Question about Sony Cyber-Shot DSC-P32 Digital Camera
Camera is not getting off & also not proceeding further
Even after switch off button pressed it automatically gets on . we need to removethe battery to keep it off. it shows error code as 92.00 on screen
  • amitg Sep 25, 2007
    this got solved by pressing the reset button. but the error was repeating after 1-2 hours & over a period of usage it got rectified.
  • 69 Answers
Error code suggests a problem with the focus drive mechanism.
Posted on Sep 25, 2007
SOURCE:
Shutter button does nothing when pressed halfway, will not focus automatically. It doesn't make the beeping noise, no green box, nothing happens! I can press it all the way and take a picture, but t
Please check if yu did set the camera in AF mode continuous. In that mode, the camera is focusing on whatever is aimed at. Even when the shutter button is not pressed, allowing you to shoot without missing opportunities.
The mode where you see the camera focus when the button is pressed half way, is called single. This setting will conserve battery power.
Look in the manual under Switching between Focus Settings. I can't tell you war page that is for your camera, in mine it is page 100.
On the last pages in the book are all settings for each shooting mode.
Dec 01, 2013 | Canon PowerShot SX160 IS Digital Camera
HOW TO USE SAMSUNG SMART CAMERA
Like every other camera. First charge the battery. Then place the battery and a memory card. Put the rail with the green camera on or next to it, on the green camera loge. (that is the automatic mode) Then switch on the camera. Point the camera to a subject you want to image. Then press the shutter release button half and wait tick the camera has focused. Most of the time you hear a beep or see a light becoming green. Then press the button compete and the picture is made. Only when you are familiar with this, you can go on and work with menus to get other (not always better) results.
Everything is in the manual, that came with the camera.
Nov 26, 2013 | Samsung Cameras
How to change multifunction switch on 04 buick century
STEP BY STEP INSTRUCTION First, any time you work around the steeringcolumn you it is a must to disable the air bag system you will do this my disconnectingthe battery. After you disconnect the battery wait at least 5 minutes before proceeding. 1. Ifyou have tilt remove the tilt actuator arm by firmly pulling straight out. 2. Removethe upper and lower trim covers. 3. Removethe wire harness assembly from the wire harness strap. 4. Disconnect the turn signal andmultifunction switch assembly connector from the SIR system coil connector.This is alongside the steering column there is an 8mm bolt in the center of theconnector that must be removed to disconnect the connector halves. 5. Slide the 2 connectors of the turnsignal and multifunction switch assembly out of the bulkhead connector. With a smallscrewdriver slightly pry between the connectors to release them. 6. Removethe 2 pan head tapping screws and from the turn signal and multifunction switchassembly. 7. Removethe turn signal and multifunction switch assembly from the steering column tilthead assembly. INSTALLATION PROCEDURE 1. Installthe turn signal and multifunction switch assembly onto the steering column tilthead assembly. 2. Screwthe 2 pan head tapping screws and into the turn signal and multifunctionassembly.3. Slidethe 2 connectors of the turn signal and multifunction switch assembly into thebulkhead connector. 4. Connectthe turn signal and multifunction switch assembly connector to the SIR coilconnector. 5. Installthe wire harness assembly (1) into the wire harness strap (2). 6. Installthe upper and lower trim covers. 7. Installtilt actuator arm. 8. Reconnectthe battery.
Mar 01, 2011 | Buick Century Cars & Trucks
Camera doesnt allow me to take photos, lense keeps going in/out
this is most likley one of two things. If you are using a rechargeble battery - it is not keeping a charge. When the camera detects low power it will usually shut itself down drawing in the lens for protection and shutting down. If the battery is gone passed it's time it will not take a proper charge. You will need to replace the battery.
Alternatively you may have a dodgy mechanism - some dirt or even internal component may be broken - in your zoom lens. If the lens cannot extend correctly the camera will automatically retract and power down so as not to cause further damage - for example you camera gets accidentally switched on whilst in the case, and the lens cannot come out.... bring it in for repair.
I know not a solution but hope it helps.
Regards
Thomas
Jul 24, 2009 | Olympus FE-340 Digital Camera
Camera goes to sleep too quickly...is there a way to adjust?
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation after 3 minutes when the camera is turned on (when the lens cover is open and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode. Operate the zoom button or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left on for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 20, 2009 | Olympus ? 1030SW Digital Camera
I can't get the flash to work.
The accessory shoe above the flash has a switch under the plate which detects when an external flash is attached. If that switch has become obstructed by dirt the camera will not fire the built in flash. Check it is free from dirt or corrosion, apart from that, the only other cause will be the flash tube itself is faulty and needs to be replaced. The user manuals for Canon cameras are usually fairly thorough but if you require further assistance your local photo store should be able to direct you to some helpful workshops to help get the most out of your product.
Mar 14, 2009 | Canon PowerShot SX10 IS Digital Camera
Have a big issue with my digital camera. Some one help me out.
This is a big time failure. Take the card out and make sure it has clean contacts. Format the card in the camera. If to no avail go to HP technical Support This may be a known issue even though warranty ids over- but where further help may be available
Jul 05, 2007 | HP Photosmart M307 Digital Camera
Flash Problem
Using the flash When shooting with the built-in flash, open the flash manually. The flash does not pop-up automatically. The flash will not fire if it is closed. The flash will work when it is opened up. When the flash is open, the (flash on) icon or (automatic) icon will appear on the LCD monitor (or in the viewfinder). Flash on: The flash fires in every shot. Automatic: The flash fires automatically. Press the (flash) button to switch between the and flash modes while the flash is open. In some shooting modes, the flash mode does not switch even if the flash button is pressed. Please refer to Functions Available in Each Shooting Mode in the Camera User Guide provided with your camera for more information. When you are not using the flash, close it manually. When the flash is closed, the flash will not fire and the icon appears on the LCD monitor (or in the viewfinder).
Aug 31, 2005 | Canon PowerShot S2 IS Digital Camera
Sony Cyber-Shot DSC-P32 Digital Camera Logo
24 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
