Question about Gateway MX6445 Notebook
Issues with DVD Rom Drive
I have a Gateway MX6445 Notebook with a Philips DVD+RW SDVD8820 drive. When I play DVDs the picture is slow, jumpy, and sort of digitized from frame to frame. The sound is also jumpy and seems to echo. I have also noticed that it takes a lot longer to "rip" music from a CD. This behavior is the same no matter what programs I use to view DVDs or rip music and I can play video I have stored on my hard drive with no problems.
  • DI123 Feb 01, 2008
    I have the same problem, again--same Gateway MX6445 notebook--same Philips DVD+RW SDVD 8820 Rom Drive. My notebook is under warranty, and I have had the DVD player replaced twice already. I usually have the problem after transporting my notebook in a backpack. When I insert a DVD or CD the drive tries to play the disc but fails after several minutes of making strange noises. Maybe these particular drives are extremely sensitive to the normal jostling during transport; maybe just a coincidence. Any advice/comments appreciated.
Mine did that too but for whatever reason when I did a system restore back to a time when it didn't do that... it worked.
Posted on Oct 13, 2007
Ok i asked before if my drive will burn both dvd and cd. the answer was yes. but when i installed the drive and ran my dvd creator program. it said this drive is dvd read only.
Hi mikey7420 ,
The drive name itself is the clue to know whether it can burn dvds or not.
  • In your case it's a CD-RW (read and write or rewritable) and DVD-ROM (Read only memory and not read and write or rewritable as in the case of CD)
  • Perhaps the one who told you did not understand your question properly , and understood it , in the sense that it can read CDs as well as DVDs , as far as Dvd-ROM drives are concerned many shopkeepers who are especially new working in the shop just make a guess and answer our question which could lead to this misunderstanding or incorrect information being passed on.
  • So the next time you buy a DVD drive which should have a read and write functionality as well , then look up for a CD_RW,DVD-RW drive.
  • Also remember that DVD-RW drive can by default read and write CDs as well , but it's not true for CD drives..
  • So usually a DVD-RW drive can read and write Cds as well as DVDs but a CD-RW drive can either read or read and write a DVD depending on whether it's a DVD-ROM or DVD-RW.
Hope this helps.
May 11, 2011 | Philips CDD 5101 (CDD5101/33)...
My gateway laptop's dvd/cd drive stopped working, all of a sudden, but it plays music cds, it is just the DVDs that don't play them or even explore... what could it be the problem? how do i solve it? it...
Are you sure yours is a DVD player? It could only be a CD-CD writer, which will NOT play DVDs.
Open your control panel ->system->hardware->device manager and click on the DVD/CD-ROM drives icon. The listed devices will tell you if you really have a dvd player or not. If you do really have a dvd player, try a different dvd
Mar 19, 2010 | Gateway MX3228 Notebook
PHILIPS CDRW/DVD SCB5265 ATA Device cannot play most DVDs
I'm guessing you may have locked the DVD region. If you right-click on the device in Device Manager and click the Region tab, does it say 0 changes available? Acer won't fix this, and claim you have to replace the drive. Can't find a firmware flash for this drive online, will post back here if successful!
Aug 14, 2009 | Acer Aspire 5535-5050 Notebook
Would like to upgrade Dell Inspiron 1300 c.d drive
Is your dvd rom drive a RW drive? if not, you need to buy a RW-dvd rom drive to be able to RW dvds or cds.
If you already have a RW DVD Rom drive, you need to have a burning application (ex. nero burning rom). You can check on the internet and download a freeware and install it on your machine.
Jun 01, 2009 | Dell INSPIRON 1300 Celeron 1.4GHZ,256MB...
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
DVD Rom Drive Won't Play Some CDs...
Couple of possiblilities. Hardware or software.
You can go here to get the latest drivers for your system , just put in the serial.
http://support.gateway.com/support/drivers/dlcenter.asp
Or here
http://support.gateway.com/support/drivers/ddaStep.asp?platform=10022&model=10651&os=&type=&st=browse
If it is listed correctly in the system , it is probably starting to fail. You can try cleaning the laser lens GENTLY with a cotton swab and alcohol.
Also you can try and flash the firmware of the drive. The format of DVDs change slightly over time sometimes making newer ones unreadable. Here is a site with flash utilitys for your drive.
http://tdb.rpc1.org/#GSA4082N
If you still have issues , you may need to replace the drive. Cheapest one I could find was $179
http://www.notebookparts.com/products/description.php?II=11272
Might be cheaper to go with an external one if you can get one cheap.
Mar 01, 2009 | Gateway MX7118 Notebook
I want to play mini cds in a standard slot drive in laptop.
You should notice in your cd tray a smaller cutout in the center. That is specifically for mini cds.
Jan 14, 2009 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
Philips DVD+RW SDVD8820 does not recognise burned CD or DVDs
it could be upper and lower filters in registry and system files, use a removal tool called filtercheck 4.6 in CDR-zone.com (goto the forums and search for filtercheck)
after you downoad, run it, click yes to all filters found to remove. close program.
reinstall your preferred burning app (1 prog installed at a time and test burn)
this is to replace the filter entry that was corrupt
Nov 09, 2008 | Computers & Internet
Philips dvd rw sdvd8441 plays dvd's jumpy and stuttery in my gateway notebook computer.
hello m8 are your disks dirty of scratched if not you could have another progam open in background that could be using too much of your system mem or you could have low virtual mem try to increase it or your drive could be on its way out troubleshoot these answers to find out what your problem is eg.. try removing your drive and putting it in another laptop see if it has the same problem ect
Sep 29, 2008 | Computers & Internet
Gateway MX6445 Notebook Logo
149 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
