Intermittent Horizontal Jitter in NEC Accusync 125F Monitor
I have an NEC monitor, a large CRT type, AccuSync 125F, that works perfectly except for an annoying occasional "jitter" where the horizontal size (width) of the screen fluctuates slightly. (You can see the left and right sides of the picture move slightly in and out, like someone is varying the Horiz Size setting.) I am experienced in electronic and TV repair, and I have gone through the main board and resoldered connections and most components in the horizontal oscillator, driver, driver transformer, and flyback transformer areas, and also resoldered many other connections including the pins on the yoke connector. Have done the same in the power supply module. I have repaired similar intermittent troubles in other computer monitors many times by carefully resoldering these areas, but there was no effect on my problem with this unit. Could this be a component rather than a solder joint? Any fault history or ideas on this issue? THANKS!
  • zekeman Sep 06, 2007
    All good ideas. I did check the settings in the manual, also tried setting it back to all factory defaults. The horizontal jitter is intermittent, but it does not matter what screen resolution setting its running. I normally run 1024X768, but the problem occurs regardless of the scan rates or refresh rates selected. When I say "jitter" I mean a slight increase or decrease of width, often no more than a few milimeters to maybe 1/4 inch at the most. It is only noticeable as you look at the screen edges, more of a problem on documents than with gaming or video. It happens regardless of temperature, brightness, contrast, or any other user settings. I have tried it on multiple computers as well.
  • 944 Answers
You can get the user manual here; http://www.necdisplay.com/cms/documents/UserManuals/AccuSync125F_manual.pdf Check page 8 of the pdf (page 6 of the manual) - "GTF Auto Adjust". Try it on and off and see if you get a change. there is also a factory settings reset which could be worth trying (same page). Check the Moire settings on the following page (probably not going to help, but worth a try in case) I'm guessing you have tried to degauss already? - if not check page 10 (8 of the manual). Also page 10 is the global settings reset. Check page 14 for the resolution/refresh rate combinations that are supported and check (diagnosis on page 10) that you have the input set to one of the approved settings.
Posted on Sep 06, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Sep 06, 2007
    You can also get the monitor driver here;
    http://www.necdisplay.com/SupportCenter/...
    Might be worth a try.
    After all that I would suggest getting an oscilloscope on all the power circuits - it could be external interference, could be something generated internally.
    Hope this helps :)
  • Nigel Ridehalgh
    PS - I couldn't find anyone else with the same issue for this model online
    Master:
    Sergeant:
  • 461 Answers
Yes it could be the components check especially on capacitor and oscillators.
Large screen
try clciking auto on screen or downlaod grathics drivers eg intel grathics , then u can change from there
Apr 27, 2010 | NEC AccuSync 900 19" CRT Monitor
Screan on monitor not lighting up.
How do you know the flyback is good if it is not functioning?
Some causes for no high voltage:
short or open horizontal output transistor.
open or shorted capacitors in horizontal circuit.
Defective or non functioning horizontal drive circuit.
Open yoke.
Malfunction in horizontal B+ regulator circuit.
Faulty solder joints.
Short in CRT.
Apr 26, 2010 | NEC AccuSync 90 19 in.CRT Conventional...
Getting black horizontal lines across the screen. It started off as an intermittent problem, now occurring more often. I changed the video card and the power supply tests fine and I changed the refresh...
I would test the cable, use it on a different monitor or try a different cable. That is the only other thing to check, otherwise it definitely is the monitor.
Apr 07, 2010 | NEC AccuSync 700 (White) 17 in.CRT...
Help me please
Try this link, I am asumming you have the AccuSync LCD71VM monitor, I don't know what a n4 ibfgl is. But here is a link to nec that might help you...
http://www.necdisplay.com/SupportCenter/DriverFinder/
Download the file NEC LCD MONITOR Installer.
Hope this helped you..THK
Nov 24, 2008 | NEC AccuSync LCD71VM 17" LCD Monitor
NEC flat screen monitor reset screen keeps popping up.
Call 800 836 0655 and ask for directions from tech support.
Nov 14, 2008 | NEC AccuSync LCD71VM 17" LCD Monitor
NEC AccuSync 120 Frequency setting
This is the maximum resolution for this monitor:
1600 x 1200 / 76 Hz
Even if you lower the resolution to the monitor, as I can see that you want to do, the maximum refresh rate is still going to be 76 Hz. If you were able to force the monitor to scan a greater field rate and its protection circuits do not shut it down, the monitor will be damaged.
Your display card is most likely limited also, unless you went out and bought a very high end card.
When using a different resolution that what the specs on the monitor indicates as its native mode, this will reduce the quality of the results displayed.
Specs for this monitor:
http://www.superwarehouse.com/NEC_AccuSync_120-BK_Black_21_CRT_Monitor/AS120-BK/ps/120193
Jerry G.
Apr 24, 2008 | NEC-Mitsubishi Nec Display Solutions...
Help me with ma monitor
Being a 21" CRT monitor (old tube type) it is going to be cheaper to buy a new LCD flat screen than to fix this one. Best bet if you do want to fix this, is to take it to a tv repair shop and let them work on it. You have not given enough information to give a good educated response to what might be causing this issue. Good luck.
Aug 18, 2007 | NEC AccuSync 120 CRT 21" Monitor
NEC ACCUSYNC 900
Havent you got a person or a friend that has a puter to test the monitor??? This would be the best way as it could be the crt on the monitor or the crt driver board but before we go there we should make sure where the problem lies. Good Luck
May 12, 2006 | NEC AccuSync 900 19" CRT Monitor
Computers & Internet Logo
426 people viewed this question
David Payne
David Payne
