How can I separatte the ****** handle of my Epic 6500 fromthe hose? I have a wrapped pair of socks stuck in it at the handle
There are two different styles of hose for the 6500 vacuums. Please be careful when you take the handles off and also when putting it back togeather. To remove the handle there are two screw caps that you need to remove to get to the screws. You can do this with the tip of a knife or something similar inserted under the edge of the screw cap and pry up. The screws can either be a Phillips head or a torx bit. Remove the screws and then separate the top part of the handle from the bottom. Make sure to notice the position of the wires and do not unplug them from the switch or the contact block.The contact block at the hose end of the handle has two contacts that transfer the power from the hose to the handle and will bend out of shape if you are not careful. To remove the contact block, use a flat head screw driver under the block and pry up. On the older models, the handle will slip right off. If you have a newer model, there is a handle retainer at the base of the handle and will push out with a screw driver. It only goes one way and
the handle will slip off.
To replace the handle just reverse the procedure. Good luck.
