SOURCE: Do Not Use A Heat Gun On Your Xbox 360! Send It In To Microsoft! Find Out Why Here!
If you are looking for an Xbox 360 3 Red Lights Fix do not use any guide that suggest a heat gun fix!
Although a heat gun is used sometimes you are better sending it in to Microsoft to do the work!
If you buy any guide with the heat gun fix ask for a full refund you will need it!
If you still want to fix it yourself then click the link below and get
a FREE preview of an easy 30 minute fix that does not use a heat gun:
Xbox 360 Repair
SOURCE: Help Microsoft Xbox 360 Wireless Receiver For Windows, help help
Hello my name is Tim Ehrhart, If the reciever is not lighting up then it is dead, you can try to take it to walmart and exchange it for a working one, they are usualy good at swapping out and if they give you a hard time buy a new one and return it with the old reciever instead of the new one. I hope this helps you.
There is a perfect way to play your old XBOX games in Xbox 360 games.
you are in luck that you bought ARCADE,if you ve core without harddisk yo cannot play,
so the solution is
you need the FLASH UPDATE as above.
you'll need the hard disc drive accessory plugged into your Xbox 360 to play old Xbox games
if its there we can simply play it.
need to follow these
sign in to Xbox Live. Where do you find the update?
To get the update, all you need is to have your 360 connectedonline and logged into Live. Insert an original Xbox game into the360's disc drive, close it, and the update should begin automatically.Being on Xbox Live is the most hassle-free way to make sure you canplay Xbox 1 games, as the system should automatically update each timesupport for new games come out.
If you are not online with Live. How do you get the update?
You have two options - either order an update disc from Xbox.com(which will be sent by mail and incur a small fee) or, if you haveaccess to an Internet connection and a CD burner, you can download theupdate yourself.To download the update yourself, visit this Xbox support page.The download itself is roughly 2.5MB. Simply unzip the downloaded file,burn it onto a blank CD or DVD (it must be the only file on the disc),and insert it into your 360. The process should begin automatically.
