Our washing machine is not adding the fabric softener from the special additives draw (middle draw). After the load has finished the fabric softener is still in the draw diluted with water. i have removed the draw and cleaned it , but can't figure out how it is released from the draw.
-   I replaced the bushing and outter tub on my Maytag Washing Machine. Maytag model #MAH3000AWW serial #25128831UH. I replaced this bushing because of a loud squeal. My repair did remove the loud squeal. I put the machine completely back together. The machine seems to pause a very long time between revolutions. Is this possible? Could I have knocked a wire off its terminal?-   sarjoe
The detergent dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next test !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Was this helpful?
Yes
No
Solution #2
posted on Dec 25, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
water will not shutoff at the end of fill cycle. shutoff valve has been replaced.
top load washing machine maytag the agitator is loose it slides up during wash and want pull clothes down you can pull it off is there a clip or something that holds it down.
I have an over year old Kenmore front load washer (HE2PLUS) thats leaking out the front door......
(More)
I have an over year old Kenmore front load washer (HE2PLUS) thats leaking out the front door... Pleasehelp... Carlos........
FTF2140ES0 Does not spin clothes. It will do the load adjust but then just finishes its cycle as if...
(More)
FTF2140ES0 Does not spin clothes. It will do the load adjust but then just finishes its cycle as if completed spin cycle. There is no error beep as i got once when my drain line froze. Drain is not plugged (I disconnected it and is draining into bucket).
