Pansat2500 remote my remote is jam on pansat2500 can you help me please
  • Anonymous Apr 03, 2009
    my tv frezz up
    Genius:
  • 1,153 Answers
Does anything work from reciever? If so then remove batteries and open remote and clean pad and put together. Make sure you press STB button
Posted on Sep 07, 2007
Hi there, I have a Hannspree XV HDTV, product # JT02-37U1-000G, it stuck in the volume adjustment screen, my remote(not original doesn't make it work,also the button on the tv too).please help
Unplug the television from mains first take the batteries out the remote then plug the tele back and switch on from the television see what happens if it goes back to normal the you have the volume bottons jammed on your remote control
Nov 16, 2017 | Hannspree Televison & Video
Philips 21pt1654 58
Hi, are you sitting on the remote? does the TV have analogue/manual control buttons on itself, are they jammed in or damaged in any way? Are any of the buttons on the remote damaged in any way?
To rule out the remote, remove the batteries, if the problem still occurs it's the TVs problem, if it doesn't it's the remote.
Mar 21, 2014 | Televison & Video
Hi, i have this remote. it works on my tv before. but now it doesn't wprk any more. please help?
Hello, Thank You for visiting Fixya.com!
Allow US to help you with your remote issue.
Many times batteries cause this issue, over time the buttons often get stuck and cause the rmeote to jam. What this means is more then one of the Button pads might be pushed in causing the remote to JAM and not function.
You can take a phillips screw driver open up the unit and clan the button pads, you also can make sure your using good batteries as well.
Many cases with these universal remotes or, original remote the pads under the buttons get jammed or dirty. A remote generally does not just die. There are many causes. Allowing a dead battery sit over time on a remote can wear down the connections on the remote. Make sure you clean these battery connections, Make sure you flex the spring inside and make sure the battery is seated in the correct position.
You can also read my Tip on how to fix a dead remote HERE
I hope you like my idea's and tips on how to resolve your problem. We hope you found this Very Helpful today, Thank You for the oppertunity to help.
Regards
Edwy aka rulds2008
Jan 24, 2011 | Philips Magnavox REM-350 Remote Control
Master Mechanic garage door opener has lost it's range. Only works when remote is very close to garage door. I have replaced the batteries in the remotes, reprogrammed the remotes and disconnected the...
Sorry to read about your problem, I hope this helps you out.
either 2 things, you have a defective receiver, or their is a outside interference jamming the signal. this is a common problem, in some areas.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Kitchen Ranges
The tv is jammed. Remote is fine but have pressed the wrong button
It sounds as though you might have just accidentally pressed a button and changed the remote into an incorrect mode for example, tv, or aux modes. This would in fact prevent the remote from successfully working with the DISH Network receiver. If this is in fact the problem, then the remote simply needs to be put into "SAT" mode, once its back in SAT mode you will then be able to change channels, select menu, power receiver on and off, etc. The "SAT" button is labeled & in the upper left hand corner of the remote to put the remote back in satellite mode, please just press that SAT once and then release, the SAT button should briefly light up red & then the light will go out, you should then be able to use the remote again, to ensure remote was successfully changed back to SAT mode, you can press select or any other button you chose & as long as the SAT button lights up when you press another remote control button- then your all set to go & everything should be working once again! I hope this helps -please let me know if there is anything else I can help you with!
-Kirstie DISH Network
Oct 01, 2010 | DISH Network IR Remote Control
What are the codes for a motorola starchoice receiver?
i have a Trutech television, and i am trying to program the remote which is a Phillips. Now i can get as far as pushing the set code button, and continuously till the tv turns on. The jam appears when it is time to SET that code. Please help, i can't take one more episode of Yo GabaGaba!
Mar 19, 2010 | One For All URC-4021 Remote Control
Remote such automaticaly
Looks like a jammed "channel up" (P+ , CH+ or similar) button on your remote. Try disassembling the remote and cleaning the rubber pads with some ethyl alcohol and cottonwool. Also clean the pads on the circuit board which come in contact with the buttons pressed.
If your TV set has channel up/down buttons on the front panel, it could be that one of these is jammed instead (could also be something else, i just suggested the most likely solution i could think of).
I hope this helps somehow...
regards
3rq8 (Triarcuate)
Jul 23, 2009 | RCA Universal Remote Control
Remote quit working.....tv comes on and goes off by itself at various times
Sometimes Buttons on remote control "stick" underneath the faceplate. It's possible the on/off button is jammed. A lot of times when a button is jammed the other buttons fail to work.
Could also be the reason you needed to replace the batteries with a button being continously pushed will drain the battery life.
Push every button on the remote and kinda wiggle each button while pushing to possibly see if its stuck.
Hope this helps.
May 26, 2009 | Norcent Technologies PT-4291HD 42 in....
95 people viewed this question
 Grubhead
Grubhead
