Question about Karcher K 5.85 M Electric Pressure Washer
Karcher 3.99 won't start - Karcher K 5.85 M Electric Pressure Washer
Karcher hds750 pressure washer. The heater won’t fire. heater won't fire.
ok ok the heater won't fire. ya burnt the element out that why it won't fire, get used to cold washes or get it fixed.
Jan 06, 2018 | Karcher Garden
Karcher K2.180 won't start
If you left the gas setting in the carb your carburetor may be gummed up drain the gas put new gas in and removevair filter ur just a little gas down the carb. And see if will start if it does pour a little mechanic in a bottle in the gas tank that will clean out the system.
Apr 21, 2012 | Karcher Garden
I have a Karcher K3.540 pressure washer. Won't take up detergent and motor pulses ever second if vari-lance increased towards maximim. Motor runs ok at lower pressure but can take 1min to start wh
This fault is within the control head, under the detergent valve is a small spring loaded valve that acts to induce the detergent, this will have failed, the shaft of the component breaks off the disk base leaving a small hole in the centre of the disk. This is enough to allow pressure past the component. The machine will pulse when operated and will not induce the detergent. I've looked everywhere to find this part as I have a karcher with the same fault.
Jan 22, 2012 | Karcher Garden
My washer was running fine and it just stopped. Now It won t start again. Any help!! Model K2.97
Check the fuse on the unit. Since this is a electrical unit, it may have also tripped your main breaker on your power source. If using an extension cord, try to use a larger one (size of wire) and shortest as possible. For more info go to www.karcher/co.uk/images/manuals/outdoor/k2 (Troubleshooting problems) .... Good luck.
Dec 04, 2010 | Karcher Garden
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Karcher K 5.85 M Electric Pressure Washer Logo
42 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Tim Venetis
Are you a Karcher Garden Expert? Answer questions, earn points and help others
