Question about CTX Optoma EzPro 610H Multimedia Projector
Projector won't power up
I have an Acer PD120D projector and when you hit the power button on the projector or the remote the power button turns blue like normal and then the lamp light comes on and then it shuts back off. This is a sudden problem, and I am new on the job and no one knows where the users manual went. Anyone have any ideas where to start on troubleshooting? Thanks for any suggestions.
  • 8 more comments
  • Anonymous Nov 12, 2007
    Same problem with a Canon Lv-7215
  • jugghead3 Nov 15, 2007
    My sharp projector doesn't seem to be getting any power to be powered up. I know that the bulb is bad, but the last time i used it (when the bulb went out) i remember it haveing power. I have recently moved and it has been handled since then. I'm wondering what i can do to regain power to restore my projector to it's full working capactiy. I know i have to replace the bulb, but is it even worth the trouble? Thanks for your advice.
  • Anonymous Nov 26, 2007
    I have a Dell 3200MP and when you hit the power button on the projector or the remote the power button turns blue like normal and then the lamp light comes on and then it shuts back off
  • Anonymous Jan 04, 2008
    my Hitachi CP-S210 Multimedia Projector
    will not power up at all.
    Power sorce is good. Turned off last night, but will not do anything today. HELP
  • Anonymous Jan 09, 2008
    I have a Mitsubishi projector -- it powers up and then shuts off after about 1 minute. Any suggestions?
  • notapro Feb 25, 2008
    At first when you plugged the unit in and pressed the stand-by button it began countdown and as soon as the lamp fired up it shut down. Now it wont even allow you to turn it on as the stand by light wont even stay on or flash, just flashes once and stops. The fans turn on and stay on though.
  • acchapman Mar 18, 2008
    I have the same problem. I sent it to BenQ and it was "repaired" and worked once. Now it doesn't work again. Previously, I suspected it was a crossed wire, but now I suspect it's a faulty temperature sensor. I would fix it myself, but can't find a tech manual anywhere. Anyone with any suggestions or help would be most appreciated.
  • Anonymous Mar 26, 2008
    I have the same issues with the Eiki. I think it is a faulty temperature sensor. We had one overheat and the bulb exploded inside.
  • tilliewillie May 09, 2008
    I have the same problem with the start button. Our LCD projector had been working fine and all of a sudden this problem comes up. I do have a manuel but not in english. I need a solution.
    Maria
  • JJCarlton Sep 28, 2008
    My Hitachi CP-S240 worked great and then one day it just would not turn on... I just spent over 300.00 on a new bulb only to find out that did not fix the problem... Any ideas on a special way to get the power back on to this unit?
I believe this is a problem similar to projectors with metal halide lamps. when the lamp is at the end of its life it does this thing called cycling, where it sparks but theres not enough voltage to start the light. for more info see http://en.wikipedia.org/wiki/Metal_halide_lamp
under the heading "End of Life"
unfortunately, if i'm right about this, it means getting a new lamp, v. expensive...
Posted on Sep 01, 2008
I don't have a solution BUT the "BEST SOLUTION" of your's dosn't help me at all...
When I put in the cable and press the on/off button (ON) on the back of my Benq, the bottons start to light... But notting happens when i try to push the power button on the top.
NOTTING AT ALL... Any Idea?
Posted on Jul 30, 2008
My Hitachi CP-S210 Multimedia Projector
Posted on Jan 04, 2008
  • Anonymous Jan 05, 2008
    Well turn power switch off and unplug the power cord for 1 minute. Plug power cord back in turn power switch back on then press the power button, it should then turn on.
SOURCE:
A flashing red light came on my acer projector pd120d but it did not stay on it displayed the power, temp and lamp
Projector bulbs generate alot of heat. Make sure the vents are not blocked or dirty. Check the fan to make sure it is operating properly. Hope this helps.
Jan 06, 2014 | Acer PD120D Multimedia Projector
Need to reset projector to factory default settings
hold the power button until it beeps or turns on ect but keep holding it and it should reset
Dec 07, 2013 | Acer X1261P - DLP projector - 3D - 2700...
My projector won't turn on, only the power light shows red, the status light is blank. Tried the remote and manually turning it on.
Hello
If the power light is ON and status light is OFF; check if any objects are blocking the air inlet or outlet grill, and remove them if any, and carry out the following.
[1] Unplug the power cord from wall outlet.
[2] Make sure that the projector has cooled off.
[3] Plug the power cord into the wall socket.
[4] Press the power button.
Check whether the cooling fan has stopped. The problem is with overheating itself.
If these does not help you, your projector need service. OK.
Nov 18, 2011 | Mitsubishi HC1500 DLP Projector
Remote won't turn on projector
if the buttons don't work or the leds are not on the projector, it has a power problem. make sure the outlet for the projector is functioning. if still nothing, the bimetal breaker on the projector may have tripped due to overheating. you'll need to remove the top cover. the bimetal has a small red button and is located on the lamp housing. push in the button to reset it. also make sure that the lamp door and the lens cover are completely installed and that the blue switches for them are not broken. this will also cause it not to turn on.
Aug 21, 2009 | Sharp Notevision XG-C50X Multimedia...
Won't power up at all
There is a chance that it is fuse protected inside.
When a filament-equipped lamp fails, it can create a momentary surge; you've probably seen this when a standard tungsten bulb flashes very bright in the process of dying completely.
If you no longer have the User Guide, you can download it here:
http://safemanuals.com/user-guide-instructions-owner-manual/ACER/PD120-_E
It may contain information about any fuse it uses.
Aug 25, 2008 | Acer PD120D Multimedia Projector
Accidently hit the key lock button
Hi
You can overcome this problem by disconnecting the AC power cord, to turn off the power. Then press and HOLD the select button and reconnect the AC power cord.
This should clear the Lock.
Hope it helps
Dec 08, 2007 | Sanyo PLC XU50 Multimedia Projector
Menu settings control inoperative.
I have the same projector and after I thought it is faulty, I finally solved the problem by putting a signal on the input. With out the signal the unit will only switch the bulb on and the menu wont be available.
Hope this help
Nov 21, 2007 | Acer PD116 Multimedia Projector
CTX Optoma EzPro 610H Multimedia Projector Logo
2,654 people viewed this question
Top CTX Office Equipment & Supplies Experts
jasbo
jasbo
Lampdeng.com
Lampdeng.com
Terry
Terry
Are you a CTX Office Equipment and Supply Expert? Answer questions, earn points and help others
