Ever since I switched from Bell Sympatico DSL to Rogers Cable Internet, my laptop refuses to connect by wire to the Internet via the router. However, I can connect to the Internet via the router on the PC.
At first, it was not a huge problem. But these past few days, connectivity has been terrible, going linkdead every 15 minutes. Sometimes the wireless light would just be off... and it always says my network adapter is not installed, even though I have done nothing to disable it (except to repair the connection).
Was there something I had to do when switching from one ISP to another? Because it's as if my laptop doesn't recognize a wired connection anymore, even when connecting directly from the modem to my laptop.
So far all I've been doing is rebooting both laptop and router... but it's gotten so unreliable, and only adds to my aggravation.
-   I am on Shaw Cable service (256kbps). My ethernet-connected PC works fine (Celeron 500-512MB RAM-Windows 98SE). My old Pentium II-266MHz with 64MB RAM also running Windows 98SE on a wireless connection doesn't. It will work fine for about 10-15 minutes, then I cannot connect to the Internet unless I reboot it. Surfing via a browser fails first. I can connect to secure banking sites for longer. I can also access file sharing with the wired PC after losing Internet connectivity. I have tried two different brands of routers and two different brands of PCMCIA wireless cards. I have tried it with and without encryption. I am currently using the MR814v2 firmware 5.3_05.-   mentorron
There are a few things we can try.. First I want you to reinstall your network adapter drivers, make sure they are the most-up-to-date.
Then I want you to completely re-setup you internet connection from the beginning again, using the internet connection manager and connection wizard with setup a home network...
I want you to Check your Ethernet Cable connections.. better still get a NEW Ethernet Cable..
i hooked up the d-link (WBR1310) it used to work fine. I just moved to a house I can't get it to...
(More)
i hooked up the d-link (WBR1310) it used to work fine. I just moved to a house I can't get it to transmit the internet. The network shows up but no internet. I reset the router but no luck, any suggestions?
I can't play games like counter-strike online because of my routers firewall. I even turn on the...
(More)
I can't play games like counter-strike online because of my routers firewall. I even turn on the UPNP. How does I make it work?
my computer guy at work set my router up with a pass word and i do not have it and want to set up an...
(More)
my computer guy at work set my router up with a pass word and i do not have it and want to set up an ipod touch. how can i find the settings
