Question about Quintum Tenor DX2060 (501-0122-00) Networking Switch
Internet down when give gateway
When i give gateway in any 2000 professional pc in my network then my internet down In my network there is alos xp pc and one pc of windows 2000 professional I formatted then it working
  • Deepak  Kumar Bisth
    Deepak Kumar Bisth Sep 09, 2007
    Format windows 2000 professinal pc your problem will solve
Yes, it will work fine. But there is no need to formate. You do one thing try once more. Check modem which is provided by your vender. Switch off & on your modem. Right click on internet explorer -> properties->Delete cookies , delete history-> go to advance -> restore default. Switch off and switch on of your modem. Check four light should be blink. If it is glowing definitely it will work. Good Luck
Posted on Sep 07, 2007
DOESN'T DETECT WIFI
The wireless feature on a Gateway computer allows you to connect to a network without the hassle of cables. This allows you to browse the Internet conveniently wherever you are. Gateway computers rely on Windows operating systems, which come with a built-in feature to manage your wireless connection. This feature makes turning off your wireless connection an easy process if, for a moment, you prefer to connect to the Internet using a wired connection.
Click the Windows "Start" menu and click the "Control Panel." Click Network and Internet Connections > Network Connection, if you are using a Windows XP Gateway computer. You should see your wireless connection. For Windows Vista and 7 Gateway computers, click "Network and Sharing Center" from the Control Panel and click "Manage Wireless Connections." You should see your wireless connection. Right-click your wireless connection and click "Disable" to turn it off. Close "Network Connections" when you are done.
Mar 03, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
What are the system requirements for a Netgar - Universal Wi-Fi Range Extender?
PC: Windows 2000, XP, Vista or 7; Mac OS; UNIX; Linux; Internet Explorer 5, Firefox 2.0 or Safari 1.4 or later; 802.11b/g/n wireless router or gateway (2.4GHz); 802/11b/g/n wireless adapter or Ethernet adapter
Feb 14, 2013 | Computers & Internet
Can't ping Default Gateway (XP) From Windows 7
Make sure you are receiving a proper IP address from the DHCP server....If you run a cmd prompt (windows icon, type cmd and hit eneter, then ipconfig) you should see a 192.168.0.x address. If not, go to the control panel, network connections, manage network connections, and be sure that TCP/IP (V4) is set as auto-configure....
If you are sharing the connection through an XP computer, you will need to run the Internet and connection sharing Wizard on the XP computer, and transfger the settings on a disk to the Windows 7 PC. A simpler solution (assuming you are on a cable/dsl connection would to be to go to your local big box store and buy an Internet/Firewall router. It would also increase your security.
Dec 28, 2009 | Microsoft Windows Vista Ultimate Edition
First of all sorry for my english i have 10 user pc and 1 server (windows 2000 sp4) and 1 modem i have static ip address in my modem and i give the local ip in my modem 192.168.0.2.......ok i give the...
Each of the eleven(!) computers needs:
1. a _unique_ IP-address
2. the IP-address of the "gateway" device
3. the "network-mask" (usually 255.255.255.0)
The IP-address for your server must *NOT* match the IP-address of any of the 10 computers.
The IP-address for your server must *NOT* match the IP-address of the "gateway" computerl.
Nov 13, 2009 | Microsoft Windows 2000 Server
How to enable ics in windows xp? what changes we hava to do in dsl properties?
You need firewall functions enabled, then go to Connections -> DSL -> Properties -> Advanced and check the box "Internet connection sharing".
You will need another network from which the connections come, that will be routed through the DSL connection. Select this network in the drop down box just below. I expect it will be something like, "LAN Connection #1" or such.
The other machines shall have to be configured to have the DSL'ed PC as gateway. In the LOCAL network connection properties of the DSL'ed PC, check the IP address assigned to it. Then in all the other PC's local conn properties, put the DSL'ed PC IP address as gateway.
Oct 30, 2009 | Microsoft Windows XP Professional
Gateway 505GR not showing LAN line for internet
assuming it's XP,right click my computer>properties>hardware tab>device manager, then look down list for network adapters, if its there click the '+' sign, then right click on the network adapter and select uninstall.
Restart pc and the network card will be found and the driver automatically installed.
It should now be in network connections, if not reply back
Aug 15, 2008 | Gateway 505GR PC Desktop
Internet sharing problem in Xp network
Not clear exactly what you want to do.
Do you want to share files on your network or just access the internet from all the PC's on your network. Do you have a router?
Regards
Apr 04, 2008 | Microsoft Windows XP Professional
Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
Wireless "Gateway"
Well, a gateway is a machine or router or device that your basically give you access to another network in this case the internet. In short a gateway connects you to another network. for example: IP Address 192.168.0.10 Subnet: 255.255.255.0 GATEWAY: 192.168.0.1 If this happens on any and all wireless network then it could be that your card is configured with a static address or your network card is faulty. What are the chances that all the gateways are not working. Go to Network Connections in Control Panel. Right Click on the Wireless Connection then go to properties. Select TCP/IP in the middle, you might need to scroll down. Click on properties. Make sure that both Obtain Automatically boxes are checked. Press ok then. Then close the wireless Properties. Try again! If it was already set to obtain automatically, You card might be bad or you winsock might be corrupted. Try repairing the winsock. If its Xp with Service pack 2 you are using then download install and run this utility http://files3.majorgeeks.com/files/9bf8d7d48a8543f9d4e60aa9da5e9ef9/internet/xptcprep.exe If that doesn't remedy the problem, it could be a faulty wireless adapter!
Apr 20, 2007 | Acer TravelMate 2300 Notebook
Quintum Tenor DX2060 (501-0122-00) Networking Switch Logo
155 people viewed this question
Top Quintum Computers & Internet Experts
David Payne
David Payne
Are you a Quintum Computer and Internet Expert? Answer questions, earn points and help others
