Question about Sharp AR 201 Copier
H and 3 Reading
My Sharp AR 201 stopped working, all you see is the letter H and # 3 on the readout. Is this something I can fix myself or do I need a copier technician to fix it? Pls. kindly advise if this is something I can resolve. Thanks. Bates
  • mefp43 Sep 06, 2007
    Hey Mr. CopierOne, Sir:
    Hope you could read this but THANK YOU for your input and sharing to me. I followed your instructions and the machine is back in operation again. I printed your post for later use if I run into the same situation again. About the thermostat you mentioned and I hope it doesn't get to that problem but I am a pretty handy person (ex US Navy engine room mechanic and ex aerospace assembly line employee) who can disassemble my Sharp copier. Can you pls. kindly post how to replace it, that's if you don't mind and it won't take you long in writing to explain it. Thanks and ALOHA, which part of Hawaii are you in as I visit there every few years. I was there in Honolulu, March of 2006 for vacation....I luv to live there someday. Bates
  • 30 Answers
This is a fuser (heating section) trouble code. It means that a higher than normal temperature was detected in the fuser. To reset you must press the following keys in order. Press the clear key, then interrupt, then the number 0 then interrupt. The display will change and you then enter the numbers 1 and 4 then press "print" the machine will then restart the warm up sequence. If the code reappears, your thermistor is bad and must be replaced. Only a technician can do this. Let me know if this helps. Aloha Bill Monroe
Posted on Sep 06, 2007
  • Bill Monroe
    Bill Monroe Sep 18, 2007
    The thermistor is a small square device that rides on the surface of the teflon roller, the one that has the heat lamp running through the middle of it. Removal and replacement is usually fairly simple and straight forward. You have to remove the upper half of the fuser which is secured by a single screw on the front frame which prevents the upper fuser from being raised to the vertical. There are two power leads for the heat lamp and a connector for the thermistor. Remove these to take the fuser out of the machine and replace the thermistor. Let me know if this helps as I haven't worked on that particular Sharp model in several years.
    Aloha,
    Bill Monroe
    PS. I'm in Mountain View which is on the big island, just about 10 miles south of Hilo. Great place to live and not as expensive or crowded as Oahu.
How do I print both sides of a document on legal size paper?
tell the copier you have a two side orginal. then scan one side then scan the other
try this site
http://siica.sharpusa.com/product-downloads
Dec 02, 2014 | Sharp Ar-202nt Toner Cartridge Ar 162,...
Is the Sharp AR 201 compatible with Windows 8
No it's not. Your best bet is to try an HP driver.
If you're ready for a new machine I can give you a quote!
Skelton Business Equipment Houston Copiers
Jun 08, 2014 | Sharp AR 201 Copier
Developer signal
On a Sharp AR-201, the developer light comes on when 50,000 pages have been made since the technician (or factory,) last changed the developer substance and reset the counter. A tech should come out with a Preventative Maintenance kit because training is needed to remove the developer substance safely as well as to clean the optics, interior and inspect the fixing unit, drum and cleaning blade and vacuum out the copier. You should call for service and tell them the developer light is on so they know to bring a kit. And yes... I am factory trained on this model. Retired now.
Nov 24, 2012 | Sharp AR 201 Copier
SHARP AR 201 - ERROR CODE H4
# * C * den start batan the copier will re-start
Oct 07, 2010 | Sharp AR 201 Copier
How do I get to the black toner reading on a Sharp AR-M257 copier
Hold down the Copy button and you should see a readout for the total copies printed from the copier and the percentage of toner left in the unit.
Aug 28, 2009 | Sharp AL 800 Copier
I need to obtain a meter reading for sharp ar-m236. How do I do that?
Simply press and hold the copy mode then you get the meter reading and toner percentage status
Apr 15, 2009 | Sharp AR-235 Copier
Error Code F1 on Copier Sharp AR201
F1 means "shifter Motor Trouble". The motor that driver the shifting mechanism at the paper exit side is not functioning. The motor could be bad or there may be something binding the motor up. Take a real close look at the exit unit (where the paper comes out of the machine) and see if there is anything in the way of the shifter. It could also be a bad board issue - sending the wrong signal to the motor... or possibly a bad home position sensor for the shifter.
You could try taking the shifter unit out for a closer inspection - make sure its properly installed.
Hope this helps.
Apr 13, 2009 | Sharp AR 201 Copier
Incomplete copy
the paper is set to 8.5-11 and you are running letter r paper u must set the copier tray to the proper size
Mar 03, 2009 | Sharp AR 201 Copier
DISPLAY ALTERNATES "L" THAN "6"
Hello sir; this machine have a laser unit problem, replace it !
Feb 18, 2009 | Sharp AR 201 Copier
Sharp AR 201 Copier Logo
85 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
