Question about Samsung ML 1710 Laser Printer
Blank stripes on page left to right
A new cartridge that printed fine for a few days. Then, something strange happened... Can't recall exactly... then all pages have 3 white stripes. I have shaken the cartridge a few times, held down the button, shut it off... What next? THANKS!!
  • 691 Answers
If the blank stripes go up and down the page (vertical) then it sounds like the laser lens has simply got toner on it. remove the toner and photo conductor units. Look for the glass panel that covers the laser lens and simply wipe it off with a cloth. Some machines incorporate a lens wiping pad that can clean the lens without taking out the parts. I can not remember if the 1710 does or not.
Posted on Sep 16, 2007
I also have the 3 HORIZONTAL fated stripes.
Any ideas?
Posted on Feb 07, 2008
I have a LexMark C752L. when i go to print first thing in the morning i get a 3/4" verticle stripe on the right hand side of the page. With each page i print this stripe gets less noticable until it...
Based on your description I would assume this has something to do with the Transfer belt, where in the cleaning blade of the belt is already worn or defective.
You may need to replace the printers transfer belt unit.
For further diagnosis and assistance, please contact Lexmark Technical Support.
Regards!
Sep 22, 2011 | Lexmark C752 Printer
HP Laserjet P1006 prints with blank white stripe down left side
Clean the Corona Wire carefully to remove any residue. As the charge on the wire is effectivley masked it cannot deposit any toner to the page and will result in a consistent white vertical stripe.
Aug 29, 2009 | HP LaserJet 1022 Printer
Cannon multipass F60 scanner/printer striped color printing
What you have is a dried up color cartridge. You can try to use the <clean print heads> in the diagnostic tools section of you priner software. (usually, just try to print something & the window will appear) Sometimes you have to clean heads, then print test page like 2 or 3 times before it clears up. If that doesn't correct it, don't worry. Have your color cartridge filled (staples, office depot, & other stores do it cheap) - or - replace it with a new cartridge. You may have to run the clean print heads program after installing a new cartridge, but this will definitely fix your problem.
Jul 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
Samsung CLX-2160, keep getting faded toner stripe down page. changed toner numerousof times The same problem occurred for me after only 300 pages. The black color on the all prints is faded out on the...
Everyone will tell you that it's the Imaging Unit - happy to say that's not true. If it was the imaging unit the colors would not come out right either. I bet if you print a test page that all the colors come out fine across the page. It's only the black.
Also - if you replace the black toner cartridge, or reinstall your printer and drivers like some people will tell you - still no results.
The problem is in the black toner cartridge PATH inside the printer. Something has jammed it up a bit. Try taking out the black cartridge and blowing firmly into the small hole at the bottom of the spout that looks to have a sponge inside. Use a straw and make sure your air blown is dry. Then lightly tap the cartridge a few times. Then use the straw and once again blow very firmly inside the receiving path (inside the printer) for the spout on the cartridge. Make sure you are blowing into the spout path at the bottom - not the gear drive path in the middle - as that will not do any good.
Replace the cartridge, warm up and print another black and white page. You should see that the faded out section is gone or diminished in size. If it is not gone, simply repeat the above steps until it is gone. You will see that the faded out strip gets smaller and smaller each time until it's gone. I had to repeat five times, but eventually got it corrected. Now prints like brand new so don't get discouraged.
Loki
May 18, 2009 | Samsung CLX-2160N All-In-One Printer
Intermittent blank stripe down Right Side of page
Open the top cover, lift up the PCU lever & remove the PCU. Rotate the carousel (Toner holder) by hand and check that all of the toner levers are locked down fully. Check if any of the toner levers are loose and possibly moving as the drum is rotated. There is a small clear plastic flap below each cartridge, it is possible that one is fitted incorrectly or even missing allowing toner to leak past and fall on to the laser lens thereby blocking the laser and causing these symptoms. Hope this helps.
Feb 02, 2009 | Epson ACULASER CX11NF All-In-One Printer
HP LaserJet 2100tn prints ok but with 3 lines of strange characters over image
Is your transfer roller clean?
How does the drum look on the toner cart?
Is the fuser getting bad?
Would you consider this an old image that is ghosting?
Jun 24, 2008 | HP LaserJet 2100 Printer
Printer prints first page with strange nonsensical characters
I would move the printer to another computer. See if the problem follows. I have seen the issue a few times with issues in normal.dot but also in other office applications.
Problem I'm fighting with on my 1720 is its printing extra pages between pages. basically print a 5 page document and get an 8/9 page final with the extra blank pages. Think its a user error but could be machine related. going to try it on another PC and see what happens.
May 28, 2008 | Dell 1720dn Laser Printer
Black Toner Problem
You just might have a faulty black toner cartridge think back did the problem arise when you installed the new black cartridge. Also is the toner a original if not change for a original.
Hope this Helps
Thanks J
Dec 31, 2007 | Samsung CLP 300 Laser Printer
Stripes on printout MD5000P
This happens alot, iteithermeans your inks running low, your inks too new, or its a low quality printer.
My suggestion would be to check your ink level, and if its fine, print out a few pages, then see if it helps.
Dec 29, 2007 | Alps MD 5000 Thermal Printer
Black stripes ove the page
Try cleaning your ink nozzles or ink jets. It sounds like you have a plugged nozzle or two. Your printer program should have maintenance options that allow you to test for plugged nozzles and clean them.
In control panel, open the printing/fax icon, right click on your printers icon, left click properties, then on the bottom of the page the panel that opens you will see a button that says printing preferences, and that should open your print program.
Dec 15, 2007 | Epson AcuLaser C900 Printer
Samsung ML 1710 Laser Printer Logo
511 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
