Chyanne, usually a socket wrench with correct size socket and extension will remove mirror screws. Check the attached video links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." How To Install Replace Side Rear View Mirror Chevy Lumina 90 94 1AAuto com
I have the haynes repair manual from 1982-1996 oldsmobile cutlas ciera & Cutlas cruiser in the book it say the code 26 is the Quad Driver Module Circuit I hope this helps
You will need to change the crank position sensor first and see if it corrects the problem. It is located behind the engine near the firewall. It's a bit tricky to get to it, you would need to rotate the engine forward then look under the exhaust manifold and under the cylinder closest to the drivers side. Use a 10 mm deep socket to loosen bolt. After replacement and it is still stalling then you will need to replace the ECM (vehicle computer). If it turns out to be the computer, go to your local junkyard to get an inexpensive replacement Click on the link below to view the CPS, it is around $22
locate the ECM under the dash on the right side in the side kick panel, gain access.do not remove it,light tap on it while it runs see it the motor changes.you probably need another ECM.I would have to have more info to help you better.
Put the car up on jack stands,remove left front wheel,seperate strut and knuckle popout left side axle shaft and tie out of way,support engine and trans from bottom,remove trans mount that attaches to side cover,remove pan/cover bolts raise and lower eng/trans assembly as needed to wiggle pan/cover out.hope this helps
That is not a Question but if you want to know what to do with your broken mirror. replace the mirror . it may be accessable by a plastic panal on the backside of the mirror on the inside of door by the window.under this panal their should be bolts or screws remove them and the mirror will come off.replace bolts or screws with new mirror.replace plastic panel.
CAUTION
When draining the coolant, keep in mind that cats and dogs are attracted by ethylene glycol antifreeze, and are quite likely to drink any that is left in an uncovered container or inPuddles on the ground. This will prove fatal in sufficient quantity. Always drain the coolant into a sealable container. Coolant should be reused unless it is contaminated or several years old. 2.2L Engine
Disconnect the negative battery cable.
Properly drain the engine coolant into a suitable container.
Remove the serpentine drive belt, as outlined in of this repair guide.
Unfasten the water pump pulley bolts, then remove the pulley.
Remove the alternator and side bracket.
Disconnect the water pump hoses.
Unfasten the water pump retaining bolts, then remove the water pump from the vehicle. Remove and discard the gasket. Thoroughly clean all gasket mating surfaces.
To install:
Position a new water pump gasket, then install the water pump. Tighten the attaching bolts to 18 ft. lbs. (25 Nm).
Install the water pump pulley and secure with the retaining bolts. Tighten the bolts to 22 ft. lbs. (30 Nm).
Attach the water pump hoses.
Install the alternator bracket and the alternator.
Install the serpentine drive belt.
Properly refill the engine cooling system using the correct type and amount of coolant.
First you have to remove the corner turn signal and grill. Both should be held on with just some hex screws (3 in signal, about 6 in grill). Then you should see 4 black bolts. Unscrew those and the assembly comes right off. : )
I can't fgure out which bolts to remove to get alternator out
