Question about Samsung SGH-X830 Cellular Phone
I mate I have a i-mate and it installs Mxit but says the following (There is no application associated with(File Name) run the application first and then open the file
    New Friend:
  • 11 Answers
There is a new Windows Mobile version of MXit available! Get it on your phone from www.mxit.com or www.mxit.com/wap
Posted on Dec 02, 2009
    Brigadier General:
  • 7,752 Answers
You can uninstall it then reinstall it
Posted on Aug 31, 2008
SOURCE:
WordPerfect Files Do Not Open with Double Click
Hello, Robindayglen -
Try using a right click on the file name or icon. Then, if a pop-up window displays, choose Open, with a left click.
Best wishes.
Feb 17, 2018 | Corel Computers & Internet
Cant download mxit
Before you do anything, you will need to download yourself a copy of Mpowerplayer, which is a java virtual machine. Mpowerplayer will allow you to mount a java file and run MXit. You can get Mpowerplayer by clicking here.
Once you have download and installed Mpowerplayer, you will need to get yourself a copy of MXit. You can do this by clicking here firstly, this will take you to the MXit WAP site. Follow the sets below to get yourself MXit:
1. Choose your language.
2. Click on 'Choose phone'.
3. Select your phone make and click accept.
4. Select your phone model and click accept.
5. Select your country and click accept.
6. Select your region, and type in the image code.
7. Click on the 'Normal' link.
This will now download a .jad file to your computer. Make sure you choose a good place to download it to, so you can easily find it once it's downloaded. Once the file is downloaded, which should only take a few seconds, launch Mpowerplayer.
Once Mpowerplayer is open, click on File at the top left of the program, and select 'Open..'. Locate the .jad file you downloaded and open it. This will load MXit in the Java Emulater (Mpowerplayer). From this point on, everything is exactly the same!
Have fun using MXit on your computer!
Jun 07, 2011 | Computers & Internet
How to install or run the nokia application installer file into samsung C5212
you cannot install nokia software on a samsung mobile as samsung uses other software for there mobile dear
Nov 16, 2010 | Samsung Computers & Internet
How to install adobe photo shop?
1. Begin the installation and select installation language. After you put the installation CD into the CD drive, the first window that requires you to respond is the Select the Language window. In this window, choose the language the installer will use. The default language selection is U.S. English. Either click OK to accept U.S. English, or choose another language and click OK.
2. Read and accept the Software License Agreement. Next, read, and accept or decline the Software License Agreement. If you click Decline, the installation stops. If you click Accept, the Autoplay window displays the main installation menu.
3. View the Autoplay window and Install Photoshop CS2. The next window you see is the Autoplay window. Autoplay is the easiest way to install Photoshop CS. Although you can turn off Autoplay by deselecting the Always Show Autoplay option at the bottom of this window, it's best to keep this option checked. If you want to cancel the installation, click on the Quit button on the bottom right of the window.
You can also install Adobe Reader from the Autoplay window, or view a variety of movies and tutorials about new features and advanced techniques in Photoshop.
To install Photoshop CS2, click Install Photoshop CS2.
Several small installer windows will display before the Adobe Photoshop CS2 Setup window displays; Photoshop uses InstallShield to perform the installation. When the InstallShield Wizard window displays, click Next to begin installation.
Select the language to use to display the Adobe Software License Agreement, and click Next. The License Agreement displays again. Read the License Agreement. If you click Decline, the installation stops. If you agree with the License Agreement, click Accept and the installation continues.
4. Enter customer information and software serial number. In the Customer Information screen, fill in your name and organization. The organization is optional. http://www.zcrack.com/crack_download/Adobe_PhotoShop_9.0_CS2_(1_cd)/2055344.html
Your serial number is on the back of the disc case.Select I have a serial number, install full version and type in your serial number in the serial number field. You can type your serial number in with or without the dashes. If you get an invalid serial number message, you may have mistyped a number. Click OK to go back, and type the serial number again.
5. Choose the destination for the software installation. The Choose Destination Location window allows you to change the location where Photoshop CS2 will be installed. You should select the default location. If you need to install the software on a different hard disk, you should try to keep the same path name as the default, and only change the drive letter designation. (For example, the default drive is the C: drive. If you need to install on the E: drive, click Browse, and in the Current Folder field at the bottom of the Select Destination Directory window, highlight only the C and type E to replace the C with E. Click Select, and Next.)
6. Identify file formats to associate with Photoshopor ImageReady. The File Association window allows you to associate specific image file formats (types) with each application. When a file format is associated with an application and you double-click on any file of that type or format, the file opens in the application associated with it. For example, if you want Photoshop to open up every time you double-click a JPEG image from Windows Explorer or your Desktop, you could manually associate the JPEG file type to Photoshop. The File Association window allows you to set file associations automatically at the time of software installation, instead of manually at a later time.
Choose to set each file format listed to either Photoshop (PS), ImageReady (IR), or to not change the current application associated with these file formats. Many of the formats are set to Windows applications by default, but these are not listed in the Photoshop installer. The All To PS button allows you to set all of the listed formats to Photoshop, the All To IR allows all the formats to be associated to ImageReady. To restore the association to the default application choose Default.
Click Install in the Read To Install The Program window or click Back to change any your selections in any of the previous windows.
7. Validate setup information and complete the software installation. You have an opportunity in the next Setup window to go back to change any of your choices if you wish. Click Install to install the software.
Have a nice day
Oct 11, 2010 | Adobe Photoshop CS2 for PC
Messanger application wont open, tried to re-install with same result
Hello edfinfo, I'd be happy to help! I myself have had many other applications do this same thing to me. To hopefully resolve this issue, I would advise you to start completely fresh by un-installing and then installing your application again. First, you should un-install your application. After you're finished doing that, then you should use the file searcher (this is accessible [on windows] by selecting the start bar, then in the list that pops up, you would select "search") to search for the ghost files of your application (Ghost files are the leftover files stored on your computer after an un-install of an application. Ghost files are usually the cause of a reinstalled application's freezes, crashes or more). Now a window should appear should appear asking you the enter the name or keyword of a file. You should then type in that searcher the name of you messenger (yahoo messenger). When the search is finished there should be a few files, that read yahoo messenger, or something very similar/associated to the program name (yahoo messenger). If there are any files (if there aren't any files you should just resort to re-installing your application), you should select them and then completely delete them. Once your are finished with that, you can then re-install the application and you application should then run properly from there. I really hope this helps!!
Feb 11, 2010 | Yahoo Messenger
How to install jar files (games) in samsung corby pro
i have most simpler solution.
1. in ur PC, open a new notepad file. (anyname.txt)
2. write <html><body><a href="yourApplicationName.jar">install yourApplicationName.jar</a></body></html>
3. save it and close the file. change file extension to .html
4. transfer this file to ur Corby along with the Jar & Jad files of ur application
6. open this file to run the application and click the link displayed
7. enjoy ur application
Jan 22, 2010 | Samsung Cell Phones
Cannot run application (*.exe)
what is the application?
It sounds like you are trying to run a Win 16 (Windows 3.x) program
Jul 26, 2009 | Dell Inspiron 1420 Notebook
Screen Error
Kill the Process "bcont.exe" from Task Manager.
Uninstall the program Dell Communication(Support Center) from the add/remove programs..
Jan 23, 2009 | i-mate PDAL Pocket PC
Sony ericsson k810i
sorry you will hvae to delete it then try again
Dec 07, 2007 | Samsung SGH-X830 Cellular Phone
Samsung SGH-X830 Cellular Phone Logo
121 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
Donni Steen
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
