Question about Toshiba 32A60 32" TV
Color line across the center of a black screen
My Panasonic T.V. started yesterday with a 2 inch line across the screen where I could see colors and the rest of the screen was black. A few minutes later it changed to a wobbly picture with a lot of wavy lines across the entire picture. It may work fine after that or go back to the 2 inch line across the screen. What is the problem?
  • 6 more comments
  • Sherry2 Sep 15, 2007
    I appreciate your help. I have not taken it in to be repaired yet. Is this a costly repair or do you think it's not worth having it repaired?
  • main2jib Jan 19, 2009
    Black screen with a thin line running across the middle. The sound is fine, just no picture.
  • Anonymous Jan 31, 2009
    Black screen, with a line going through the middle. I am getting sound but no full screen.
  • Anonymous Feb 17, 2009
    same problem but it first started with a line about 5 inches from the top goin all the way across now just some green line across center.
  • Anonymous Mar 02, 2009
    I have the same problem. Was working fine last night but then when i turned it on in the morning it only showed a line about 1 pixel wide across a black screen. Pretty sure its a dry solder.
  • chromy Apr 14, 2009
    I have a line threw the center of the screan. I have no picture, and no sound and voices. I have power to every thing. Please grt back to me. Thank you. [email protected]
  • chromy May 11, 2010
    My tv is a NetTV. The line is a green line that goes on. The line is in the center of the tv screan. Do I go in side the tv to fix this? Please let me know.
  • racin510 May 11, 2010
    I have had this colored line across an otherwise black screen. Now the screen has gone completely black unless a control on the flyback transformer is changed to produce the line. is this still due to solder joints or is there also a problem with the flyback?
I had the same problem. My TV has 2 to 3 color lines jumping up and down. But as soon as I strike on the body, the picture resume again. I take an electronic technician and soldered all joints with soldering gun, now it is OK. So the problem is the breakage of lead joints and you can confirm by striking the body with hand to change the color lines to picture.
2nd 145
Posted on Jul 17, 2009
  • 372 Answers
Hi. this is caused by dry solder joints on the frame o/p IC. Resolder all legs of frame chip. Should sort that out.
Posted on Sep 12, 2007
  • chris pursloe
    chris pursloe Sep 15, 2007
    Hi.
    If you are in the UK probable price £40 to £60.00
    I cant comment for other countries.
SOURCE:
I have a Vizio M701d-A3 with single line across the top half of my screen, it appears over top of the menu when displayed. The line is not black but changes color with the picture. What's the problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 07, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
How do I fix my Sharp tv from right side to center there's a half inch black line 9 inches down from top on screen and it changes color depending on background and UNDER the line the image is blurry a
If this is done with every input of your tv and also with tv channels this means a bad circuitboard .You can find on ebay one and mod it yourself. Its not such a difficult thing.
Nov 26, 2014 | Sharp LC40E67UN TV
Tv screen is black except for 1 horizontal line of color
The line is there because the vertical deflection unit - the one that spreads that line across the entire screen to form the image - has failed. Replacing it is a job for a professional, or at least an experienced amateur, and the parts will be quite difficult to find for such an old tv .
May 28, 2010 | Panasonic CT-36DV60 36" TV
Red line across top/blue line across bottom of screen
Adjust your convergence. Under menu I think its the last choice at the bottom of settings or picture menu
May 05, 2009 | Sony KDF-50E2000 50" HDTV
Lines across screen
If the lines are slightly diagonal and in red, blue and green you have a problem in the ABL circuit. if the lines are only one color you may take the front grill cover offf and remove the panel. look fro the black box 2 inches square with 6 little controls on it. 3 are for focue 3 are for screen the middle on of the screen is the green adjustment the other 2 should be labled r and b respectivly. what ever the color of the line turn the control labeled screen and r b or g for that color ever so ligtly counter clock wise.
Mar 30, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Line across middle of screen.
The line of color is due to a failure in the vertical circuit. The main suspects are the vertical Ic AN15525A and/or capacitor c308 [email protected]
If you have the capacity to do so, you should check the other electrolytic capacitors in the vertical circuit which are USUALLY located near the vertical IC in most cases
you can purchase the part at
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5760279&smodel=CT32SL15N
or mcm electronics
Mar 13, 2009 | Panasonic CT-32SL15 32" TV
Color band lines scrolling across my screen
That sound like your picture tube is doing. Also if you have any speaker near the tv it will effect it because of the magent.
Dec 22, 2008 | Panasonic Televison & Video
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Toshiba 32A60 32" TV Logo
903 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
