Question about Palm TX Handheld
Brand new Palm TX wont let me set the date to this year
It lets me change everything except this years date???? Bizzare. I have data entered for future datees but the best thing about the Palm handeheld device is the datebook feature.
  • Anonymous Dec 08, 2007
    My calaendar says Saturday jan 1 2005 when it is Sat Dec 8
  • 59 Answers
Are you both sure that under the World Clock icon that the current date/time is set to the right year?
Sometimes the dates get set back incorrectly if the Palm dies.
Posted on Jan 05, 2008
SOURCE:
HOW TO SET DATE & TIME
To open the USER SETTINGS MENU. Open all three of the One-touch speed dialing panels. Then press the button labeled "Data Registration".
Press the "SET" button 2 times until you see: USER SETTINGS - 1. DATE & TIME.
To open the DATE & TIME Menu. Press SET. Use the buttons on the numeric keypad to enter the current month, day, year and current time. Just enter the new numbers over the old numbers.
To set the year, enter 08, 09, etc.
Use the 24-hours format to enter the time (e.g. 1:00 p.m. would be entered as 13:00)
You can also use the cursor buttons to move the cursor without changing a number entry.
To restore previous entry, press CLEAR. Press SET to "lock in" the Date and Time.
These instructions come directly from the User's Manual.
Hope this helps.
Mar 29, 2011 | Canon L220 Plain Paper Laser Fax
Set date & time
Go to settings first , then set date and time.
Oct 18, 2008 | Palm Computers & Internet
I have Calandar Creator 10 and have created a family calandar which I use from year to year that includes birthday events, holidays etc. and phases of the moon. This year, when I went from Dec. 2010 to...
Calendar Creator 10 has the four moon phases from Jan 1990 thru Dec 2010. To extend past 2010:
- File Open Collection ' Local Disk(c:)'Program Files'Calendar Creator' Template'Events'Phases of the Moon.bcc
-For each of the four events (First Quarter, Full Moon, Last Quarter, and New Moon) change the Repeat Until date past 12/31/2010 to 12/31 of the year you will add data for
-For each of the four events, click Advanced Repeat Rule you can selete the drop down under Exceptions / Pick exception and there you can see the dates by month and year from Jan 1990 thru Dec 2010 for the event. You need to extend this list. First obtain the moon phases from some web site like www.timeanddate.com/calendar. (note that this site calculates the mone phases base on New York time). The simply select each of the dates for the event you are modifying by clicking that date on the calendar in the upper right hand of the screen. Just advance the calendar thru the months and years you want to enter data for. You can check the list when finished by selection the ExceptionS Pick exception drop down box.
- Save your changes by clicking OK and Ok again. Make changes for all for events.
- Select File and Save Collection
- You need to replace the Phases of the moon events in your calendar by removing the old events and importing the new events. To remove the old Phases of the moon in your calendar, select Events'Categories highlight Phases of the moon and delete. Then add back the changed events by File'Import Events and browse for the Phases of the moon.bcc file you changed.
I hope this gets you what you need.
Nov 19, 2010 | Broderbund Calendar Creator Deluxe 10 Full...
My computer that I sync my Palm TX to was "wiped" clean. What steps would I need to take to be able to resync my Palm TX to the computer and not loose everything I have stored on my Palm TX?
Palm Desktop and HotSync won't destroy the data on your device if you have a fresh copy that doesn't have your data backed up. That said, however, look for free utilities that will back up your TX's data to an SD card should HotSync wipe your TX as well.
Jul 09, 2010 | Palm TX Handheld
My palm e2 screen brings a frozen screen even after reset and no button whatsoever works, it can reset but freezes on the screen again,that is 0 alerts. even the power button does not work, only reset,...
You can try doing a hard reset. A hard reset will delete everything on your device. All your data will be deleted, and formats, preferences and other settings are restored to their factory default settings. Don't perform a hard reset unless you've backed up your data, or you're willing to lose everything. Here is the link for directions for the Hard Reset:
http://kb.palm.com/wps/portal/kb/na/tungsten/e2/unlocked/solutions/article/42094_en.html#tx
Nov 18, 2009 | Palm Tungsten E2 Handheld
When trying to sync, error message reads (sys 0505)(0,841).What can I do? For Palm TX handheld
Try to perform a System Reset (see article linked below). If it works to break the loop, you should then be able to delete the offending "My Palm" software and perform a Hotsync to backup your data to your desktop.
If that doesn't break the loop, you'll have to perform another Hard Reset. Sometimes, a Hard Reset takes a couple of tries to get it right, since it's easier to do it wrong than to do it right.
This article discusses the various types of Reset for different Palm devices:
http://tinyurl.com/zlwza
Until you break the TX out of its loop, you won't be able to get the data from it.
To see the Palm OS version running on your TX, enter the Menu, select Info, then Version.
To Get Out Of A Loop:
  1. Perform a SYSTEM RESET by doing the following:
a) Press the UP Button
b) And THEN press and release the RESET Button
c) When you see the second Logo (Palm Powered) release the UP Button
d) Now check if your SYSTEM RESET worked by going to Beam Receive. If it goes back to Off even after you put it to On it means you were successful
2. Now Perform A SOFT RESET by pressing and releasing the button in the back once
  1. After a soft reset, a logo screen appears, followed shortly by a Preferences screen asking you to set time and date.
  1. If a soft reset does not break it out of the loop, you may need to try one of the other resets below.
  1. Do an INCOMPLETE HARD RESET by holding down the power (on/off) button on your device.
  1. While holding down the power button, Press and release the reset button on the back of your handheld device
  1. Keep the power button pressed and release it when the “Palm Powered” logo appears.
  1. A message will now appear warning that you are about to “Erase All Data”. And this will happen if you press UP or DOWN.
  1. Instead you press left or right to begin a soft reset, leaving your data intact.
  1. Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Sorry this was so long, I tried to put everything down that might help you.
Aug 03, 2009 | Palm TX Handheld
Exporting palm data to another platform
Palm to include Data Transfer assistant, allowing users to move contacts to the Palm Pre.:
http://www.palm.com/us/support/downloads/pre/migration/moveontophone.html
http://smartphones.about.com/od/howtoguides/ss/transfer_contacts_to_palm_pre.htm
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 23, 2009 | Palm TX Handheld
Time & Date
1. To open the USER SETTINGS MENU. Open all three of the One-touch speed dialing panels. Then press the button labeled "Data Registration".
2. Press the "SET" button 2 times until you see:
3. To open the DATE & TIME Menu. Press SET.
Jul 10, 2009 | Canon LaserCLASS Fax 710 Printer
Palm tx wont turn on
When the battery is discharged, it is best to charge it overnite.
Have you reset the TX?
Hold the power button down and push in the reset button on the back of the TX with the stylus. Hold the power button down until you get the screen where it ask you if you want to erase/reset the unit. click yes to reset.
Then when it comes back up, re-sync it with the Palm Desktop on your computer.
Thanks, Joe
Jun 17, 2009 | Palm TX Handheld
Change time
Hey here is something you can use to adjust the time on your T7206.To Change the Time:
1. Press the CHANGE softkey Display will read: "Hour:
2. Press the CHANGE softkey Display will read: "Hour: _ "
3. Enter the new HOUR. (in 24-hour format - Ex.: 5:00pm = 17:00. Display will then read the new Hour programmed.
4. Press NEXT Display will read: "Minutes: # # "
5. Press the CHANGE softkey Display will read: "Minutes": _ "
6. Enter the new MINUTES.
To Change the Date:
1. Press NEXT Display will read: "Date DD MM YY"
2. Press the CHANGE softkey Display will read: "Year: # # "
3. Press the CHANGE softkey, (If the year is incorrect) Display will read: "Year: _ "
4. Enter the new YEAR Display will then read the new Year programmed.
5. Press NEXT Display will read: "Month: # # "
6. Press the CHANGE softkey, (If the month is incorrect) Display will read: "Month: _ "
7. Enter the new MONTH Display will then read the new Month programmed
8. Press NEXT Display will read: "Month: # # "
9. Press the CHANGE softkey, (If the day is incorrect) Display will read: "Day: _ "
10. Enter the new DAY Display will then read the new Day programmed
Let me know how that turns out and good luck
Oct 03, 2008 | NorStar T7208 Corded Phone
Palm TX Handheld Logo
76 people viewed this question
Top Palm Computers & Internet Experts
Ekse
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
