Question about OKI MICROLINE 5521 Matrix Printer
Hp deskjet 1180c
I am having problem with hp deskjet 1180c printer. when i switch on the printer orange light of cartridge started blinks. i remove cartridge & insert new reffiled but same problem is going on what to do, is it printer problem or cartridge problem.
  • 2 more comments
  • Anonymous Jan 23, 2008
    blinking
  • kinzababar Apr 30, 2008
    the light still blinks even after following the suggestion posted on this site
  • sonnyf Oct 09, 2008
    I am having the same problem but only withe my 895cxi.
  • sonnyf May 11, 2010
    Newq cartridges, Turned printer off and back on, held button in but printhead didn't move and it continues to do the same thing( cartridge lite keeps blinking).
Either it is the carriage assembly cable/s that may be faulty or the carriage chip where the cartridge gets in contact with, might need some cleansing with alcohol. Sometimes the reading becomes "blocked".
Posted on Oct 13, 2008
Try this:
  1. place good cartridges
  2. turn off printer
  3. press and hold power button until printhead is moving
  4. release power button
  5. your printer should be working again
Posted on Mar 13, 2008
2 Suggested Answers
SOURCE: HP DESKJET 1180C
printer driver for xp
Posted on Dec 16, 2008
Orange ink light blinks, printer will not print. Turned off, shut down computer, unplugged everything & replugged & restarted but did not fix problem.
Open the printer ink cartridge bay, and remove and re-insert the cartridge, it may be empty and need to be replaced.
Feb 28, 2011 | HP DeskJet 932c InkJet Printer
Hp deskjet D4155...Both power and arrow lights are blinking and I have tryed turning it off and un-plugging the printer multiple times, Every time is comes on, they both are still blinking. Please help....
Please remove the ink cartridges, unplug the power cord. You may also remove the paper from the paper tray. Now, try inserting the cartridge as well.. after about 20 seconds, plug in the power..
put in the paper, and ensure that you have inserted the paper properly. Then insert the ink cartridge. This should resolve the problem.
But if the light is still blinking , try by replacing the ink cartridge.
Aug 12, 2010 | HP Deskjet D4160 InkJet Photo Printer
The orange ink cartridge light keeps blinking. We
the problem is that your cartridges are expired or bad, just replace the two cartridges with a new one
Mar 16, 2010 | HP DeskJet 940c InkJet Printer
Inserted new cartridges..orange light still on
Try re-seating the ink cartridges. A lot of times, the electrical contacts on HP's ink cartridges do not make a solid connection.
Jun 17, 2009 | HP DeskJet 880c InkJet Printer
Arrow light and Power light keep blinking
take out all the cartridges and the papers..
unplugg the power cable from the printer..
manually slide the carriage from left to right and vice versa and roll the rollers in upward direction from the back after opening the back door..
if doesnt slide or roll..press & hold the power button for 60 seconds and then try again..
clean the inner area of the cartridge slot and the copper contacts of the cartridge with a soft lint-free cloth..
close the back door...
dont put the cartridges..
connect the power cable and power on the printer...
Lights will blink..
Insert one cartridge in the respective slot and close the cartridge door and check if any light blinks..
then remove the cartridge and insert another one and check the same thing..
If light blinks..it will mean the respective cartridge is not good and replace it--
Nov 07, 2008 | HP DeskJet 6540 InkJet Printer
HP Deskjet 5740 printer both orange lights are blinking and wont print
  • I replaced both carts with HP brand, no joy.
  • I cleaned the cart/printer connections, no joy.
An interesting aside is that if one or the other cart is removed, the appropriate LED goes out and the other blinks. At least some of the sensing circuitry sees the cart.
Anyone have a schematic of the cart/printer electronics?
Oct 10, 2008 | HP DeskJet 5740 InkJet Photo Printer
Hp deskjet 1180c
Did you run a test page? Are all the colors in the page shown?If someof the colors in the test page are not shown,there might be a defect in your color ink cartridge.
Apr 14, 2008 | Computers & Internet
Does not print
There is problem with your printer head socket, service the printer if problem is solve then ok otherwise change the head socket.
Mar 10, 2008 | HP DeskJet 920c InkJet Printer
HP DESKJET 1180C
HP Deskjet 1180c and1220c Professional Series Printer and HP Deskjet 9300 and 1280 Printer - Troubleshooting a Blinking Print Cartridge Light Introduction The Print Cartridge light continues to blink with both cartridges properly installed and the Access Cover (also known as the top cover or lid) closed. Instructions The blinking Print Cartridge light may be caused by a faulty cartridge, the plastic case of the printer being dislodged or slightly out of position (which prevents the Access Cover from seating properly), the Access Cover sensor (also known as the top cover sensor or lid sensor), or by the actuator on the Access Cover. Follow the steps below to resolve the issue.
  1. With the printer turned on, open the Access Cover. The carriage will move out of the capping station and stop at one of the cartridge status icons located inside the printer under the Access Cover. The yellow arrow on top of the carriage will point to one of the cartridge status icons to indicate a good, empty, or faulty cartridge. See Figure 1 below.
    1. If the carriage stops in the cartridge’s OK position, indicated by the happy face in Figure 1, continue with Step 2.
    2. If a problem is indicated with one of the cartridges, remove the cartridge and verify that the cartridge part number is correct. The black cartridge part number is 51645A and the color cartridge part number is C6578A or C6578D.
    3. If the cartridge part number is correct, clean the electrical contacts on the cartridge with a soft, lint-free cloth. Do not touch or wipe the nozzle plate.
    4. If a faulty cartridge is still indicated after verifying the cartridge part number and cleaning the contacts on the cartridge, replace the cartridge.
    5. After replacing the cartridge, turn off and then turn on the printer to clear the cartridge error from the printer's memory. If the cartridge error cannot be cleared, the printer will require repair. If the carriage stops in the cartridge’s OK position, indicated by the happy-face in Figure 1, continue with Step 2. NOTE: The printer checks the status of both print cartridges before printing. Both the black and color cartridge must be functional and installed in the printer in order to print.
    Figure 1: Cartridge status icons c00001225.jpg Icon/Drawing Problem identified by the symbol Solution c00001226.jpg The color cartridge is missing, improperly installed, defective, or the wrong print cartridge is installed. 1. If there is no color cartridge in the cartridge cradle, insert a color cartridge.
    2. If there is a color cartridge in the cradle, remove the color cartridge and firmly reinsert it.
    3. Check to make sure the color cartridge is appropriate for the printer.
    4. If the problem persists, replace the color cartridge. c00001227.jpg The black cartridge is missing, improperly installed, the wrong print cartridge, or is defective. 1. If there is no black cartridge in the cartridge cradle, insert a black cartridge.
    2. If there is a black cartridge in the cradle, remove the black cartridge and firmly reinsert it.
    3. Check to make sure the black cartridge is appropriate for the printer.
    4. If the problem persists, replace the black cartridge. c00001228.jpg The color print cartridge is running low on ink. Replace the color print cartridge with a new color print cartridge. c00001229.jpg The black print cartridge is running low on ink. Replace the black print cartridge with a new black print cartridge. c00001230.jpg None. The print cartridges are working correctly. None. The print cartridges are working correctly.
  2. Close the Access Cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, remove the Access Cover by following the steps below:
    1. Open the Access Cover and hold it open.
    2. Dislodge the Access Cover from the hinges with a sharp blow to the hinge area of the Access Cover and then remove the Access Cover.
  3. Install the Access Cover by following the steps below:
    1. Align the hinges on the Access Cover with the hinge pins on the printer.
    2. Push down firmly on the Access Cover until the hinges snap into position.
  4. Close the top cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, the printer case may be dislodged or slightly out of position. To restore the printer case to the proper position, squeeze the printer by applying pressure to the front and back pressure points shown in Figure 2. Figure 2: Pressure points c00006497.jpg Firmly squeeze the pressure points on the printer case as shown in Figure 3. If the Print Cartridge light continues to blink, continue with step 5. Figure 3: Squeezing the pressure points c00006498.jpg
  5. If the Print Cartridge light is still blinking, push down firmly on the center of the Access Cover (the extra pressure may engage the sensor). If the Print Cartridge light quits blinking, remove the pressure from the Access Cover to see if the Print Cartridge light starts blinking again. Re-apply the pressure to the center of the Access Cover to see if the Print Cartridge light stops blinking again.
    1. If the Print Cartridge light quits blinking with pressure applied, the Access Cover is faulty and should be replaced.
    2. If the Print Cartridge light continues to blink even with pressure applied, the Access Cover sensor may be faulty and the printer will require repair.
Oct 18, 2007 | Office Equipment & Supplies
OKI MICROLINE 5521 Matrix Printer Logo
545 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Clive
Clive
Timothy Van Der...
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
