Home | Venta | VS 100 Humidifier | Unit only works ups...
Venta VS 100 Humidifier
Problem for Venta VS 100 Humidifier
Unit only works upside down!
By libero1010 on Apr 07, 2009
I drenched the unit. Took it apart to allow it to dry. When I put it back together it wouldn't work. Took it apart again and plugged it in while apart (bottom of unit oriented correctly, top part of unit upside down). It worked, but when I turned the top back rightside up, it clicked and quit working.
Is there an orientation switch that's getting tripped? What else might be clicking and shutting it off?
Solution #1
posted on Jul 03, 2009
Not Rated)
rickpepper
Rank: Guide
Rating: 75%, 1 votes
there is a water level next to the ocilater make sure that the canal is clean. try some water and vinegar
Was this helpful?
Yes
No
Popular Solutions for Venta VS 100 Humidifier
Questions and Unsolved Problems for Venta VS 100 Humidifier
Do you recommend Venta VS 100 Humidifier?
Answer
Answer
The water in my tank completely spills out in 2 minutes - what am I doing wrong???
Answer
I own a Trane 4TEE air handler and I am hook up a HE360 Honeywell Humidifier what terminal on the... (More)
Answer
I have a MAF-1 replacement filter. It is circular and has a red coloring on one side. Which side... (More)
Answer
does extractor fan have to be wired to a light switch to work, I live in a flat and the outside... (More)
Answer
I need the part the hooks the new filter to the humidifier, is like a round white part,
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Venta VS 100 Humidifier:
Top Humidifier Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Humidifier Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
