Question about Acer 17" AL1717 Flat Panel Color LCD Monitor w/Speakers
Color i cannot adjust the colors on my monitor correctly. there is no red even though i have the red up to 100.
  • Anonymous Jan 31, 2008
    screen is all green
  • 661 Answers
This may be a cable problem, check the connector of your HD15 VGA cable for broken pins (there is usually one pin that is normally not present so don't worry about that one)
Posted on Sep 07, 2007
My 2001FP shows the contrast cotrol greyed out and the screen has very low contrast, which I need to correct. I use it with a Dell Inspion 9300. The laptop screen has excellent contrast. The 2001FP...
I have four Dell 2001FP monitors. The unavailable contrast is standard for this monitor when used with digital input (DVI). Make sure your brightness is at 100%.If you want a better result of dynamic range and color, the only effective option is color calibration. I use the inexpensive Huey Pro, available
several places, including eBay. Retail is around $100. It something one uses maybe twice a year, takes five minutes to install and use, and the results are notable. I'm a designer, and need excellent color. This is the best solution. Calibrate your laptop as well, and the color should be almost exactly the same between them.
As an alternative, you can use the color settings, select User Preset, and start with something around 40 red 43 green and 37 blue. Adjust proportionately upward until you get what you want.
Another possibility is to use a different connector cable if your laptop has that option, since your monitor an take four different input formats.
Good luck.
Dec 07, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Color loss
Hi, right click on an empty area of th e desktop, select "Properties," next, pick all areas that will apply: Windows Color and Appearance, Display Settings... make the adjustments, "resolution etc. "Rating the solution is appreciated, thanks."
Apr 13, 2010 | Acer AL1916W 19" LCD Monitor
My display has a red tint to it
Try adjusting the color properties of the monitor using the controls located on the front of the monitor.
If you can't correct the color, then it's a problem in the color circuit. As an ex tv repair guy I can tell you it may cost more than the monitor is worth to fix it unless it's still under warranty.
Jul 13, 2009 | Dell Computers & Internet
I have no color red on monitor.
Confirm the "no color red" by testing with another PC. If the same condition check if a color adjustment on the monitor is possible... like maybe a default setting. If the monitor still produces a bit of red it might be possible to edit the color adjustments using the advanced graphics adjustments; or a graphics program that your computers' manufacturer has available on your computer.
If nothing works the monitor may need repairs.
Jul 08, 2009 | Computers & Internet
Viewsonic VA2012WB monitor too much red color
I hope there's nothing wrong the the RGB circuitry. Here's what i recommend. degauss, recall the monitor. There's also a temperature setting for the monitor. Change it to COOL or NORMAL.
Mar 15, 2009 | ViewSonic VA2012WB Monitor
Screen colour not matching the printed pages
Unfortunately that's the age old problem of matching colors between computers and printers. Your printer is probably not the problem, that's why he couldn't fix it. Even though your monitor is set to default values it doesn't mean that your colors are correct as colors can vary from monitor to monitor and the color temperature is probably too high causing the colors to look lighter than the printout. The picture on the monitor may look good to you, but it's not set right for matching printer colors. Monitors use RGB (Red, Green & Blue colors) colors and printers use CYMK (Cyan, Yellow, Magenta & Black) colors and you have to make them get the results you want. You will have to do some tweaking of your monitor's settings to get it to match the printer output. Below are some links that will help explain things better and maybe help you adjust your monitor.;_ylt=AjWgmLYL.EGyC5z6hTuiEILty6IX;_ylv=3?qid=20090405191851AAl0xOq&show=7#profile-info-R3GCvDlKaa
Feb 28, 2009 | HP LaserJet 3600dn Printer
My monitor was not red colour
Change the vga cord of your monitor. red,geen and blue signal from cpu to color monitor pass tru vga cord. if one line is cut for example red line is cut 100% there is no red color in your monitor.
Jan 06, 2009 | Computers & Internet
Horizontal display
To replace TIP122 at near by LOT.
Check any dry point of DMV32 or DMV1500(Damper diode).
Check flayback capcitor and boosting FET 634.
Aug 30, 2008 | Computers & Internet
Monitor Coloring
Well most monitors come with 2 preset color temperatures and the option to customize it(the rgb setting). Your monitor has them as well 6500K or 9300K. 6500 is more reddish(like outdoors) and 9300 is more a bluish white(like a tv, i like the 9300 more). How u said its red and bright, what i would do is set the 9300 preset and if its still too red the customize the RGB by lowering the red. and If too bright then Lower the brightness(Press down on BRIGHTNESS CONTRAST page). If you don't have the manual you can download the full manual from LG's download site here: If you see that you can't get it just right,then the monitor might need adjustment from inside and you should make a qualified technician open the monitor and adjust that for you. Hope this was helpful.
Apr 26, 2007 | LG Studioworks EZ-FLAT E700B 17 in.CRT...
Computers & Internet Logo
64 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
