smeg electric oven
your neighbour is probably right. fan should work but if the element has disintegrated, bits of the element could be jamming the fan. take the rear panel off inside the oven and check
Jun 01, 2007 | Smeg SE399X/5 Stainless Steel Electric...
Smeg single fan oven
You are right, it could be a thermostat or a heater problem. You should check that the heater element receive power. In case it receive power,the heater element should be replaced. In case it doesn't receive power, the problem is with the thermostat. In any case, check as well that all wires connected to the thermostat and the heater are in place. Good luck.
May 02, 2006 | Smeg SE250XUK Stainless Steel Electric...
Ovens Logo
442 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
