I have 2 sonicwalls on 2 locations.
the hq site has tz190 with static ip with sonic enhanced os
the remote has tz170 with dynamic ip with sonic std os
vpn config has been setup and i'm able to ping computers on the hq from the remote site.
vpn log says connected on both sonicwalls.
however, when i look up computers from the hq site using pcs from the remote site, I can't see anything.
please help troubleshoot vpn config
1. Check the manufacturer's web site for update this could be the issue Most new router modem off the shelf have not been update by the manufacturer due to delay engineer changes and may only become available after shipment to the retail stores. Here is there site if you can connect through a friend or relative connection and download the updates for your unit. the update also may be able to go onto a 4gb flashdrive. http://www.sonicwall.com/us/support/3141.html
This is not directly possible to do with a TZ170 as the device will only allow configuration for 1 static or dynamic IP at a time for the WAN port. However this being the case, I suggest setting the SonicWALL up as a perimeter firewall and place devices that require the other public IPs form the additional IP range behind the TZ170. Basically the SonicWALL becomes the gateway for the other IPs needed as long as the range of the IP block is contiguous. This would involve using the 4 ports of the LAN on the back of the TZ170 to connect directly to the other devices or if it is more then 4 devices, using a switch connected to the LAN side of the SonicWALL to provide connectivity to the multiple devices behind it. Most TZ170 are licensed for 10 connections on the LAN side and if you require more then 10, additional licenses will need to be purchased. I would be careful pushing too much traffic through a TZ170 as it is designed for Small Business use and will quickly become overloaded with too much traffic causing high latency/traffic bottlenecks and in extreme cases connections being dropped. This is especially true for multiple VPNs.
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
Need more info, " I want to configure two VPN for different customers but both at the same host computer." You can havemultiple VPN`s, and port forward to anyewhere on the inside or dmz.
Need to know what you are trying to achieve. madmac
Hi Rajmeet,
Here is the documentation on the SOnicwall TZ170 the detail configuration can be found on page 211. Please let me know if this helps you and if youhave any other questions.
http://www.sonicwall.com/downloads/SonicWALL_SonicOS_Standard_3.1_Administrators_Guide.pdf
