Question about E-Machines eMachines Desktop PC
Emachines e4026 non-responsive
After purchasing a 500gb hard drive and 2gig kit for upgrade on my e4026, i formatted my secondry drive and installed all emachines drivers and operating system, this worked fine and all was well, i then powered down and installed my new 500gb drive as the secondry, after doing this, while the machine was still open i thought it a good idea to remove the cpu fan and heatsynk and give it a good clean as it had alot of dirt inside, after doing so i replaced everything and powered up but to find that the blue power light on the front of the model is the only thing that works!!!, the fans kick into life for a split second but then die and absolutely nothing else happens!!! i have since taken off the fan and heatsynk and cleaned off all existing paste with isopropyl alchol and reapplied new thermal paste thinking that it could be that the cpu had overheated and just shut down, this still has not worked, can you please advise? please, please, please!!!
  • protlc Sep 07, 2007
    i have realised what it is!, where i initially removed the heatsynk and fan to clean them, on placing them back i did not mount them correctly and this caused the cpu to overheat initially, this has caused one of the small pins in the bed which holds the cpu to become damaged somehow! on closer inspection i found that the small pin had actually bent and broke, solution? i guess a new motherboard is required as the cpu bed is non-removeable, please asvise if i have got this incorrect?
    many thanks.
  • 279 Answers
I don't think it's an overheating CPU. It would stay on for a bit longer if it was that. My best guess is a power supply issue. Either your power supply is bad, or more likely something is pulling too much power from it. Emachines are notorious for using the bare minimum hardware... possibly the extra hard drive is pulling more juice than the power supply can handle, so it shuts down. Try disconnecting power to the new hard drive and see if the machine comes up. If it does, you need a new, higher wattage power supply.
Posted on Sep 06, 2007
  • John Goodman Sep 07, 2007
    Unfortunately, you have it correct. Not much you can do about broken pins but replace whatever they're on.
Can I upgrade the PS4 Harddrive?
The PS4 will allow you to use an external drive to store data other than games. If you put a game on an external drive, it wont work. The drive in the unit is 500Gb
Jun 28, 2015 | Sony PlayStation Video Game Consoles &...
Upgrade hard drive
b9863391-bc66-4456-9d11-5f1787312d10.jpgprovided you format your new drive first you can put most any in. To format buy a wire kit that you can plug the drive into a usb the kit comes with a power supply transformer.
Nov 07, 2013 | Gateway M280E
I would like to wipe out my computer and start over can i do that
Hi josephamy99
Yes , you can . Launch the install disc and follow instructions .
Note : back up all your data and drivers ( very important , the drivers , some hadware could not function if you don't reinstall the drivers on your new system ) .
Best regards ,
fanaudi .
Sep 14, 2011 | E-Machines eMachines Desktop PC
I wish to Upgrade My HP Pavilion ZD8230US 100GB ATA HDD to one that is faster and has more Maybe as high as 500GB. SATA type drive would be great to have but unsure if I can install SATA Drive in this...
yes you can upgrade your hard drive but still on ATA,if you upgrade in SATA you need some converter from ATA to SATA .and since it's a laptop i think its hard to do that thing.
Sep 13, 2011 | Computers & Internet
Slow, and sometimes non responsive. I just cloned my old hard drive in my Macbook Pro to a new 500gb WD drive. What could be the issue? please advise
Please check that the power connection - to the outlet and to the device itself is as it should be. Mostly, when these things occur, it's related to a physical problem - either with the power source (cable/outlet) or a physical problem with the drive itself.
Feb 13, 2011 | Western Digital Caviar 500GB Internal SATA...
Hitachi Desk star 500GB SATA drive
you can check the jumper, is it on the right place?
besides, some motherboard is indeed do not support hard drive with large size on it...
Jun 08, 2009 | Hitachi Deskstar 7K500 500 GB Hard Drive
Replacing HDD's on WD MyBook World II won't format
I was attempting something similiar -- replacing my World Edition II 500GB drives with 1TB drives. My research unearthed two things... These units will only work with Western Digital Caviar Green drives. The blue ring won't light if other drives are installed. I also read (in a couple spots) that the unit's O/S is stored on the hard drive (as opposed to be stored in Flash memory). If this is true, you would need to image the old drive to the new (using a tool like Ghost or True Image), and increase the partition size as part of the imaging process. I don't know if this would work, as I opted to not proceed with the upgrade. For me, the new version of the World Edition II (WDH2NC20000 and WDH2NC40000) turned out to be a better option than upgrading. These units provdide the extra space and are MUCH faster than the old ones.
Apr 16, 2009 | Western Digital 500GB My Book World...
Having problems upgrading my laptop hard drive !!!
From what I gather basically you want to copy everything off of your 40GB and put it on the new 320GB and the install correct? Why don't you do a backup (Start>All programs>System Tools>Backup to the external 500GB drive. Install the new 320GB drive and then load the operating system from your operating system disc, then restore the data from the 500GB you backed up, or am I missing something.I know it is not as convenient as cloning but sounds like you may need to do it the old fashion way..there is no good reason that the cloning software would quit reading your disc unless it's some kind of "only get one chance and throw away software".
Dec 27, 2008 | Dell Inspiron E1505 Notebook
LaCie 2d 500GB isnt recognized
Has the drive been formatted? Before using a hdd it has to be formatted. In Windows XP you have choices of FAT 32 or NTFS format. Hope this helps.
Dec 17, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
E-Machines eMachines Desktop PC Logo
144 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
