Kyocera Mita KM-3035 All-In-One Laser Printer Logo
Anonymous Posted on Sep 06, 2007
Copier giving error
The Kyocera mita KM-3530 KX is showing an error. Display shows "System Error, Call Service C4200 aND A TELEPHONE SIGN IS COMING IN THE MIDDLE WITH SOME STARS Please help!!! the model number of printer is stated above as i caudnt find it in the list provided below.
Sam
Level 2:
  • Expert 36 Answers
  • Posted on Oct 25, 2007
Sam
Expert
Level 2:
Answers
36
Questions
0
Helped
31053
Points
349
Defective Optical Laser Unit or main board. Is it making noise?
If so, it is the laser unit.
And that is more likely than the main board.
  • Sam Nov 01, 2007
    You always enter the trouble reset code first. It may be a false code. Enter 10871087 on the key pad. The machine will enter the service mode. Enter 906 and start. You will see a square on the screen that says "execute", touch it. The machine will try to reset itself.
    If it is a false code, it will come ready.
  • JJenkins
    JJenkins May 06, 2014
    Thank you! This completely cleared my copier and it is now working again.
Anonymous
Level 2:
Sniper:
  • Expert 56 Answers
  • Posted on Oct 31, 2007
Anonymous
Expert
Level 2:
Sniper:
Answers
56
Questions
0
Helped
84120
Points
136
Just open and close door on the left side of  Machine.I had that problem.
  • Anonymous Oct 31, 2007
    And do not forget to switch off and on machine after door is closed
Anonymous
Level 1:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Nov 05, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
1352
Points
The kyocera MITA KM-3530 KX IS SHOWING ERROR
DISPLAYS SHOWS SYSTEM ERROR CALL SERVICE C6020
AND A TELEPHONE NUM ALSO
PLEASE HELP ME TO SOLVE THE PROBLEM
  • Anonymous Nov 19, 2008
    You always enter the trouble reset code first. It may be a false code. Enter 10871087 on the key pad. The machine will enter the service mode. Enter 163 and start. You will see a square on the screen that says "cancel", touch it. The machine will try to reset itself.
Kyocera mita km2050 kx printer shows print error and does not print?
MR KIRAN now which type of error is that the machine showing alert mi soon you will get immediate answer thanks
2answers
I Keep getting a j10 display when I try to print on the display
A J10 shows up if there is no feed from the upper paper tray. Check the operation of the paper feed clutch for the upper drawer.
Good luck,
Peter
1helpful
Error 902 kyocera 1500 and also give to me error list.
Please check again 902 does not show it must be A**** or C****
3answers
My kyocera km 5035 has an error code of c 2642. Any suggestions?
C2642 is not a listed error code for the KM-5035.
C2600 is deck conveying motor / desk motor problem.
C4200 is a LSU (laser unit) problem.
3helpful
3answers
My Kyocera KM-5035 receive error code 4200 in PC printing and in photocopy
Hello, This error C4200 indicates a problem with the main Laser Scanner Unit. The laser scanner functions to image onto the drum in the copier. It scans at a high rate of spped, the error indicates it is in trouble.
The Laser scanner would need to be changed.
It is also possible the main PCB is failing (remote chance)
Find a Kyocera Repair Facilty.
8helpful
2answers
System error C4200 on kyocera 3530 printer
try doing a reset... with the copy screen on press 10871087 then when screen changes enter 906 then press enter then start then enter... if that fixes it run to the store and get you a nice expensive surge protector... if that does not fix it then your main board is fried...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
2helpful
2answers
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Top Kyocera Mita Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Ngoro
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
