Question about Magellan RoadMate 700 GPS Receiver
Keeps seeking but no GPS positioning
Hi I purchased a brand new Roadmate 700 two years ago. Its tracking system keeps seeking GPS signals ie showing little satellite in corner, but nothing progresses. it can still locate using the view feature, but no maps or sound or visuals associated with GPS. I tried resetting it using secret screen, reset data, but nothing works. Any help?
  • 50 Answers
Get a new unit like any magellan mastreo series or roadmate 800 ,i had a 700 they start having alot of problems after i did my research on here.
Posted on Jan 10, 2008
SOURCE:
Magellan Roadmate 1412 won't track satellites
It might mean that the signal is disrupted. Might be a software glitch. Try going outside, get a clear view of the sky. Then reboot/reset the unit. Hold the switch to the reset position or off position for 10 seconds, it will shut off. then switch it back on. It should reacquire a signal within 2-5 minutes, then it will fix on your position. If that doesn't work, try updating your software. Call Magellan Tech Support for instructions.
Dec 29, 2011 | Magellan RoadMate 1412 Car GPS Receiver
Magellan 700 roadmate
it is a dicontinued like mine roadmate700 and started losing sattilite signal like everyone says here ,i got upset i spent alot of money on it,then this happens, so i decided and bought the new magellan mastreo 4000 and just updated the software and no problems i love it,portable,thin light weight internal chargable battery that lasts 3hrs,the signal strenght is awsome,never had any problems,my advice junk it, the 700 like i did and purchase a new unit.this way it will save you alot of problems and headaches in the future,beleive me.
Jul 29, 2008 | Magellan RoadMate 700 GPS Receiver
My 700 gets stuck with the last map
Same problems, you have to update as far as I know and you have to update every year otherwise it will start to freeze up. It's a rip off because it's $99 a year. Does anyone know if the other GPS companies do this?
May 14, 2008 | Magellan RoadMate 700 GPS Receiver
All navigation units are GPS Receivers - that is - they receive satellite signals. So, no there is no difference.
Apr 19, 2008 | Magellan RoadMate 700 GPS Receiver
Magellan roadmate 700 Does not track
get a new unit like any magellan mastreo series 4000 or higher or roadmate 800 or higher,i had a 700 they start having alot of problems after i did my research on here
Feb 15, 2008 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700
Yes, get a new car connector. -Daniel
Apr 23, 2007 | Magellan RoadMate 700 GPS Receiver
Stopped working
Your probably right about it still not working even after the 5.32 upgrade. Although it could be the software, so try resetting GPS user data. Enter into the "secret" menu by pressing the zoom out key and the repeat button while at the beginning user menu. select reset GPS data.. If it's nothing to do with software, check your antenna and make sure none of the pins inside the connection are bent.. or the RF cable inside could be gashed/cut.. bent up.. do you hear a rattle when you shake your unit?
Apr 20, 2007 | Magellan RoadMate 700 GPS Receiver
Loss of signal
Leslie, Not updating your GPS isn't going to cause signal loss. Push the options key, go to configuration, then to diagnostics, scroll down.. select reset gps. it will say it takes 5 min. to relocate.. etc. see if that fixes it. If it doesn't fix then when you restart your unit and the user menu appears. Press "-" key and "repeat" button at the same time.. then select clear gps user data or.. user data gps... something to that nature.. Hope this works out for ya. -Dan
Oct 18, 2006 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
268 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
