Question about HP Compaq Presario V2000 Notebook
Black screen``` i recently restarted my computer. when i came back the screen was black but the power light is on the caps light is on and the disk drive light is flashing what is wrong. how can i fix it
    Sergeant:
  • 457 Answers
You cant fix it Im afraid I think the screen maybe poked and died on you. To prove a point plug and external Monitor to the laptop and if all is well then Im afraid the latter I have informed you is correct. There are quite a few models of laptops out that nfortunately are built to fail so the rotten companies who make them sell another. To replace your black screen if it is damaged would be $700 and thats for the screen there is the fitting yet you might have pay the man for that and they are not cheap. I wish I could help you further or wave a wand but I cant Im sorry.
Posted on Sep 06, 2007
SOURCE:
Hung on black screen apple logo is still light
Try holding the shift key when restarting the computer until it is all the way up. It would show safe mode. release the key. Basically it would not load 3rd party items to load. If it works find the offending program. Also go to the library and trash the " com.apple.plist ". Please include your OS version. Currently it is 10.9.3.
May 10, 2014 | Apple Computers & Internet
Tip
Troubleshooting Error Messages on a Black Screen that may Occur During Startup...
<b><u>For Hp Laptop</u></b><br /><br />There are many reasons that a computer does not startup or boot into the Windows operating system.<br /><br /><b><u>Resolving Start Up and No Boot Problems Checklist</u></b><br /><b></b> <br /><b>Perform a Hard Reset</b><br />1. Disconnect all peripheral devices and remove all USB devices and media cards.<br />2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds.<br />3. Reconnect the AC power adapter (do not connect the battery), press the Power button and look for the LEDs to blink or glow, and listen for the sound of a disk drive and fan turning.<br />If computer does not start normally, identify the specific problem symptom listed below and take the recommended actions.<br /><br /><b>Symptom: LED lights do not glow, display is black, computer does not start<br /></b>If LEDs do not glow when power button is pressed, there is no power available to the notebook. Check AC adapter wiring and power connection to the notebook. Connect a different AC power adapter and remove battery. Connect a different battery and disconnect AC power adapter. If there is no battery or AC power at the notebook, contact HP for technical assistance.<br /><br /><b>Symptom: LEDs glow, but computer fails to startup or boot, and displays a black screen</b><br />Usually occurs if a component is installed incorrectly, or there is a device conflict or failure. Connect an external monitor to check display Remove all CD/DVDs, SD cards, USB devices, peripherals and do hard reset If memory or hard drive components were replaced, reinstall original components Remove memory modules and replace one-at-a-time If possible, boot to BIOS mode (f10) and run Memory Test and Hard Drive Test If all other methods fail, use recovery disk to recover the computer to original condition.<br /><br /><b>Symptom: Computer displays a blue screen or continually re-starts</b><br />Trying to restart the PC after an error message can usually bypass the error and the PC can run in Safe mode to install an update or patch. <br />Boot to BIOS Diagnostics (f10) and run memory and hard drive diagnostic tests Boot to Windows Advanced boot options (f8) and:<br />o Select Disable automatic restart on system failure to view error message<br />o Run Repair Your Computer<br />o Run Last Known Good Configuration (Advanced)<br />o Select Boot into Safe Mode and then Run a Microsoft system restore<br />o Select Boot into Safe Mode and then Uninstall recently installed programs<br />o Select Boot into Safe Mode and then run Windows Update<br /><br /><b>Symptom: Computer displays the Windows logo screen and stops responding</b><br />Boot to Windows Advanced boot options (f8) and select Disable auto-restart to view error message<br />Boot to BIOS mode (f10) and Restore the BIOS defaults (f9) Boot to BIOS mode (f10) and run Hard Drive Test Boot to Windows Advanced boot options (f8) and select Last Known Good Configuration (Advanced) Boot to Windows Advanced boot options (f8) and select Boot into Safe Mode and then Uninstall recently installed programs<br /><br /><b>Troubleshooting general black screen errors on an EFI-based computer</b><br />The Extensible Firmware Interface (EFI) is available on select HP Notebook PCs manufactured in late 2008 and beyond.<br />To access the Startup Menu and the troubleshooting options on an EFI-based computer, press the power button and immediatly press the ESC key. If computer does not display a EFI Startup Menu, it may a non-EFI computer.<br />The EFI environment allows you to select from the following options:<br />Press f1 for System Information .<br />Press f2 to perform System Diagnostics .<br />Press f1 for System Information System Information.<br />Press f2 to perform the Start-up Test .<br />Press f3 to perform the Run-in Test .<br />Press f4 to perform the Hard Disk Test .<br />Press f11 to view the Error Log .<br />Press f9 for Boot Device Options .<br />Press f10 for Bios Setup .<br />Press f11 to perform a System Recovery .<br /><br /><b>Troubleshooting general black screen errors on non-EFI based computers<br /></b>The Extensible Firmware Interface (EFI) was not available on computer manufactured in 2008 or earlier.<br />When you try to start your computer, it may appear to stop responding with an empty, black screen before reaching a blue screen or the Windows logo. If there is no specific error message provided, there are several things you can do to troubleshoot a black screen. <br />Remove a non-system disk from the computer <br />To remove all non-system disks and reboot the computer, follow the steps below:<br />Disconnect any eSata, USB, or 1394 (Firewire) devices that are attached to the computer.<br />Remove any CD / DVD discs or memory cards from the drives if present.<br />Press and hold the Power button for 30 seconds to turn off the computer. Then, press and release the Power button to turn on the computer. <br /><br /><u> NOTE: During startup, a computer checks several devices for an operating system in a pre-determined order. You can change the order that the computer uses in the system BIOS. </u><br /><b>After removing any non-system disk:<br /></b>If the computer starts up normally to the Windows desktop, no further action is needed.<br />If the computer still stops at the black screen continue by restoring the BIOS default settings.<br /><br />for re-installation bios process, waiting for next tips. <br /><span>Thank you</span> <span>for taking</span> <span>the time</span> <span>to</span> <span>read. H</span>opefully these tips beneficial to you to solve your hp laptop.<br /><br />Regards<br />Multilinkent
on Mar 08, 2011 | Computers & Internet
I had accidently turned of the power as my PC was loading up , so then when i turned it back up it has come up in a black screen saying:- We apologize for the inconvenience , but windows did not start...
Now that PC works in Safe mode i suggest you to run the Disk Check.
Step1: Double click on My computer and then right click on C drive.
Step2: Choose properties and then click on tools option.
Step3: Click on the Check Now tab listed under Error Checking.
Step4: Select both the options under "Check Disk Option" then click on start.
Step5: It will prompt you to restart your computer.
Step6: The Disk Check gets initiated as soon as you your computer starts rebooting.
Step7: Allow it to finish.
Hope this helps.
Jan 15, 2011 | ASUS Eee PC 1000HE Netbook
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Black screen
Look in the power/inverter board for bad caps with bulging top first, post back what you see inside so we can you further, see failed VIEWSOINC due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 02, 2010 | ViewSonic VX2235WM Monitor
When It goes to loading screen it restarts
It is becasue of your computer is not properly shut down and so your harddisk has some bed indexing of memory location.
For that you need winxp disk or recovery disk.
Then boot your computer with that disk .
You have to set first boot device as your cd or dvd rom.;
For that when you power up press F1 or F2 or "del" key to enter in bios .
Then go to boot option then sewt first boot device as your cd or dvd rom.
then save settings then put winxp or recovery disk in rom.
Then follow the procedure .
Then enter in recovery console then type in prompt "chkdsk /r"
then it fix error on harddisk.
Sometimes this command fix eror and then after restart windows load normally but sometimes need to repair windows.
So after check this if still face issue just chose "r" when it finds your previous version of windows then it recovers your windows.
Let me know if you need more assistanse.
Thanks.
Sep 04, 2009 | Computers & Internet
My Panasonic Toughbook 51 PC Notebook, locked up on me yesterday. Was able to get the computer back by draining the battery and restarting. Then, when I got up this AM the screen was black, neither the...
Please try re installing your operating system. (Genuine windows xp or vista recommended)
If the problem still persists feel free to get back me @
deepuunni1985gmail.com
Aug 16, 2009 | Panasonic Toughbook 51 Notebook
Laptop only works in safe mode, Black screen no task bar or Icon
Try this...
power on ur system,press F8(functional key) and select option of "last good configuration"....
Mar 10, 2009 | Microsoft Windows Vista Business Edition...
Black screen
you need to re install windows and when installed if not the original disk that came with pc possibly have to install certain drivers also.sounds like generic drivers for vga were installed and not compatable for ipod,ipod seen as new drive with unknown drivers causing conflict
Mar 01, 2008 | Acer Aspire 5100 Notebook
Black Screen / Computer Stays in Standby Mode
Completely remove the battery and unplug the power cord for a few minutes. Reinsert battery and power up. You can also hit F8 when starting and see if you can boot into safe mode.
Sep 06, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
61 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
