Question about Dell 1703FPt 17" TFT LCD Flat Panel Monitor
Dell 1703 FPi 17" TFT LCD Flat Panel
This panel is dead no sign of power.How to open the back cover?
  • pnmethi Jun 24, 2008
    power on led is on permanently. no display. on/off button while pressed does not go off.
My wife bought me a new monitor and I used the information above to take the old one appart. The new one works great and after taking the old one appart and testing everything with my multi tester, I saved a few parts and threw the rest in the scrap pile.
Posted on Jan 30, 2008
    Problem Solver:
  • 7 Answers
You have snap frame around the screen itself use flat screw driver fine edge, theres about four locations that snap into slots work them away and remove frame, then remove screws on back will seperate ,you will have to remove monitor button panel board to, once inside, four screws around screen itself once in side,this will lead you to power connection inside main screen frame, the board and the connections
Posted on Sep 07, 2007
SOURCE:
Dell E177FPv, 17" TFT LCD Flat Panel Monitor will
I think you might have the same problem I did with my E178FPb. I made a video on how I fixed it.
Apr 04, 2011 | Dell E177FP LCD Monitor
Dell E172FPt 17" TFT LCD Flat Panel Monitor powers
It will need parts or board repalcement.
Board is only $30, http://www.lcdrepair.us/e172fpt-inverter-power.html
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Replacement board: http://www.lcdrepair.us
Jan 17, 2011 | Dell E172FPt 17" TFT LCD Flat Panel...
It is only a monitor?
Hi
Yes 1703FPs 17" TFT LCD Flat Panel Monitor it is only a monitor
In case I had help you pls vote me
Nov 06, 2010 | Dell 1703FPs 17" TFT LCD Flat Panel...
My dell 1703 monitor showing green color . what should i do
Do a factory reset on ALL Settings.
http://support.dell.com/support/edocs/monitors/E173FP/En/controls.htm
Dec 15, 2009 | Dell 1703FPt 17" TFT LCD Flat Panel...
Resolution
1280 x 1024 resolution
800:1 contrast ratio
Thanks for posting and please rate
Sean
Mar 30, 2009 | Dell 1703FPs 17" TFT LCD Flat Panel...
Dell E173FPc 17" TFT when turned on goes black
Hi Gaz,
First, verify the monitor is functional.
Monitor STFC (Self Test Feature Check)
Turn off the monitor
Plug the monitor power cord directly into the wall socket to remove any surge protectors or APCs from the troubleshooting equation
Unplug the monitor video cable from the back of the computer
Turn on the monitor
The floating dialog box should appear on screen against a black background.
If the issue appears during the STFC, the monitor is defective. What are the results please?
Jan 22, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell 1704FPTt 17" TFT LCD Flat
I used to repair LCD monitor from Dell. There are 4 screws for rear panel and no screw for front frame. If there is no visible screw, you have to look for "capped" screw holes (little covers that fit flush with the case to hide the screws). If you don't see these neither, this must be a tension fit case. So, face the screen up and look for "rectangular hole" on the side edge (usually at the bottom edge of the screen). This will be a challenge to open without breaking it. You'll need a very thin flat screw driver and wedge it into that narrow rectangular hole. You can use any prybar if you don't have screw driver. It is not too deep. You may stab something important inside and pry it. Once it starts to spread, start sliding it along the seem and you should feel the tension tabs start "popping" open. Continue to work your way around until it's off. Hope this will help you to get the rear panel off. If there is anything I can help you with, feel free to let me know.
Thank you,
Mar 02, 2008 | Dell 1704FPTt 17" TFT LCD Flat Panel...
First there is a seprate snap frame around screen itself, there about four location on snap frame , 2 on each side ,use flat screw driver to seperate frame, there in slots like,there might be 2 on the top also,then go for screws in back, remove button panel from front side and remove flat wire connections to the board ,they pull out of slot on board , be careful putting them back in ,take your time they will go back in by pushing on the stiff part,about a 1/8 or so from the end to go in. of the connection,go for the VGA connection ,you will remve screws to seperate screen it self to get to the connection, it just pulls out of the socket on the board,hope this helps
Sep 08, 2007 | Dell UltraSharp 1703FP Flat panel TFT 17"...
Dell 1703FPt 17" TFT LCD Flat Panel Monitor Logo
854 people viewed this question
Ekse
Clive
Clive
