Question about Motorola Mobility RAZR V3
Motorola error message
Im trying to open 2 browser messages but when i select "go to" i get 403 error message. Ive never put any lock code in. the one thing i did was one time in the game bejewled i went to multiplayer and put in a user name and e mail address and played oline. plz help!!!
    Brigadier General:
  • 7,752 Answers
Do a master reset and then try it again
Posted on Feb 22, 2008
SOURCE:
Tip
How To Enter Unlock Code Into Motorola Mobile Phones Step By Step Instruction...
Model: All Motorola; check below for exception
1. Insert an unauthorized Sim Card and turn ON your phone
2. "Enter Subsidy Code" box appear
3. Enter Unlock Code
WARNING: If one of these messages appears:
- "Contact Service Provider"
- "Tamper Alter"
- "Wait before enter special Code"
- "Contact Service"
It's because you or somebody already enter too many wrong codes, you just have to let the phone ON at these errors message (do not close the phone if V3) and after 40 minutes to 12 hours, the message " Enter Subsidy Code" will appear again.
Model: A1000 and other A series model
1. Click on the Phone icon
2. Enter **057*
3. "Locking Enter Personalization" box appear
4. Enter Unlock Code
5. Press Ok
Model: L6i & L7i (NOT L6 and L7)
1. Press and hold * key and enter 787090
2. "Menu Network" box will appear
3. Select Yes
4. Press OK
5. Will ask for code
6. Enter Unlock Code
Model: All Motorola 3G network model
1. Enter **057*
2. Enter Unlock Code
Motorola CDMA & TDMA
1. Enter 74663# [Menu] [Menu] and you will be asked for a Subsidy Code
Unlock Motorola CLIQ (SIM Unlock) 1. Reboot your Motorola CLIQ with an unaccepted SIM card in.
*If the display reads "Enter Special Code", enter the unlock code and press "OK"
*If the display does not read "Enter Special code":
2. Press and hold the * key until an entry box is displayed.
3. Type *, #, 3, 2, # and press "OK"
4. Enter your Motorola CLIQ's unlock code and press "OK."
5. Your Motorola CLIQ should now display either "Completed" or "Deleted"
Motorola MPX
2. If the phone is asking for NETWORK PIN
3. Enter the NETWORK PIN
4. If the phone is asking for SERVICE PROVIDER PIN
5. Enter the SERVICE PROVIDER PIN
6. Your phone is now unlocked
Network PUK
If the phone is asking for NETWORK PUK: Power on the phone with the original Sim Card in and wait till phone is fully powered on and you have access to menu. Enter *#**364# and press green button. You will get an error message and thereafter, you will see an Engineering Menu:
1. Select Options
2. Select GSM Test
3. Select Send AT command
4. Now you will see a new window Saying "Send AT Command"
5. Enter AT+CLCK="PN",0,"[SERVICE PROVIDER PIN or NETWORK PIN]"
6. Press send
If you get Response "0 []" phone is unlocked. If you get 1 error, then make sure you have typed the code correct and try the other code. Turn your phone off, take battery out. Put battery back in. Power on the phone and leave it for 40 minutes to 12 hours until the message "Enter NETWORK PUK" is gone. Now enter the Unlock Code and 00000000 (eight zero's) as a new password
Service Provider PUK
If the phone is asking for SERVICE PROVIDER PUK: Power on the phone with the original Sim Card in and wait till phone is fully powered on and you have access to menu. Enter *#**364# and press green button. You will get an error message and thereafter, you will see a Engineering Menu: 1. Select Options
2. Select GSM Test
6. Press send
If you get Response "0 []" phone is unlocked. If you get 1 error, then make sure you have typed the code correct and try the other code. If you do not have the original Sim Card or if the original Sim Card is not accepted because you flashed the phone with other firmware, then we cannot help you
You can get the unlock code through online..........give your IMEI number and get the unlock code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
on Apr 07, 2011 | Cell Phones
MY RAZR V3 IS ASKING FOR SUBSIDY PASSWORD
If one of theses messages appear :
- "Tampert Alter"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola RAZR V3 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
You can get the Subsidy code from the site
Wickedunlock.com/motorola-razr-v3/rs11wp9/ and Unlock Motorola Razr V3 phone from network lock.
Jul 13, 2012 | Motorola Mobility RAZR V3
I want to unlock my motorola i856, what is the procedure
You can Unlock it simply using the Unlock code,You can get the Unlock code from the site
www.mobile-unlocker.com
and Follow the instructions and unlock it step by step.
Motorola I856 Select your current network to see a list of available unlocking services noimage.gif Network Provider Select your Current Service Provider
Motorola I856 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Motorola I856 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola I856 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola I856 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola I856 is locked to.
WARNING: If one of theses messages appear :
- "Tampert Alter"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola I856 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Oct 22, 2011 | Cell Phones
Error code=403, system error code=10060. This is the message tally client displays. Tally server running successfully. Pls help. thanks
Sep 14, 2010 | Computers & Internet
Cannot access a site although have put in browser, to acitvate it, have been having error page 403, gone into browser but still will not allow access to stite requested.
HTTP Error 403 is an error message which means that you are not authorized to view the web page which you are attempting to load. Usually, the HTTP error 403 - Forbidden means that access to the file/folder you are trying to open has been denied, either on intention or owing to a configuration anomaly. You could attempt using a proxy website if the access is blocked intentionally.
May 29, 2010 | Microsoft Internet Explorer 8
I am unable to access my e-mail. Error message
write to the provider and communicate the error code...at least for yahoo I managed to unlock in this way some mail addresses
but in theory it ok for all mail servers ///
Oct 07, 2009 | Computers & Internet
How to unlock a http error 403
Hi, HTTP Error 403 is an error message which means that you are not authorized to view the web page which you are attempting to load.
The 403 error is also known as "Forbidden". The 403 Forbidden error is most often seen when you are attempting to browse to a directory which has directory browsing permissions turned off. The actual error message you receive will depend upon your web browser. For example, Internet Explorer says "You are not authorized to view this page."
Follow these steps if you get this error:- 1.Make sure the URL is entered correctly 2.Try the URL with a different file extension (.html, .htm, .shtml, .php) 3.Go to the main page of the site and look for a search function 4.Go to Google and search for a similar page
Oct 02, 2009 | Dell OptiPlex™ GX270 PC Desktop
Get a 403 error message
Hi,I am hosting with this http://www.tucktail.com/ site,still now there is no problem for me,you too also try this one,All the best.
Jun 17, 2009 | Twitter Tweets
Motorola Mobility RAZR V3 Logo
141 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
