Question about Dell UltraSharp 1701FP 17" LCD Monitor
Dell 1701FP monitor - power buttons blinking - no display - no white screen
Hi guys, I just got a free lcd panel from a friend who broke it recently. Its been dropped and the screen is cracked, but when I plug it into my laptop as a secondary monitor, I don't see anything on the broken lcd panel. The power buttons just kinda blink randomly - green for the power and amber of the brightness contrast buttons. I am pretty good at experimenting with electronics, so I did open the case up, and found out that the inverter is dead. For this reason, I have another inverter borrowed from a CCFL kit, and I found out that the tubes to burn, and you can see the white glow. But now that the screen glows, and I have the controller board hooked to my laptop as a secondary, when the board is powered up, I still don't see any image, and the LED's on the power button controller just blink randomly. Anyone got a remedy or solution for this?
  • 1 more comment
  • Anonymous Mar 14, 2008
    My dell LCD monitor screen is just blinking(power light) can I get help just for troubleshooting from anyone on line?
  • rbingaman Nov 01, 2008
    I have the exact same issue. No one on the Web seems to have an answer besides buy a new monitor. Bummer.
  • jspagnol Mar 14, 2009
    Hello, I have the same issue as joel joely. The monitor I have is the Dell 1701FP (black) and it was donated to me. It worked fine for about 6 months and then started acting as if it were going into sleep mode but I could not get it to come out of sleep mode by moving the mouse or pressing keys on the keyboard. The green light stayed on but the further right light turned amber AND the power button would not turn it off. Although it is not a fix, my work around was to unplug it and plug it back in after a few seconds and VIOLA the screen came back on and I could see my desktop again. I'm still researching what causes this and if there is any permanent fix.
    Scholar:
  • 29 Answers
Solution to a blinking orange power light indicator.
Checking procedures.
1. Check the fuse on the inverter board labeled F1. If it is opened then your inverter board has a problem. That's why the fuse is opened.
2. Remove the white wide cable connecting the main board and inverter board. Next plug the D-sub cable and power adapter and test. If the 2 green light indicators are solid green then your problem is positively coming from your inverter board.
Solution in fixing the inverter board:
In my case, the fuse was opened. So I first resoldered all the legs of the 4 transformers. Eight legs each transformer. Resoldered also the capacitor at the back of the inverter board. Checked the 2 diodes labeled (D3 and D13). One of them was shorted. So replaced it using Radioshack 3A 400piv. It is quite bigger in value but I just want to make sure it can handle the load of current.
Tip in checking a diode, it should always open using a digital tester.
That's it. re-assemble then test it again.
Roan
Triangle Tech Whiz
Posted on Jul 13, 2009
  • Roan Jul 13, 2009
    I forgot to mention on how to fix the fuse.
    3 ways:
    1. The cheapest is to use 3 fine strand of wires and twist them, then solder them on top of the fuse.
    2. Use a car fuse ( low amperes).
    3. Buy a replacement fuse from Radioshack or any electronic stores. Solder it.
    Roan
Hi my name is joel joely from etech vanuatu limited. my dell LCD monitor is just blinking power light on with orange light and also power switch not working if turn it on or off no display on screen.
my email address is joel@etech.com.vu
thanks
joel
Posted on Sep 11, 2008
White screen
The white screen you are getting is it just right after turning on the computer? If yes it means that you were not able to see the Dell logo correct?
Try connecting an external monitor thru VGA. While monitor and laptop is on with white screen please do this. Hold down Fn key then press F8 at the same time. This will toggle the display from the laptop to external monitor. If laptop displays to external monitor means that laptop LCD needs to be replaced.
If you do not have an external monitor try this.
While laptop is OFF. Do this. Hold down the D key then press power button at the same time.
Check if the laptop will display colors the whole screen. If you still see white screen then LCD needs replacement.
LCD mean LCD panel or the whole screen together with LCD cable and Inverter.
Hope this helps.
Mar 25, 2011 | Dell Inspiron 1525 Notebook
I have lost the original power supply for my dell 1701fp monitor. I have a power supply that I think may work as a substitute until I can replace the original. I need to know, what the acceptable voltage...
What ever you use, it must be REGULATED power supply that will maintain 14vdc output, rating at 3A. These regulated power supply can easily maintain the output voltage within +/- 5% with input AC voltage range from 100~240vac.
Linear regulator power supply may not work since it has slow response time to regulate the voltage.
http://www.amazon.com/dp/B002D1E8NE/ref=asc_df_B002D1E8NE1376531?smid=A3IZHOEADOGAP0&tag=dealtmp386264-20&linkCode=asn&creative=395105&creativeASIN=B002D1E8NE
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 06, 2011 | Dell UltraSharp 1701FP 17" LCD Monitor
My LCD monitor is blinking green but no display is coming, some days back after blinking 15-20 minute display comes. But now display not come
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, falied inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 09, 2010 | Dell UltraSharp 1701FP 17" LCD Monitor
Dell Blinking Power Light
Hi There,
I have worked on several of the Dell 17" and that is almost always the Capacitor problem.
The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
If you can get inside the frame of the monitor, and disassemble, you can find the caps by seeing a bulge on top, or even a rusty looking material on the top. Be VERY careful around the high voltage section if you do go inside.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
Apr 04, 2009 | Dell E153FPf 15" TFT LCD Flat Panel...
1701FP display problem
Try to do the factory reset. It is on the pop up main menu on the screen by pressing the screen button.
Thank you,
Jan 12, 2008 | Dell UltraSharp 1701FP 17" LCD Monitor
Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Oct 22, 2007 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor (Dell 1701FP) flickers, flashes and goes black
Just to check - when the screen is black- can you see any image- in its un-illuminated state. To do this look sideways along the screen not straight at it. I suspect this is an inverter problem. Whether or not this is repairable I know not- depending on your local repair facilities Perhaps DELL can suggest a local agent.
May 16, 2007 | Dell UltraSharp 1701FP 17" Flat Panel LCD...
Everything has a yellow tinge.
Have you tried giving it a good tap on the side? Hey its worked before. Have you tried hooking it to another machine to verify "yellow." Was it yellow on your friends computer? How old is the monitor? Good Luck, Tim
Feb 07, 2007 | Dell UltraSharp 1701FP 17" Flat Panel LCD...
Lines across screen
Is it sort of rolling almost.
If so you have a few bad capacitors in the power supply that need to be replaced.
If you dare to venture inside you should see 1 or more buldging caps. (bowing upwards on the top)
If these start to fail, then they will interupt the correct flow of power and cause this problem with your panel.
Easy to fix if you are electronically minded, if not, take it to your local TV tech and it shouln't cost that much to have repaired.
Remember, inside these monitors is high voltage that can kill, even if it's not plugged in.
Dec 10, 2006 | Dell UltraSharp 1701FP 17" Flat Panel LCD...
Computers & Internet Logo
1,488 people viewed this question
Clive
Clive
Alun Cox
