This nano is about 2 years old but used only once when it was new. It has been on a USB power hub to keep the battery charged. I hooked it up to the pc yesterday load 1 song to it and noe the LCD is just white. I did the 5 Rs, I've reseated the LCD connecter, disconnected the battery and still a white screen otherwise it works????
SOURCE: IPOD automatically disconnects
the settings in itunes need to be changed so that you can sync manually
SOURCE: Frozen iPod Nano
FOR ALL PERSONS WITH THE FREEZING IPODS AND CANT TURN OFF HERE IS THE SOLUTION
to reset your ipod
switch hold button off and on again then press the menu and the center button simutaneausoly until the apple logo appears and goes bright and there .has been reseted
rate the solution plzzzz thank u
Press and hold the center button while holding down the menu button. This will reboot your Ipod. Check your IPod cable to see if its shorted. If might have transferred a song and crash in the middle of the transfer.
SOURCE: charging ipod nanon 4th gen on bose sound-dock
http://www.scosche.com/products/productID/1694
Click on the link above for the solution for your problem
