Question about Dell E171FPb 17" TFT LCD Flat Panel Monitor
Black screen, led is green and if unplugged from computer led is amber. I need instructions about how to open the case of the monitor and possible solutions
  • Anonymous Jan 06, 2008
    Monitor was working fine. Turned computer off. Later turned computer on but noticed green power button was flickering on and off on the monitor. Tried monitor on another computer....same. Unplugged monitor from computer and the lite is still turning on and off...in the dark the screen seems blank for the few seconds it comes on......seems a power source fault inside the monitor but I cann't remove the back panel . :-(:-(
    Master:
    Sergeant:
  • 461 Answers
This may not because of LCD.Have you try to use other monitor to confirm that you PC is OK?
Posted on Sep 06, 2007
  • SS s
    SS s Sep 21, 2007
    May I know why my comment is not helpful to you?
SOURCE:
Lp2065
if screen black but green light on then is inverter was bad.
if screen black n green light off or amber then check then monitor defective.
Try with different monitor and result the same problem, either the monitor or the video connection.
Apr 01, 2014 | HP LP2065 Monitor
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
Monitor led is blinking green but screen is black. Unplugged and replugged all cables already.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement board: www.lcdrepair.us
May 19, 2010 | Dell E173FP 17" LCD Monitor
The monitor shows a black screen but the green
Yes, there is internal main AC fuse, which should be OK because you can see the indicator light, you need to open it up and check for caps with bulging tops first, post back what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 07, 2010 | Acer AL1714CB (Black) 17" LCD Monitor
Screen blinks to black, but the LED indicator is still GREEN
Get both inverter board and backlight fluorescent bulbs from eBay.
Jul 04, 2009 | AOC LM 720 17" Flat Panel LCD Monitor
Samsung 191T Blank
You need a fluorescent back light and inverter kit. Available on eBay.
Jun 10, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Screen going black, green LED staying on
Check to see if the image is Dimmed. Chances are the power supply on the FPD is either dead or not supplying power to the back lights.
Your problem is the power supply or the inverter on your board, you can replace it and it will be fixed.
Easy Fix REALLY EASY FIX
(inverter is what supplies power to your backlights. A lot of the times the reason a monitor goes black and the green power button is on, is because the backlights shut off. in most designs of the 1730 the inverter is embedded on the power supply. That is most often the case on this problem. Power supply/Inverter=Replace it and you will have a spanking new looking nice monitor working again. :)
Jun 19, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Dell E171FPb 17" TFT LCD Flat Panel Monitor Logo
155 people viewed this question
Ekse
Clive
Clive
