I have a 12 year old big screen projection tv my picture is out of line. when i go to menu then convergence adjust the cross that is normaly white has the blue and red lines beside it.I have the original remote but cannot figure out how to adjust the lines manually.Also sometimes if i leave the tv off for a few days then turn it on it will be fine for a day or two.I tried to look the manuel up on line but had no luck.
I have had my tv since 2002. Just a few days ago it started acting up. When I turn on the tv. The screen looks curved inwards. Almost like you are looking inside of a bowl. The picute looks 3-D. I can see the images in red, blue and green. What can i do to fix it. Help Please!I have had my tv since 2002. Just a few days ago it started acting up. When I turn on the tv. The screen looks curved inwards. Almost like you are looking inside of a bowl. The picute looks 3-D. I can see the images in red, blue and green. What can i do to fix it. Help Please!
I have a samsung projection tv and the convergence is off! When i tried to manually adjust it wont line up at all!I have a samsung projection tv and the convergence is off! When i tried to manually adjust it wont line up at all!
i have that same problem with mine i tried to adjust the lenses inside the tv but that didnt work either i have that same problem with mine i tried to adjust the lenses inside the tv but that didnt work either
When I turn on the tv. The screen looks curved inwards. Almost like you are looking inside of a bowl. The picute looks 3-D. I can see the images in red, blue and green. What can i do to fix it. Help Please!When I turn on the tv. The screen looks curved inwards. Almost like you
the tv has the picyure and then a blue colored almost ghost image out beside everything on the screen.the tv has the picyure and then a blue colored almost ghost image out beside everything on the screen.
I have a similiar problem however along with the blue halo I have alot of red. I have tried to adjust the colors with remote and withthe converge but, still alot of red and blue halo, any help would be appreciated.
CharlotteI have a similiar problem however along with the blue halo I have alot of red. I have tried to adjust the colors with remote and withthe converge but, still alot of red and blue halo, any help would be appreciated.
Charlotte
picture looks offset...when i first turn it on the picture looks yellow and green almost like its set to a horrible tint....but the picture in this condition is fine....not offset or blurry at all...cant fix it with color settings....but if i turn it off and then back on the color is back to normal but the picture is a tad offset again
An expert that got 20 achievements.
An expert that got 10 achievements.
An expert that got 5 achievements.
Hitachi Master
Re: picture looks 3D
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
President:
An expert whose answer got voted for 500 times.
Master
KIT10 $29.50 Repair Kit for Hitachi convergence Chassis DP-14G KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors: http://www.eserviceinfo.com/ http://www.digitalhome.ca/forum/search.php http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220 http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
Screen looks 3D
TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Please do us a favor and rate this solution after reading.
Screen looks 3D
Screen looks 3D
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Screen looks 3D
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Screen looks 3D
Screen looks 3D
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include.... •Screen looks 3D •Colors don't line up •One or more colors can't be adjusted when using the convergence menu. •Screen is bowed or warped. •TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
CONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Charlotte
I have the same problem. Have you received any helpful tips?
my screen is curved upwards
