Routers
Problem for Routers
Generic problem for all Routers
Problem with connectivity
By breeches on Sep 06, 2007
We have a router and our laptops are showing "connected" with "excellent" signal, but we hare not able to sign on the internet. Any clues what we may be doing wrong.
Same Problem
Aug 13, 2008
-   I have a Netgear (WGR614NA) wireless router and from some now I have been having problem connecting to the Internet with it. My lap top has the wireless built in stuff, it detects the wireless signal, and indicates that the wireless signal is strong but when ever I attempt to load my Internet browser it gives me an error message saying that it is unable to load page. Interestingly, I am able to connect to other wireless networks with this identical computer but not my own wireless network at home. Can any one help me resolve this issue? -   jduwarkollie
May 29, 2008
-   I have DSL through AT&T Internet Services. I just purchased a Compaq Notebook laptop PC. I also purchased the NetGear WGR614 Wireless Router. The problem is, I don't know what I'm doing. Please help me to set it up.
-   Bryan K
Mar 26, 2008
-   I have a DSL connection through a Speedstream 4101 modem. I like to connect my laptop with the Netgear router, I connnected the router to my computer and connected the router to the modem. When I did it I cannot connect to the DSL line.
How can I do a proper setup?-   Guest
Mar 10, 2008
-   When using the install wizard I was not confident that the install was done correctly. How do you know if the router is installed correctly? There is not an icon on the decktop showing and there is nothing showing on the control panel. If it is not installed correctly should you just start the wizard again and go through the whole process again? I am totally lost. 1) I have gone through the installation process several times. 2) I have named my router 3) If you are supposed to connect your laptop to the router through the control panel it will not let me, it says that I am not using a windows program to use the Netgear program to connect. Like I said, I am totally lost.-   Lostsenior
Jan 25, 2008
-   cannot connect my laptop-   Guest
Best Solution
posted on Sep 06, 2007
Helpful)
sandrew
Rank: Wiz
Rating: 83%, 5938 votes
you need to get into the routers settings and look for DHCP, and enable it so as to give your pc's there automatic ip addresses, also check in the general settings if it's a modem router that you have got a internet connection from your ISP and all the dns and ip addresses are showing.
Go to the properties of each network card in network connections in your control panel and click on the TCP/IP line and click properties again and ensure obtain ip address automatically is selected and click ok.
Restart all pc's if neccasary and refresh your web browser when trying to get online.
Was this helpful?
Yes
No
Solution #2
posted on Feb 12, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
i lost my 32 digit code how can i retrive it
Solution #3
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the help....actually had to get the system checked....bad router. We're up and running again...Yeah!!
Popular Solutions for Routers
Questions and Unsolved Problems for Routers
Answer
We have a 3000 sq ft split level house, so range is critical (could we extend range with antennas,... (More)
Answer
need the software to install it on my comp.
Answer
I have a dlink wbr-2310. My wireless works, but only after a fashion: it seems like whenever I want... (More)
Answer
My PC broadband connection gives limited/no connectivity errors (windows XP SP3). The PC wireless... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Routers:
Top Router Experts
Rank: Guru Guru
Solutions: 3608
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
