Question about Toshiba Satellite M30X Notebook
Screen brightness keeps going down.
Hi, Just wondering if anyone can help me with this problem I have started having with my Toshiba M30 Laptop. Whenever it goes onto sleep mode when you turn it back on the screen brightness has always turned down to the lowest level. How can I stop this from happening? It has only just started doing it.
  • Anonymous Mar 24, 2014
    I have a toshipa lap top and it had problems with the screen ( it gets bleard) and when you apply pressure to the screen it used to get ok.....and there was a little circular spot wich had more brightness than the other parts of the screen. But yeterday that little spot overheated very higly and i have to turn off the pc......is my screen competly ruined? and how can i maintain it. please dont say by throw the screen.
    President:
  • 2,961 Answers
Its because it has gone into power saving mode, you need to go into the power/battery settings and set the brightness at 100% and then choose that setting as default.
Posted on Sep 06, 2007
SOURCE:
My Toshiba Satellite S75D-A7272 laptop has always had a problem with getting it out of sleep mode. Is there a fix for this?
Sleep or standby mode should allow your computer to conserve energy yet respond quickly to power back on when you need it. Most Toshiba laptops should exit sleep mode if you press a key on the keyboard or use the trackpad mouse. If the lid was closed, opening it should also wake up the computer. If none of these methods work to bring the computer out of sleep mode, you may have a power issue or software glitch. Causes Insufficient power can cause this problem, so try plugging in your Toshiba laptop before attempting to wake it from sleep mode. If this does not immediately fix the issue, your problem is more likely a software issue. If your laptop was shut down incorrectly prior to the sleep mode incident, it may be stuck on a blank screen that makes it appear to be in sleep mode when it actually is trying to start up.
Indications Press the power button for a few seconds to see if your computer will wake up. If it does, the laptop was not truly stuck in sleep mode, but rather went into hibernation mode. If your laptop is truly stuck in sleep mode, you may be able to force a shutdown by holding down the power button, but when you power back up it will move right back into sleep mode. In some cases, the power button may not shut down the computer from this mode at all.
Solution The best way to solve your Toshiba's problem is to completely remove all power from the laptop to ensure a fresh restart. Close the laptop's lid, turn over the unit and remove the battery. Also remove the power adapter cord from both the laptop and the wall socket. Open the laptop lid and press and hold the power button for approximately 20 seconds. This will drain any stored power in the backup battery. Wait a few seconds, then put the battery back in, plug in the laptop and press the power button to turn on the computer. It may start up with an error screen; in this case, select the option to start your computer normally. If the error recurs, start the computer in "Safe Mode" to see if a program running on your computer outside of the basic Windows operating system is causing the problem.
Further Help Sometimes this issue also requires holding down a specific key, such as "F8," when you restart. If the basic power drain and restart process doesn't work, you can use Toshiba's support website to look up further information for your specific model. Just click the "Product support" tab and enter your laptop's model information, then read through the support bulletins listed for your particular Toshiba model. Toshiba also maintains a support hotline at Call us : +1 850-610-1013 https://www.instantprintersupport.com/toshiba-printer-support
May 28, 2018 | Toshiba Computers & Internet
Laptop screen goes off and then to sleep mode
go into your control panel and under power saving turn off the sleep mode settings also check power saving sleep mode settings in bios by pressing f2 at boot also check battery options in security settings hope this helps and yes hp techs are just high paid plumbers reading memos from screens so there not usually much help lol
Mar 01, 2013 | HP Pavilion Computers & Internet
M305d-s4829 stuck in sleep mode
go to power potion and disable sleep mode
Jan 30, 2013 | Toshiba Satellite Computers & Internet
Toshiba satellite m30 bios password
To reset the BIOS password read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Jan 11, 2011 | Toshiba Satellite M30-S350 Notebook
Computer goes to sleep before it even starts up
Hi there, it appears as though the Power Options are set too short a time and the PC is going into sleep mode. Go to Start menu/Control Panel and look for Power options. Set them all to "never" This will prevent her PC from going into sleep mode. Good Luck.
Oct 26, 2009 | Dell Dimension 4600 PC Desktop
Laptop apprears to go into sleep mode while I'm using it
To my knowledge it could be hibernate mode for laptops to save battery life when not plugged into the wall, try pressing the power button, my Compaq did that too. Also don't hold down the power button as after 5 seconds it just shuts off the laptop, unless you wanna do that.
Jan 14, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Toshiba Satellite M30X Notebook Logo
694 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
